Any one here got a 1911?
Discussion in 'Guns & Hunting' started by dman597, Feb 11, 2013.
  1. Jun 2, 2017 at 8:11 PM
    #221
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    First go round he said different length extractor so that's how I answered. I Missed the second time around he said ejector. Yes there are different length and shape ejectors. For open guns you want as long an ejector as possible. Not nearly as important on non open guns and standard length for that caliber are fine. Some guns need some tweaking.
    The longer the ejector the sooner it hits the case and pushes it. If the ejector is too long it can cause the case to swing out before clearing causing a problem. Also have to ensure the ejector is relieved to not make contact with the magazine as it's seated.
  2. Jun 2, 2017 at 8:13 PM
    #222
    SFSMedic
    Brett C
    Corona, CA
    Something else to check if we are talking ejectors and not extractors is the ejector cut in the slide. Many factory guns lately have their breach face cut to high so the case slides all the way up right on past the ejector track meaning the ejector never even touches the case. That's easy to see. Remove the slide put a round into the slide and look at the ejector track from behind. Can you see the case? If so then good to go. If not than the only fix is an oversized ejector, machine the ejector track higher and machine ejector to fit. But in reality a lot of these guns once the extractor is tuned right has flawless extraction and ejection so it's not usually worth all that work.
  3. Jun 2, 2017 at 8:17 PM
    #223
    beyer075
    beyer075 Rock Licker
    Northern Nevada
    2016 White TRDOR
    I did say extractor at first, got the two parts confused... but thank you for the answers, they were very helpful as I am still learning 1911's.
  4. Jun 2, 2017 at 8:33 PM
    #224
    SFSMedic
    Brett C
    Corona, CA
    I studied under a master 1911 gunsmith for 2 years and took all my machining classes before I started working on them. I'm still studying under him since he's got over 40 years of experience. They are not simple by any means. Feel free to ask and I'll help out where I can.
    cmack likes this.
  5. Jun 2, 2017 at 9:26 PM
    #225
    cmack
    cmack Well-Known Member
    Dana 44
    How do I clean my 1911?
    :D
  6. Jun 2, 2017 at 9:28 PM
    #226
    Foggy Noggin
    Foggy Noggin Well-Known Member
    Puyallup
    2017 Tacoma TRD Off-Road 6MT
    OME BP-51 LR UCA Stealth Custom Series F5 Nitto Trail Grapplers 285 75 15 ARB Dual Air Compressor Rigid Industries Fog lights
    Dan Wesson Valor vbob
  7. Jun 2, 2017 at 9:39 PM
    #227
    SFSMedic
    Brett C
    Corona, CA
    Unicorn farts and sea monkey water
    cmack likes this.
  8. Jun 2, 2017 at 10:32 PM
    #228
    Justified
    Justified Well-Known Member
    Wayne
    Nevada
    2013 Pyrite Mica Tacoma TRD DCSB Off Road
    Beware of the "idiot scratch" when reassembling. :p
    taco2010trd likes this.
  9. Jun 3, 2017 at 6:31 AM
    #229
    SFSMedic
    Brett C
    Corona, CA
    Getting rid of those sharp edges. Carry Bevel pkg, still needs bead blasting.
  10. Jun 3, 2017 at 7:49 AM
    #230
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    W
    Would you mind giving your opinion on the best and worst 1911 manufacturers ?
    Thanks
  11. Jun 3, 2017 at 8:34 AM
    #231
    SFSMedic
    Brett C
    Corona, CA
    Honestly they all have their quirks and each individual 1911 from each manufacturer is different. Kimber has weird metallurgy issues (grainy) at time when doing custom work, Springfield overcuts their beavertail tangs making it a pain to blend (have to weld up and recut), RIA metallurgy and the list goes on and on. I prefer SA as a starting platform for a full donor gun but that's just my preference.
    Getting into high end manufacturers doesn't always mean high end products. I just put a new gunsmith fit barrel in a high end manufacturer and their barrel fit was awful. The hood was .008" to short and the lower lugs were over cut to the point the barrel was starting to downlink, they would have broke in about 5000 rounds, accuracy would have been horrible and I doubt it headspace right. It was done so the slide blended with the frame instead of properly blending the slide to the frame after the barrel was cut.
    I've had factory guns where the breach face is narrower than the Saami drawing of the caliber it's supposed to be shooting. A common issue is the breach faces cut to high like I memntioned before. Granted they still run fine with a properly tuned extractor so it's rarely addressed.
    Keep in mind I'm looking at this from a machinist and gunsmith stand point. Off the shelf guns are USUALLY fine and if not the manufacturer will USUALLY cover repairing it. I'm looking at it from a hand fit everything to proper specs to make it run excellent reliable and accurately. They are looking at it from a mass produce standpoint. The higher end guns that are hand fit down an ssembly line of smiths have zero excuse for what I described above. But as long as they stand behind it that's fine also.
    Rob Daman, taco2010trd and Holeshot like this.
  12. Jun 3, 2017 at 9:03 AM
    #232
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Have owned the following 1911s; Colt 1991 Commander, Charles Daly 5" (I know Phillipines), Kimber 5",
    Dan Wesson Valor SS 5", and Dan Wesson Specialist SS 5". All are gone except the DW. What has been your experience with DW products since CZ took over.
    This post is for SPSMedic.
  13. Jun 9, 2017 at 10:53 AM
    #233
    GPC
    GPC Well-Known Member
    LFOD
    2015 Tacoma TRD Pro
    I call it a re-assembly mark. That was way I learned in the Military way back in the day lol.
    Justified likes this.
  14. Jun 9, 2017 at 7:28 PM
    #234
    GPC
    LFOD
    2015 Tacoma TRD Pro
  15. Jun 9, 2017 at 7:36 PM
    #235
    taco2010trd
    Tampa, Florida
    GPC likes this.
  16. Jun 18, 2017 at 10:59 AM
    #236
    SFSMedic
    Brett C
    Corona, CA
  17. Mar 9, 2018 at 11:51 AM
    #237
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    Man, nobody even got a 1911 for Christmas??? 8 months, no posts. :rolleyes:
  18. Mar 9, 2018 at 11:57 AM
    #238
    taco2010trd
    Tampa, Florida
    I shot my two recently...:woot:
    ROCdermody and Member1Zillion like this.
  19. Mar 9, 2018 at 12:01 PM
    #239
    Member1Zillion
    Big Whiskey, WY
    I'm outta practice. It's been like 10 days. :annoyed:
  20. Mar 9, 2018 at 12:10 PM
    #240
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    Shot on a darts target with a buddy last week. He shot his FN FiveSeven, I shot my 1911 officer. I cleaned his clock. He switched to his Ruger Mark IV target rimfire with glass. I cleaned his clock again. Good times.
    Member1Zillion and taco2010trd like this.
