Any one Line-x their frames?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hunt/Taco, Apr 27, 2018.
  1. Apr 27, 2018 at 6:46 PM
    Hunt/Taco
    Hunt/Taco [OP] Well-Known Member
    Coleman
    2003 Tacoma, Reg Cab, 2.7, 4wd, Auto. 90,xxx miles
    Pioneer Radio, New rear bumper (that does not really count though). Going to be upgrading it more and more as time goes on.
    Have any of you had your frames Line-Xed? I talked to a guy where they spray Line-x and he said they will not spray it on the frame, with the cab still on, as if it gets on your brake lines/ wiring when they are spraying it, it hardens, that would not be good. I guess it is pretty hard stuff, and dries very very fast. Would love my frame to be sprayed with Line-x though. So have any of you guys had yours sprayed? And if you had them spray your frame, did you have the whole thing stripped down to the frame, or did you have them spray your frame with the cab still on? Thanks
  2. Apr 28, 2018 at 4:43 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Why would you want to do that?
    if it is to protect from rust, you are much better greasing/rustproofing the frame than put this stuff on it.
    It would be a very bad idea to put line-X on the frame with this purpose in mind
  3. Apr 28, 2018 at 5:28 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    The frame rots from the inside out
    jeff b and Hunt/Taco[OP] like this.
  4. Apr 28, 2018 at 7:09 AM
    Hunt/Taco
    Coleman
    It was just a thought. I know the frames rust from the inside out. I was just thinking about painting the out side of the frame, and putting the oil to the inside of the frame. I am going to keep it oiled/ greased anyways. I am bringing my truck into Toyota for one last frame inspection, would like it to fail, for a new one. If it passes, I will just grease/ oil it, like you guys said. Thanks for your input.
  5. Apr 28, 2018 at 7:11 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Your best bet is POR-15. It’s kind of expensive but it’s the best option for rust proofing. I just POR-15’nd my rock sliders and plan on doing my entire frame when I can.
    standard and Hunt/Taco[OP] like this.
  6. Apr 28, 2018 at 7:36 AM
    Hunt/Taco
    Coleman
    We Por-15 my Brothers 2002 Toyota tundra frame. Still not sure if I like Por-15. I think if my original frame rusts out, I will just buy a replacement frame and pay some one 1-2,000 to do the frame swap for me. My truck only has 90,800 miles on it right now. And for the most part the frame is not all rusted. From the back of the cab back, it could use grease/ oil. Going to keep pumping the inside of the frame with oil also. Keep it coated.
    QMEDJoe[QUOTED] likes this.
  7. Apr 28, 2018 at 9:49 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Why not have it powder coated... thats the commen thing to do. Not linex
    Kiloyard and Hunt/Taco[OP] like this.
  8. Apr 28, 2018 at 9:50 AM
    QMEDJoe
    Joe
    Yeah, I only have surface rust as of right now. I bought it a few years back and it looked like a brand new frame. It was rather garaged or replaced. I looked into brand new and they were like $3k.
    Hunt/Taco[QUOTED][OP] likes this.
  9. Apr 28, 2018 at 9:51 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    And i think por15 can stand the heat from power coating, think its rated for 400 degrees, not sure how hot powder coating gets
    Hunt/Taco[OP] likes this.
  10. Apr 28, 2018 at 11:01 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just oil your frame every winter - it's a tested solution - fluid film and a few other types of oil work.
    standard, Danno1985 and Hunt/Taco[OP] like this.
  11. Apr 28, 2018 at 1:22 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I'm sold on fluid film. It was designed with Heavy Marine Industry in mind meaning protecting steel from salty water. I used it the second time on my both trucks and the coating is the best from anything I've seen.
  12. Apr 28, 2018 at 3:32 PM
    Hunt/Taco
    Coleman
    How much would that cost? And could they powder coat your frame with the cab still on, or does it have to be fully disassembled?
  13. Apr 28, 2018 at 3:34 PM
    Hunt/Taco
    Coleman
    What type of oil do you use? And this is what I plan on doing anyways, buy a sprayer for the air compressor, that way I can put what ever type of oil I want in the sprayer, and just spray the frame, inside and out.
  14. Apr 28, 2018 at 3:35 PM
    Hunt/Taco
    Coleman
    I have used fluid film on the snowblower to keep the snow from building up. Do you buy it in the gallons, and just spray it on your self?
  15. Apr 28, 2018 at 3:36 PM
    Hunt/Taco
    Coleman
    Yup, when my frame needs replacing I would like to have the swap done to it, if the rest of the truck is still good. The frames are about $3,800. Pay a guy 1-2,000 to do the swap, and you are all set. That is way down the road though.
  16. Apr 28, 2018 at 3:37 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I live in socal so there's not a hint of rust on either of my trucks - most guys in the salt belt that truly care about rust prevention will use fluid film or Krown or some home-made concoction like some old diesel fuel mixture etc. Eric O. who does South Main Auto on YouTube used Krown with good results. Fluid film is probably a little cheaper.
  17. Apr 28, 2018 at 3:51 PM
    Hunt/Taco
    Coleman
    What is Krown?
  18. Apr 28, 2018 at 3:53 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  19. Apr 28, 2018 at 4:00 PM
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    My truck has only seen one real winter, but I made sure to fluid film it meticulously inside and out this last fall. When I power washed the undercarriage before re-applying this spring, everything looked brand new under the coating of gunk. That stuff works and I will swear by it from now on. I only regret not discovering it earlier.
    Hunt/Taco[OP] and Dalandser like this.
  20. Apr 28, 2018 at 4:11 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Powder coating requires taking the frame to just a bare frame, no rubber at all
