Any one Line-x their frames?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hunt/Taco, Apr 27, 2018.
  1. Jun 19, 2018 at 3:02 PM
    #41
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    And use listend to a chevy guy?
    BigRed03 likes this.
  2. Jun 19, 2018 at 3:10 PM
    #42
    BigRed03
    BigRed03 Well-Known Member
    Scott
    03 Taco TRD DC
    I would definitely agree that if you don’t clean the gun immediately it will be trash.
  3. Jun 19, 2018 at 3:18 PM
    #43
    BigRed03
    Scott
    03 Taco TRD DC
    Yes. As stated earlier I took the bed off, power washed the frame inside and out. Then I scraped and wire brushed the areas that needed it. De-greased everything, metal etched everything and let it dry after washing the metal etching off. Then I proceeded with the por-15 application 2 coats. Then I sprayed the frame internally, when you do this make sure you cover every hole in the frame with tape or it will get everywhere. Once it was dry I removed the tape and sprayed the POR-15 Hardner over the frame. I was tired of fooling with it.
  4. Jun 19, 2018 at 4:16 PM
    #44
    tony2018
    tony2018 Well-Known Member
    Hey at least I searched for an answer.
  5. Jun 28, 2018 at 7:17 PM
    #45
    Hunt/Taco
    Hunt/Taco [OP] Well-Known Member
    Coleman
    2003 Tacoma, Reg Cab, 2.7, 4wd, Auto. 90,xxx miles
    Pioneer Radio, New rear bumper (that does not really count though). Going to be upgrading it more and more as time goes on.
    Thanks guys for all the input. Just was searching options. Come to find out, I got approved for the new frame through Toyota. So do not have to worry about painting the old frame. Just have to worry about keeping the new frame well undercoated/ oiled. Thanks again guys.
  6. Jun 28, 2018 at 7:18 PM
    #46
    Hunt/Taco
    Coleman
    Brought my truck in 5 days before the 15 year warranty was up, and got approved. Waiting for the frame to come in to Toyota.
  7. Jun 29, 2018 at 6:43 AM
    #47
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    I have been using Fluid film and it has been great for 4 new england winters. The only rust on my truck is a small spot on the bed floor where the coating cracked (it is a ridgid coating from Toyota) and some salt or calcium chloride got in the crack and it stayed. Terrible rust hole. That confirms my belief that a conforming coating like fluid film is best. I think a material like linex bed coating is not appropriate for frame coating or any undercoating application.
    Hunt/Taco[OP] and Danno1985 like this.
  8. Jun 29, 2018 at 6:56 AM
    #48
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Didn't read the thread, but
    What ever you do, you don't want to create a barrier that can trap moisture inside your coating. This issue with some of these coatings, they crack moisture gets inside and rusting begins while you can't see it.
    My research suggested that the best approach is a fluid film or crown type of annual or more spraying.
    Hunt/Taco[OP] likes this.
