ANY ONE PUT BIGGER TIRES ON THE LIMITED 18 WHEELS?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DAVIDAWD, May 12, 2016.
  1. May 12, 2016 at 4:57 PM
    DAVIDAWD
    DAVIDAWD [OP] Member
    DAVID
    2016 TACOMA LIMITED 4X4
    PREDATOR TUBULAR SIDE STEPS LED LIGHT KIT HUSKY MATS TRI-FOLD COVER
    I WANT TO SWITCH THE TIRES ON MY STOCK LIMITED 18S I WAS THINKING ABOUT THE
    COOPER DISCOVERER SST. WILL I BE ABLE TO FIT THE 275/65/R18 WITHOUT LIFTING IT?
  2. May 12, 2016 at 9:11 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I'm 99% sure they will. I wish I had a better answer, but I wanted to give a better answer than:
  3. May 12, 2016 at 10:33 PM
    Lanhusa
    Lanhusa Well-Known Member
    Wow ! Calling him dumbass is kinda harsh
  4. May 12, 2016 at 10:40 PM
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    I'm pretty sure that 275's will rub. I was looking to put them on my truck as well and people are stating that the largest you can fit are 265's without a lift because the will rub when you turn. Can't give you a for sure answer but check with your tire shop before throwing down the cash.
  5. Jun 6, 2016 at 3:56 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    They will fit but likely rub a bit. I had 275/65 r18's with a leveling kit and took the pucks out due to the differential vibration. It was just fine with just a little run when the steering wheel was fully turned. Each wheel and tire setup is different.
