Any one running billies 5100 and Relentless bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcanders, Feb 2, 2011.
  1. Feb 2, 2011 at 2:47 PM
    bcanders
    bcanders [OP] Active Member
    I am about to pull the trigger on the Relentless bumper, however I am not looking for a huge lift. Will getting a set of billies help out with the additional weight of bumper and winch. So many options out there for suspension. I nice set of coilovers would be nice but spendy. OME has a complete lift for about the same as a set of coilovers. I have a brand new set of 265/70/17 toyo's so I don't want to go to high. I just can't stand having a normal tacoma. Will the relentless bumper work with a bud built IFS skid? I believe the stock one will still work. Do you still retain the sway bar with the relentless bumper? I guess I need to do even more research.
  2. Feb 2, 2011 at 2:54 PM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    I think you will need heavy duty coils. Some guy smarter than me will chime in.
  3. Feb 2, 2011 at 2:55 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The 5100's are not going to change much if you keep the stock coils I recommend you getting some beefy coils the bumpers are heavy and I don't think stock coils will cut it.
  4. Feb 2, 2011 at 3:50 PM
    bcanders
    Can I run OME N182 NitroCharger Rear Shock Set on a stock rear end? All I am looking to do is level out the front end and put a bumper and winch on it. As it sits right now 35.25 inches in the front and 37.5 in the rear. If I get OME 886 Tacoma Front Coil Set which is said to give a 1.75 inch lift.It should level it out and give me the strength needed to hold up to the extra weight. So if I leave the rear stock other than the shocks and put new coils and shocks up front....should work Right??
