Any pics of OEM roof racks put to good use? any other option worth the money?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016TacomaTRD, Jan 1, 2017.
  1. Oct 17, 2019 at 12:31 PM
    #61
    kyal5
    kyal5 Well-Known Member
    Haha that's awesome!
  2. Oct 17, 2019 at 12:34 PM
    #62
    Jtoeps
    Jtoeps Well-Known Member
    2020 Off Road - Voodoo Blue
    Can anyone post pictures of the Rack + how it clears the fin antenna? The one that the dealer installed as part of my 2020 purchase interferes with the antenna when extended. (The rear bar hits + depresses the antenna/roof slightly when I click it into the receptacle)
    Thanks.
  3. Oct 20, 2019 at 3:00 PM
    #63
    gmanrider9
    gmanrider9 Well-Known Member
    Garrett
    Longmont, CO
    2009 Blue Toyota Tacoma TRD DBC
    3" Toytec Lift, Rigid Industries Grill, 10" SR2 Light Bar, Auxbeam Front Spot Rear Flood, All Pro Bumpers, Projector Retrofit Lights, 33" Tires, Smittybuilt Winch, Raised K&N Air Intake
  4. Oct 20, 2019 at 8:37 PM
    #64
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Unloaded it should clear that fin and fit a full size locking carabiner spine in the gap with room to spare — sorry for the dumb reference pic, a carabiner is what I had in grabbing distance. If the crossbar is in the hole correctly and hitting the antennae fin then that means you are exceeding the weight limitations. But, and I get this is sometimes a thing, are you sure you didn’t stick “it” into “the wrong hole?”
    Edit: I guess it’s not the wrong hole, it’s just one you need to be sure about before you go for it.
  5. Oct 21, 2019 at 9:11 AM
    #65
    slamson00
    slamson00 Well-Known Member
    Northern California
    2019 Tacoma TRD Off Road DCLB
    Sure no problem......except I am on the road for work this week and wont be back till Friday. I can get you a couple pics then if you don't mind waiting.
    gmanrider9[QUOTED] likes this.
  6. Oct 23, 2019 at 3:44 PM
    #66
    gmanrider9
    Garrett
    Longmont, CO
    No worries! Bought the mounts lemme know!
  7. Oct 23, 2019 at 4:47 PM
    #67
    blackmist27
    blackmist27 Well-Known Member
    17 Tacoma TRD Pro
    Leer shell 100XR
    how much are OE roofracks rated for?
  8. Oct 23, 2019 at 5:03 PM
    #68
    gmanrider9
    Garrett
    Longmont, CO
    Mine is rated for 150
  9. Oct 23, 2019 at 5:44 PM
    #69
    Beau_Higgins
    Beau_Higgins Well-Known Member
    I've had the OEM rack b4... adjustable bed racks are way more useful, IMO
    Yakima overhaul HD + Retrax cover would be the bees knees but $$$$
  10. Oct 23, 2019 at 9:24 PM
    #70
    Nito
    Nito Well-Known Member
    Portland, OR
    ‘20 Cement Off-road DCLB
    Did you find a solution for this?
    I just got mine installed by the dealer and when I got home, I extended the cross bars and realized it does the exact same thing. My antenna and roof are depressed when I insert and secure in the hole.
    I don’t mind driving back to dealer but if you’ve found a solution I don’t mind fixing it myself either.
  11. Oct 24, 2019 at 12:26 AM
    #71
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
  12. Oct 24, 2019 at 9:10 AM
    #72
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Pics? It shouldn’t be doing that if it is installed correctly AND you are sticking the little nub into the “traditional” hole. (I just can’t stop with these two-holes joke—I’m sorry.)
  13. Oct 24, 2019 at 9:25 AM
    #73
    Nito
    Portland, OR
    I'll get some pics up today. Currently at the courthouse for jury duty. Fun stuff!
    Called the service depart at dealer who installed them and they said to bring it back in as they don't know what I'm talking about. Does anybody know if they've changed the antenna at all on the 2020? They seem to be mounted correctly and if they're still using the same predrilled holes in the roof, it's odd that it doesn't fit.
    Sticking the nub in the traditional hole, i believe. I mean, I've heard no complaints?
  14. Oct 24, 2019 at 1:06 PM
    #74
    Nito
    Portland, OR
    So at the dealership. realized that 2020 antennas are moved forward. Which interferes with the roof rack.
    Parts said there’s not even an option on the roof rack for 2020 at this time. But once there is they’ll install for free and allow me to keep the 2019 one to to resell so that’s a plus? Lol
    I’ve attached pics for reference.
    My cement is the 2020. Other is 2016-2019. 46DE6C8A-51DF-4ADC-B62D-CD69D04CD3DB.jpgDFD61A08-16F2-4BB6-9450-1945B41A8E01.jpg
    AKGSD likes this.
  15. Oct 24, 2019 at 1:15 PM
    #75
    Jtoeps
    I was gonna post pics of mine. I saw a 2018 in the work lot and the antennas looked different. What a dumb change.
    (No I haven’t found a solution yet)
  16. Nov 5, 2019 at 10:01 AM
    #76
    Toadfishjax
    Toadfishjax Member
    Chad
    Jax, Fl.
    15 Tacoma TRD 4x4
    31 Maxxis Buckshot 2s, Yaesu ham radio, K&N CAI
    Did you use the same Mighty Mounts to mount the awning? I just ordered an OEM rack and an awning the other day. Thanks!
  17. Nov 5, 2019 at 10:57 AM
    #77
    slamson00
    Northern California
    No. The awning is the Slim Shady Awning from Yakima and it comes with its own quick disconnect mounts that work with a ton of different racks (including the OEM rack). Their mounting system is awesome by the way for this awning. Hope that helps.
    https://www.yakima.com/slimshady
    darcivic00si likes this.
  18. Nov 5, 2019 at 11:22 AM
    #78
    1992SR5V6
    1992SR5V6 Well-Known Member
    2018 TRD Sport 4x4 Cement
    Bolt on only...
    If I had to do it again I would skip the OEM rack. The spacing is an odd size and too wide for some accessories. I had to add an extension to our Yakima basket, but still cut the basket down 1-1/2" so it would fit the rack. Our cargo box won't fit either because the bars are too far apart. I think the bike racks would fit, but it's fairly tall to load bikes. I guess it would be a decent kayak carrier, but in general I'm disappointed with the rack. We have a similar factory rack on our Subaru Outback and it's much nicer quality and more usable.
  19. Nov 5, 2019 at 5:03 PM
    #79
    Taco2022
    Taco2022 Well-Known Member
    2017 TRD Sport DCSB 4x4
    Bilstein 6112, SCS SR8, Grabber ATX 275/70/17
  20. Nov 21, 2019 at 11:58 AM
    #80
    tacomahokie
    tacomahokie Member
    2005 TRD Sport 4x4 DCSB
    What did you cut off 1-1/2" of to make the Loadwarrior + Extension fit the rack? I'm toying with solution as well. Did you cut off 1-1/2" of the extension, one of the main rack pieces, or something else? I assume that was to make the mounting points fit the fixed crossbar spread?
