Any pics of the tailgate hose clamp?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeS., Jun 18, 2008.
  1. Jun 18, 2008 at 8:34 PM
    MikeS.
    MikeS. [OP] Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    I was reading a thread on page 8 and the photo there is now gone. Someone post some up for me, please?
  2. Jun 18, 2008 at 8:40 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    If there isn't one by Tomorrow, I'll grab a pic off my Taco.
  3. Jun 18, 2008 at 8:59 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
  4. Jun 18, 2008 at 10:17 PM
    MikeS.
    Far Eastern WVa
    Thanks guys.
  5. Jun 19, 2008 at 3:29 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Definitely put a strip of rubber/plastic under the clamp to prevent premature rusting in that area.
  6. Jun 19, 2008 at 4:01 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Good Idea!!
  7. Mar 16, 2009 at 7:57 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I'm totally doing that... and grinding the head off the clamp.
  8. Mar 16, 2009 at 8:32 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I didn't take the gate off to look but does a clamp on the driver side do anything?
    Also, if you grind the head off, it will be a pain to remove the clamp, if necessary.
  9. Mar 16, 2009 at 8:34 PM
    JSU
    JSU Member
    HouTex
    '07 PreRunner TRD/Sport AccessCab 4.0V6, auto
    Why not fill in the screwdriver slot with epoxy/JB Weld? That way you could still access it with a socket and long extension but not a screwdriver. A serious thief might have a screwdriver in his bag of burglar tools, but likely would have left the socket set at his hideout.
  10. Mar 16, 2009 at 8:39 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Climb under the truck, have someone hold the tailgate partway open and you can line up the screw on the clamp so when the tailgate is down the screw head can't be reached.:thumbsup:
  11. Mar 17, 2009 at 6:38 AM
    Raven65
    Camden, SC
    Well, that's the whole point, isn't it? ;) I never plan to remove my gate, but never say never. If I ever do need to, I can grind a new slot in the head in about 10 seconds with my Dremel and then take it off with a screwdriver - or just cut the clamp band.
    fletchaka, that is an EXCELLENT suggestion about positioning the clamp on the gate so it can't be accessed when the gate is down! Thanks... I'm doing that (too).
  12. Mar 17, 2009 at 6:42 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    No.
  13. Mar 17, 2009 at 6:46 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I remove my gate when I've got to load a bunch of stuff in the truck bed. I had a forklift load a pallet of pavers in my bed (no, it wasn't full) and if I had the gate on, the driver probably would have crushed the gate trying to get the pallet all the way in. It is also much easier when shoveling sand/dirt into and out of the truck.
  14. Mar 17, 2009 at 8:20 AM
    Raven65
    Camden, SC
    Well, if you're going to be doing that sort of thing often, then my method would obviously be a bad idea. Not an issue for me. You just have to keep in mind that the easier it is for you, the easier it is for a thief - and balance your needs accordingly.
  15. Mar 17, 2009 at 8:27 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm still going to do the pipe clamp, but I'll make it a little easier than grinding off the head.
