Any plans for ucon being made available for first gens
Discussion in 'Performance and Tuning' started by Empty_Lord, Oct 15, 2016.
  1. Oct 15, 2016 at 5:57 PM
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Just curious if anyone knows wether or not gadget (urd) plans on releasing a ucon compatible for the first gen v6. I'd like to get a piggy back for mine since I can't go full standalone thanks to the good old EPA. I feel with the amount of stuff I'm adding I'll be losing a lot of power due to the limiting stock ecu.
    I'd like the latest and greatest. But if there is no plans for it I'll just stick with the split second unit
  2. Oct 16, 2016 at 2:29 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Seeing as how it took him the better part of 6 years to get the 2009+ UCON harness going, I wouldn't hold your breath
    inwood customs likes this.
  3. Oct 16, 2016 at 11:01 PM
    Empty_Lord
    Dan
    I figure so much but it doesn't hurt to ask. There's almost no choices for the 1st gems that I can find. Other than unichips
  4. Oct 17, 2016 at 4:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Looking for plug n play only huh?
  5. Oct 17, 2016 at 10:10 AM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    My friend used a megasquirt on his first gen. I don't know much about it, but that's what he did.
  6. Oct 18, 2016 at 11:24 AM
    Empty_Lord
    Dan
    I'd go standalone if there's a way to trick the obd2 systems since I have to do that damn clean air check every 2 years. I don't know how to go about putting a standalone in and passing emissions
