Any problem with this wheels stud and spacer combo?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by berry79, Jul 20, 2011.
  1. Jul 20, 2011 at 5:24 PM
    berry79
    berry79 [OP] Well-Known Member
    Homestead, FL
    08 DBL Cab LB
    I've been searching and can't find the exact answer I'm looking for. I just got new wheels, XD Enduros in 16x8. They fit but barely clear the calipers and I'm sure once I change out the pads they will hit the calipers. I'm thinking about replacing the front studs with longer ones and adding a 1/4" spacer from AutoZone. My wheels are lug-centric and I already have the ET lugs. Does anyone see any problems with this set-up? I don't want spider-tracks because the wheels will stick out to far for my liking, and a 1/4" spacer will give plenty of clearance for the caliper. From my research, it seems the only problem with these spacer is the studs being to short which, will be resolved by swapping out the studs for longer ones. If there is some problem I'm missing, please let me know.
  2. Jul 21, 2011 at 8:55 AM
    berry79
    Homestead, FL
    08 DBL Cab LB
    I guess this should be good to go then.
  3. Jul 21, 2011 at 9:32 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the 1/4" wheel spacers that fit over the lugs have caused vibration issues in the past. changing your pads will not change how far the calipers stick out as the caliper housing does not move, the pistons inside move the pads in.
  4. Jul 21, 2011 at 9:46 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    sounds like what im running. i followed this thread
    tons of good info http://www.tacomaworld.com/forum/wheels-tires/119883-wheel-studs-too-short-what-do.html
  5. Jul 21, 2011 at 10:00 AM
    berry79
    Homestead, FL
    08 DBL Cab LB
    Now I see they are four piston caliper which are mounted solid. I'm still going with the spacers because it's so close you can barely fit paper in there.
  6. Jul 21, 2011 at 5:50 PM
    berry79
    Homestead, FL
    08 DBL Cab LB
  7. Jul 21, 2011 at 6:32 PM
    The_Hodge
    SC
    same as the fit on my 8069s and i've never had an issue and been running them off/on for over 2 years. as long as the dont rub when you spin the wheel, you're fine.
