Any problems from removing the secondary air filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roggs01, Jan 3, 2009.
  1. Jan 3, 2009 at 9:34 PM
    roggs01
    roggs01 [OP] Roggs01
    Surprise, AZ
    16 TRD Sport
    Predator steps,Method NVs, 285-70-17 KO2s
    Before I do this mod, I wanted to check with others to see if any problems arose from doing so. Also, what where the major gains if any:confused: I have an 07 .....:confused:
  2. Jan 3, 2009 at 9:51 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
  3. Jan 3, 2009 at 9:52 PM
    Lentsnh
    there is on the I-4 like 007Tacoma did. but i havent heard anything on the V6
  4. Jan 3, 2009 at 9:56 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    already read those posts... looking for more long term feedback. thanks
  5. Jan 3, 2009 at 9:59 PM
    HighPlains
    HighPlains Well-Known Member
    You might look into adding a cold air intake system. I think most of them do away with the secondary filter. I installed the TRD cold air intake, and it does not use the secondary filter. The TRD cold air intake was everything I hoped it would be. Does not seem to have affected my mileage when I drive normally. Horsepower and torque gains are very impressive for such an easy modification. I'm thinking I got it bought for around $340. I installed it myself in about an hour or so.
  6. Jan 3, 2009 at 10:00 PM
    Lentsnh
    ok... I havent heard of anyone doing it to a V6 but i dont think it would help very much.. just more stuff getting in and coming out of your engine, Thats one of those mods that i wouldnt do because so many things could go wrong
    just my 2 cents
  7. Jan 3, 2009 at 10:03 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    Thanks... this is the info I'm looking for:cool:
  8. Jan 3, 2009 at 10:07 PM
    Lentsnh
    Your Welcome
  9. Jan 3, 2009 at 10:38 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I've done it, no issues nor have I ever heard of anybody having an issue with it. Truck idles a little better but thats about it. If you've got the time to do it I'd go for it.
  10. Jan 3, 2009 at 11:40 PM
    ERdept
    ERdept Well-Known Member
    I did it on my V6 and added the K&N intake. I'm happy with the gains. It seems more responsive, but I can't tell by the butt dyno.
  11. Jan 4, 2009 at 7:05 PM
    Lentsnh
    so if you take out the secondary filter and then add the K&N (or whatever) cold air intake it will help
  12. Jan 4, 2009 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have had my secondary filter out for a while now, and still NO difference.
  13. Jan 4, 2009 at 7:12 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I don't know that there's any positive to removing it but there certainly is no negative that I've seen. I took it out about a year ago. If there were a negative, I wouldn't think all the aftermarket CAI's would delete it.
    The OEM system already is a CAI. Remove the secondary filter and throw in an AFE ProdryS drop in filter and you save yourself $250+ and end up with about the same gains, if any.
  14. Jan 4, 2009 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    As Wilson said, the OEM intake system is a cold air system, as it gets fresh air from the fender, which on the newer gens, picks up air from the front of the passenger fenderwell. Most "Cold Air Intakes" get the air from under the hood (Hot air), and show NO power gains, and in the case of K&N, actually lose some h.p.. The URD system is the only one I have found that actually has a gain in h.p.
  15. Jan 4, 2009 at 8:02 PM
    Ghost96Romeo
    Ghost96Romeo What is the Search Tab for????
    Texas
    06 TRD Off-Road D-Cab
    3" Pro-Comp Suspension Lift AAL Rear w/TSB, All-Pro Plate Bumper, Lightforce 240 Blitz lights, Lund Genesis Roll-top Bed cover, K&N Filters, Spidertrax Wheel spacers, Built-by-Me Rock Sliders, Jeep Tow-Hook, Black Leather seats, 48"Hi-Lift Jack mounted in the bed, Blacked out TRD Rims, BHLM, FLM..... and Awesomeness
    No problems here either...K&N Drop-In Filter
  16. Jan 4, 2009 at 8:06 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Agree.. Seems to rev a bit smoother but nothing noticed...
    I also have an aFe pro dry
  17. Jan 5, 2009 at 8:20 AM
    roggs01
    Surprise, AZ
    16 TRD Sport
    Good input. Thanks guys
  18. Jan 5, 2009 at 9:10 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i did it and i havent noticed anything one way or the other. no difference in reving, no difference in gas millage, nothing. BUT its nice knowing the truck runs cleaner no matter what. Why breathe through a straw?
  19. Jan 5, 2009 at 10:43 AM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    My truck runs fine without it.
  20. Jan 5, 2009 at 9:42 PM
    bradu81
    bradu81 Well-Known Member
    N. California
    Silver Dbl Cab 4x4
    it just seems louder to me
