Any problems w/spidertrax wheel spacers?
Discussion in 'Wheels & Tires' started by DRDANTDC, Feb 12, 2012.
  1. Mar 13, 2012 at 8:40 PM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    no mods until the warranty is up!
    Love how mine look
    Camel51 likes this.
  2. Mar 13, 2012 at 9:54 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    I've run them on my JK for three years, and every tire rotation checked them. They have yet to budge.
    The only down side to spacers is most tire shops will refuse to mount, balance, or rotate tires on vehicles with spacers. If you know of a shop that will, you are fortunate. Of course, if you do your own rotations, no problem. I just took the wheels to Discount and had them mounted and balanced originally, dealt with rotations since then myself.
  3. Mar 13, 2012 at 10:03 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I think that typically tire shops won't deal with spacers. Spidertrax are adapters, and I don't think you'll get too much grief from most shops with those. Pretty sure I took mine into discount at least once with the spidertrax on.
    Camel51 likes this.
  4. Mar 14, 2012 at 7:14 AM
    whereismymind
    whereismymind Well-Known Member
    Don
    Broomfield, CO
    2012 Tacoma SR5 MGM D-cab
    Toytec Ultimate lift,Spidertrax spacers,Light Racing Control Arms,285/75/16 Duratrac's
    The Discount Tire I normally go to doesn't have a problem. I did try a different DT location and they wouldn't touch it.
  5. Jun 1, 2013 at 9:27 AM
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    I just ordered these yesterday from Wheelers...I called my local Americas Tire Co. before ordering and told the tech I am thinking of ordering spacers and asked if they would still service them, at first he said, "no we wont do anything with a wheel spacer on..." and I was thinking I could not get them...then he continued with "unless it is hub centric..."
    Then I got excited because I knew they were hub centric...so I was good to go...as maxamillion said they are probably actually technically called an adapter so there is not an issue...if a tire shop ever gives any guff, I would throw out the terms adapter and/or hub centric and that should aleviate any issue they might have.
  6. Jun 3, 2013 at 6:56 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors
    FWIW, when TAC1 inquired about my running the Spidertrax 1.25's on my truck I did a quick search and found that some aerospace guys drew these and the wheel in a CAD program. The program was able to acomplish FEA of the spacer and wheel.
    Turned out the spacer is considerably stronger the the wheel itself. The predicted failure location when using Spidertrax was the lug nut holes in the wheel.
    PK
    Camel51 likes this.
  7. Feb 18, 2014 at 6:58 AM
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Pensacola, FL
    '08 4X4 TRD Sport SR5
    I'm here for knowledge folks, please feel free to inform me. -Pioneer Double-Din Receiver -TRD 6-Speed Shift Ball -Low profile black UWS tool box Ordered/En Route: -Wet Okole seat covers -Weather Tech Digital Fit Floor Mats Desire: -Bilstein 5100 Adjustable Shocks -1" Hub Centric Spacers -285/65r18 BFG All Terrain TA K/O's
    It's an old thread but it could be where I find my answer. I'm considering a 2.5" Toytec spacer lift on my '08 TRD Sport access cab and have 18x9" BBS RW wheels with 5.4" back spacing and was told previously that 1" wheel spacers will allow me to clear the UCA if I put on 285/65r18 BFG AT KO's with minor fender trimming. Does this sound feesable?
  8. Dec 18, 2016 at 8:15 AM
    JP21
    JP21 Member
    Jared
    2017 Tacoma TRD Off Road dcsb
    I'm thinking about getting the spidertrax 1.25" spacers as well. I wouldn't have to do a tire rotation as soon as I put them on do I?
