Any problems with 285/70/17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD2010SpeedwayBlue, Jul 31, 2016.
  1. Jul 31, 2016 at 6:29 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    It has been five years since I installed my 285's, when does everyone start talking about my tires?
    OP, if you get 285s expect to trim the fender liners at the very least. You will not be able to run stock wheels without spacers, or you will have to get aftermarket wheels. You may have to do the cab mount chop (I haven't, I don't come close to it). Its really not that hard to run 285's.
    Casper66 and medic2230 like this.
  2. Jul 31, 2016 at 6:31 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue [OP] Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    yeah im not running stock wheels on the new tires. getting trd pro 17x7 wheels
  3. Jul 31, 2016 at 6:32 PM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^This plus expect to remove the front mud flaps. I haven't done the cab mount chop either. I am running off road wheels on mine and have spidertrax spacers but haven't installed them yet. When I do I will probably have to do the cab mount chop though.
  4. Jul 31, 2016 at 6:36 PM
    TRD2010SpeedwayBlue
    Brandon
    would i have to do any chopping or trimming with 275/70's?
  5. Jul 31, 2016 at 6:41 PM
    medic2230
    Murph
    Bama! Roll Tide
    What are the wheel specs besides 17 x 7? Someone can answer better if they know the full specs.
  6. Jul 31, 2016 at 6:48 PM
    TRD2010SpeedwayBlue
    Brandon
    4mm offset
  7. Jul 31, 2016 at 6:56 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    If you don't do any off roading and have 2.5"+ you should only have to remove the front mud flaps and minor fender liner trimming. That's all I had to do and I only rub while turning on driveway entrances and whatnot.
    Casper66 likes this.
  8. Jul 31, 2016 at 6:57 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    No they are all different. My fjc trails teams stick out about .5" further than the stock or wheels.
    To op the amount of trimming you have to do depends on wheel offset and if you add aftermarket uca's. You can split the difference with 275. The main problem with 17's vs 16's is the cost. I was going to get the same 17's with either 275 or 285 and sort of was talked into the 16's with 285 and I don't regret it a bit. Minor trimming on fender flares bottom edge front and rear of wheel well. I did bmc way before wheels and tires so I really don't even know if I needed it. I've heard of guys not having to trim at all but I think that's rare and I think they kept stock OR or sport wheels. The bfg ko2 are bad ass. I love mine
    medic2230[QUOTED] likes this.
  9. Jul 31, 2016 at 7:07 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    yeah those are factory wheels they are refferring to aftermarket wheels. i have 17x9 wheels with a 4.5 bs and -12 offset. i have started with a 3" spacer lift which will be changed shortly to bilstein but i needed no cmc, no wheel well trimming, only remove mudflaps and snip the bottom corner of the flare you can't even tell it was done
    285/70/17's
  10. Jul 31, 2016 at 7:17 PM
    TRD2010SpeedwayBlue
    Brandon
    do ya have anymore pics of your truck?
  11. Jul 31, 2016 at 7:24 PM
    medic2230
    Murph
    Bama! Roll Tide
    That would be around 4.25" back spacing. Your off road wheels are 5.25 back spacing.
  12. Jul 31, 2016 at 7:25 PM
    TRD2010SpeedwayBlue
    Brandon
    ok so that meannns?? haha sorry kinda clueless
  13. Jul 31, 2016 at 7:37 PM
    medic2230
    Murph
    Bama! Roll Tide
    Means the 4.25 BS would stick out about an inch further than what you have now. Which when turning could make you need a cab mount chop. When the wheel sticks out further it essentially increases the turning arc of the wheel which brings it closer to the cab mount when fully turned back and closer to the fender flare in the front.
    To add to this problem you also have different tire manufacturers that have different size tires with the same number's ex 285/75/16 Nitto may not be the same size as a 285/75/16 Yokohama. So someone with one brand tire in that size may fit perfect and another brand may not fit.
  14. Jul 31, 2016 at 7:56 PM
    TRD2010SpeedwayBlue
    Brandon
    so than maby if i dont want to have to trim anything i should just get 265/70's might be best if i just get that size because i dont want to have to do any trimming
    another thing should i get C rated or E rated??
  15. Jul 31, 2016 at 8:03 PM
    #35
    maxtherat
    Inland Northwest
    Get c if you have a choice
  16. Jul 31, 2016 at 8:04 PM
    #36
    medic2230
    Murph
    Bama! Roll Tide
    That's depends on what you're going to use the truck for. Mine are D rated which is 8 ply. E are 10 ply and will ride pretty harsh in our lightweight truck. C is a 6 ply tire and rides better. For off road use most don't go under a D for the extra protection.
    Personally I wouldn't want to ride around all the time on an E rated tire.
  17. Jul 31, 2016 at 9:43 PM
    #37
    Desert fan 55
    Desert fan 55 Active Member
    Dave
  18. Jul 31, 2016 at 9:51 PM
    #38
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
    Im running 275 on 885 coils. Very slight rub at full lock in reverse. No trimming.
    KO2 comes in 275 but only E rated
    97duc748 and Thesandaddict like this.
  19. Aug 1, 2016 at 12:21 PM
    #39
    TRD2010SpeedwayBlue
    Brandon
    yeah i have to decide what the best soze to get would be.
    im starting to think i dont really need E rated.
    im going to be doing off roading here and there but not crazy offroading mainly just trails
  20. Aug 1, 2016 at 12:40 PM
    #40
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    E rated might be less likely to get punctures since it has more ply
