Any problems with 33x13.5 tires and 6" Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Namyo, May 4, 2010.
  1. May 4, 2010 at 8:03 AM
    Namyo
    Namyo [OP] -
  2. May 4, 2010 at 8:09 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Never heard of anyone running that wide of a tire on any suspension setup on a tacoma. That's equivalent to around a 335.
  3. May 4, 2010 at 8:09 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Horrible gas mileage. And rubbing I assume
  4. May 4, 2010 at 8:43 AM
    Namyo
    Namyo [OP] -
    Come on.....I seen em on a Taco in here somewherez. Their not that wide and looks pretty good I thought:
  5. May 4, 2010 at 2:17 PM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    probably talking Mickey thompsons, they offer a 13.5 in a 33".
  6. May 4, 2010 at 2:29 PM
    Namyo
    Namyo [OP] -
    Doesn't really matter what kind...I'm just curious about the size on my 05' Taco. There are several kinds...will I still be able to wheel off road with that wide of a tire and a 6" lift? I seen a few other inquiries but no experience with running em. Hawaii seems to have a few but no wheeling pic's....maybe my sign. :cool:
  7. May 4, 2010 at 2:34 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    my buddy Timicha runs 33x13.50x15's on his lifted 1st gen (3.5" via CO's and a 2" body). They're hella wide, personally I wouldnt go wider than a 12.50 but they do look pretty good in that size.
  8. May 4, 2010 at 2:51 PM
    Namyo
    Namyo [OP] -
    Yea...kinda conflicted on looks vs practicality. I mean the roster tails that would be shooting up just from a wet road vs damn that looks good. Really curious about rubbing off road on a sec. gen. tho....nobody seams to run it if they wheel.
  9. Feb 15, 2011 at 9:57 AM
    guanotwo
    guanotwo New Member
    Jay
    Syracuse Utah
    06 Taco
    I'm doing the same thing. I'm ordering Mickey Thompson MTZ's in a 33X13.5X18 with a 6" Fabtech lift, using a 10” rim and a -25mm offset for a 2006 Taco. I’m finding that it depends heavily on the offset and wheel size. My friends Tacoma (07’) has a similar configuration as previously described (6” lift with the 33X12.5 tire) his is a -12mm offset, and he does get some rubbing off-road when turning hard left and maintaining a pinhead corner. With that said, I’m 90% sure that at minimum, you, “and I” will have to cut/modify the front body mounts just inside of the back of the front wheel well and again for the front inside cowling. Also, be sure depending on you lift, that the inside wall of your tire (because it's so wide) will not rub the steering knuckels. Sucks, but that’s the expense paid to install some 33 x 13.50 steam rollers I’m finding!
  10. Feb 15, 2011 at 10:00 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    mine are 13.19" wide and look good on 4.75" of backspacing on a 9" rim
    see
  11. Feb 15, 2011 at 10:14 AM
    guanotwo
    guanotwo New Member
    Jay
    Syracuse Utah
    06 Taco
    Those are Solid! Whats the overall tire diameter? wheel offset? lift height? Do you have any rubbing?
  12. Feb 15, 2011 at 10:50 AM
    ARC
    ARC Well-Known Member
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    The guys in hawaii are running wide wheels not tires. not functional in at all.
  13. Feb 15, 2011 at 12:29 PM
    PLC721
    Patrick
    Chandler, Az
    35" amd yes they rub offroad
  14. Feb 16, 2011 at 7:50 AM
    PLC721
    Patrick
    Chandler, Az
    oh geez i never realized you had 14.5's i assumed 13.5 :eek:
  15. Feb 17, 2011 at 8:48 AM
    PLC721
    Patrick
    Chandler, Az
  16. Feb 17, 2011 at 5:03 PM
    PLC721
    Patrick
    Chandler, Az
    thanks, and right back at you :)
