Any problems with a 2" lift?
Discussion in 'Suspension' started by cacarter, Apr 22, 2015.
  1. Apr 22, 2015 at 5:10 AM
    cacarter
    cacarter [OP] Active Member
    Maine
    15 Tacoma SR5 double cab 4X4
    Toyota skid plate, roof rack, and all weather floor mats, weather tech in channel vent visors, Thule 500xt xsporter rack, color matched grill, & blacked out badges, N-fab nerf bars, Pro Comp wheels, Nitto terra grapplers, OME 884 coils, Bilstein 5100's all the way around, Icon progressive AAL with overload left in. More to come!
    Getting my lift kit on my 15 double cab done today. Putting 5100's all the way around with OME 884's up front and Icon progressive AAL in back with the factory overload kept in. Just got a call from the dealer and they wanted to advise me that they've had issues with humming noises and vibrations from the differential and drive shaft with 3"lift kits. Where mine is only 2" will this still be a problem? Anyone out there have this set up and experienced any issues?
  2. Apr 22, 2015 at 7:52 AM
    cacarter
    Maine
    Just got a call saying they can't mount the 884's onto the 5100's because it's making the spring bow in the middle??? Anyway, going with 5100's set at 1.75" and stock coils. Hopefully I'll like it!
  3. Apr 22, 2015 at 7:57 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sounds like the 5100's are not at the zero setting or the spring perch is upside down
  4. Apr 22, 2015 at 8:23 AM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    You shouldnt have problems if they put the 5100s on the 0 no lift setting. And the diff vibration can happen at any amount of lift. Search ECGS Bushing. Happens to 1st and 2nd gens.. Mine went with 2.5" front lift. Not hard to replace. Pull CV and pull bearing/replace. Only driver side.
  5. Apr 22, 2015 at 8:52 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Tacomas with no lift at all have vibration issues :rolleyes:
    But seriously, any change you make to any drive line angles could cause a vibration. One inch, two inches, three inches - or even do nothing.
    For the front as someone already pointed out it is often the driver side bearing for the CV that is the culprit. ECGS has an inexpensive solution if that occurs. The likelihood of having a problem does seem proportional to how much lift you do, but restricting yourself to 2" or any other number is no guarantee you won't have a problem.
    For the rear some combination of shims to alter the rear diff angle or carrier bearing drop to change the two piece drive shaft angles will usually fix any vibrations that show up. It can be a hassle to get right and so if this happens it is best to measure drive line angles directly and plan a solution rather than just willy nilly trying out various drops and shims.
    Lastly for the rear "take off" vibrations (vibration when accelerating quickly) is usually due to axle wrap changing the diff angle enough that drive line vibrations become a problem during the acceleration. In some cases just changing the drive line angles (again axle shims or carrier drop) will get you to a point that you don't have vibes either at constant velocity or when accelerating. In extreme cases the issue is just too much axle wrap and you must fix that problem - but this shouldn't be an issue for you with just an add-a-leaf. It is a big problem if you do lift blocks (spacers) the way really high lifts or mall crawlers might.
  6. Apr 22, 2015 at 2:52 PM
    chas44
    chas44 Well-Known Member
    Virginia
    2012 TRD Sport
    I am calling BS on the dealer saying the 884s were bowing. I have 5100's with 884s and didnt have an issue when they were installed. Runs fine, no hums, etc. Best thing I ever did for my truck.
  7. Apr 23, 2015 at 1:12 AM
    cacarter
    Maine
    Got it from the dealer and they were able to get the 884's on after all. They didn't think they'd be able to leave the factory overload in either but they were able to as well. Put about 50 miles on it since I picked it up and love it! No vibrations, and the only noise I hear besides the stereo are the Nitto terra grapplers humming down the road. Very happy with it but next time I'll take it to a garage that specializes in suspension and not a dealer that only does this sort of thing on occasion.
  8. Apr 23, 2015 at 5:35 AM
    chas44
    Virginia
    2012 TRD Sport
    Looks great! Glad they were able to install the springs.
  9. May 14, 2015 at 7:25 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    How much lift did you end up with?
  10. May 15, 2015 at 2:32 AM
    cacarter
    Maine
    About 2" total all the way around with just a slight amount of rake, which is what I wanted. Recently though I have noticed I do have a mild popping sound coming from my front when I turn the wheel sharply to park or turn onto a side street. Looking into it today perhaps something has come loose. Otherwise very happy with the looks and the ride!
  11. May 15, 2015 at 9:08 AM
    Andy Standard
    Andy Standard To the Window, to the Mall. All the Tacomas Crawl
    California
    2011 TRD Sport 4x4
    Relentless Fabrication Hybrid Front Bumper, Sliders from Ghost Ship, Brute Force Fab High Clearance Rear Bumper, OEM Roof Rack, BedSlide S, Billie Bars, TuffStuff 4x4 Alpha II RTT, Countersteer X from FN Wheels, Nitto Ridge Grapplers in 285/75-17, Weathertech digital floor mats, FX-R retrofit projectors with 5000k HID, BD S8 30in bar, Diode Dynamics SS3 Pro, G4 Elite cover, Wet Okole seat covers, Flyzeye LED light, Bed Light LED kit, All in one key from Neneago
    Awesome lift, I'm looking to do the same exact spec as yourself. How much did the dealer charge you for the install by the way? I'm looking at $600 including alignment
  12. May 15, 2015 at 12:05 PM
    cacarter
    Maine
    Mine came to right around $600 with the alignment. It was there for about 9 hours total but I was only charged for 6. They have always been fair and as honest as you can expect with their billing. Overall I'm happy with everything.
  13. May 15, 2015 at 12:21 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Huge fan of that lift, that color, and your name. You must be a great dude.
  14. May 18, 2015 at 7:14 AM
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    hows it ride compared to stock for you?
  15. May 18, 2015 at 1:38 PM
    cacarter
    Maine
    I love the ride. I find it to be much better than stock.
