Any reason not to switch to 0w-20?
Discussion in '4 Cylinder' started by The Shape, Apr 26, 2014.
  1. Apr 26, 2014 at 8:21 AM
    The Shape
    The Shape [OP] Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    My '09 has 43000 on it and I have alwyas used Mobile 1 5W-20 every 5K miles since new, however my wifes Camry calls for 0W-20 and since my truck holds 5.5 qts and her car holds about 4.5qts it would be more convenient when stocking up on oil and using up 1/2 quarts ect. We see low 0's in the winder and temps in the high 90's generealy in summer
  2. Apr 26, 2014 at 9:32 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    My 2011 calls for 0w-20 exclusively. I don't think it would be a problem changing it over.
  3. Apr 26, 2014 at 9:36 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    As long as you keep the second number the same it will be fine. 0w gives better cold start protection
  4. Apr 28, 2014 at 6:55 PM
    single cab
    single cab Well-Known Member
    upstate ny
    2012 Single cab 4x4 mt
    my 2012 calls for 0w 20
  5. May 17, 2014 at 11:53 AM
    scrappletaco
    scrappletaco Damn Deer and Idoit Drivers
    Josh
    Williamsport PA
    2011 reg cab 4x4, Debadged and dirty
    Debadged, Removed Charcoal filter
    My 2011 said you can use 5w-20 if 0w-20 wasn't availible so I just use 5w-20 since its cheaper and really haven't noticed a difference since my 09 ran the 5w
    Ymmv
  6. May 17, 2014 at 12:26 PM
    smmarine
    Melbourne FL
    0w-20 will give you better cold flow. Most engine wear occurs at startup
