Any reason to avoid 2016 Tacomas?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wackyhacky, Feb 6, 2020.
  1. Feb 6, 2020 at 9:08 AM
    #41
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    The are the same for me '16 SR5er
  2. Feb 6, 2020 at 9:10 AM
    #42
    huckfin
    huckfin Well-Known Member
    i had a 2016, and now have a 2020. the transmission in the 2020 feels better and shifts smoother than it did in my 2016. other than that, it feels the same.
  3. Feb 6, 2020 at 9:11 AM
    #43
    Wackyhacky
    Wackyhacky [OP] A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Appreciate all the input folks! Thank you all. I will fill him in.
  4. Feb 6, 2020 at 9:13 AM
    #44
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Yup!
  5. Feb 6, 2020 at 9:15 AM
    #45
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    My uncle is the type of person who gets a new vehicle every few years; I'm tempted to buy it from him!
  6. Feb 6, 2020 at 9:19 AM
    #46
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    If you dont have push button start then the ignition/door/tailgate are the same. On the push start trucks the key blade in the fob only works the emergency key hole under the door handle cap, it will not fit the tailgate. There is a seperate key in the center console lid for the tailgate.
    Im at 50k miles on my 2016. I had two transmission TSB's and it came "no more than a quart low" of fluid from the factory per my purchasing dealer. It was topped up at 2600 miles and I havent had a shifting issue since. My a/c blower motor went out at 4200 miles and melted the blower motor controller in the process. Warranty replaced both, then it was recalled last year and replaced again for the recall. Other than that my truck has been flawless. The battery finally took a dive on me last year. 3-4 years in Texas is pretty average battery life.
  7. Feb 6, 2020 at 9:21 AM
    #47
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The 4x2 would be the only bad part.
  8. Feb 6, 2020 at 9:23 AM
    #48
    PennSilverTaco
    Charlie
    I've been driving a 4x2 for the last decade with no noteworthy issues!
    shakerhood[QUOTED] likes this.
  9. Feb 6, 2020 at 9:25 AM
    #49
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    My 11/15 Texas built 2016 has about 50k miles and not one problem, in fact the truck is barely broken in at this point.
    No leaking, weeping, howling, rattles, shudder or shakes, still on the original battery and windshield, paint not fading or peeling, AC works great, head unit never cuts out.
    Tell your buddy to take it on a nice long test drive and if he likes the way it rides, go for it.
    Mikeincal, Bleep100 and shakerhood like this.
  10. Feb 6, 2020 at 9:39 AM
    #50
    Sclarpepplar
    Sclarpepplar Your raptor lights look like braces.
    Corey
    2016 TRD sport
    BFG KO2's Fuel rims SPC uca's Arb OME lift Arb on board air Prinsu designs roof rack
    Sunroof and blindspot monitoring if I remember correctly.
  11. Feb 7, 2020 at 4:51 AM
    #51
    Charlyc
    Charlyc Well-Known Member
    Jarrettsville, MD
    2023 Winter Chill Pearl Tacoma Limited
    I just bough last August a 2016 with 19K miles I don't regret it. It was flawless. Transmission has no issues great ride.
  12. Feb 7, 2020 at 5:41 AM
    #52
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    The automatics are keyless entry/start but a dedicated key for the tailgate. The manuals had a keyed ignition that works in the tailgate.
  13. Feb 7, 2020 at 5:49 AM
    #53
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    2016 was a total redesign, but based off the same frame... the body is entirely different, bed is different, interior is different, engine and trans are different.. I bought a 2016 TRD OR DCSB.. only had a few issues that were taken care of... howling fromt he lower control arms (dealer installed caps on the drain holes, I plan to install some LCA skids to comletely eliminate this.. the Trans TSB re-programming was done, and reduced the shifting/hunting. and this last summer, i noticed a metallic like high pitched scraping noise consistant with RPM's, and only happened when the engine was hot.. was proven to be my HPFP (high pressure fuel pump) on the passenger valve cover towards the rear. it was replaced under warranty and is a known TSB. other than that no issues.. truck runs great, gets into the 18mpg range with 32" tires/heavier rims, and a decent load of gear on it...
  14. Feb 7, 2020 at 6:12 AM
    #54
    Rapidfire1
    Rapidfire1 Well-Known Member
    Shaun
    York Pa
    2016 Black TRD Sport DCSB MT
    Same here, 94k and original battery and no significant issues.
  15. Feb 7, 2020 at 6:43 AM
    #55
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Not a refresh at all. Body, trans, interior, engine, etc... are all different from the previous Gen.
  16. Feb 7, 2020 at 7:57 AM
    #56
    shakerhood
    Southern Ohio
    The cab is actually exactly same as the 2nd Gen except the addition of high strength steel.
    BlkTaco47[QUOTED] and boynoyce like this.
  17. Feb 7, 2020 at 9:25 AM
    #57
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    A little more than a refresh, as a brand new 3.5 V6 motor was included.
    Myself I'm happy my '17 doesn't have all that safety crap on it that the newer Taco's have. Do it, do it!
  18. Feb 7, 2020 at 9:29 AM
    #58
    Charlyc
    Jarrettsville, MD
    Same here less to go wrong.
  19. Feb 7, 2020 at 9:32 AM
    #59
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    My '16 uses the same key in the tailgate
  20. Feb 7, 2020 at 9:51 AM
    #60
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    As was stated above this is a push to start truck problem.
