Any reason to avoid higher mileage Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robe30, Apr 15, 2024.
  1. Apr 15, 2024 at 6:09 AM
    Robe30
    Robe30 [OP] Active Member
    Pennsylvania
    Lunar Rock 23 DCSB, 1994 Landcruiser
    I've been going back and forth for the better part of 3 weeks now. I'm looking for a rust free double cab Tacoma that's manual transmission. Ive found a few in my area and due to hidden/covered up rust areas and a possible cracked frame, I've narrowed it down to a 2010 with 150k and a 2023 with 12k.
    Car payment is a huge deciding factor here, I would much prefer to NOT have a heavy car payment for quite a few years BUT the idea of having things covered until 100k is appealing but in theory, a Toyota should hit at least 100k before needing work so I'd be on my own after that point anyway.
    My wife and I are expecting our second child in September and ideally, she would like to go part time instead of working full time and paying a stranger to care for our child.
    This brings me to the point of my post, the 2010 has 150k on it, unknown service hx but started up with no issue after sitting a dealer lot for 2 months, has no rust, runs and drives well (reminded me of my 1991 x-tra cab but actually had enough power to merge onto the highway) and is in overall nice shape. The engine is quiet, no leaks that I saw, clutch is strong, shifted into 4x4 hi/lo without issue, cold AC and hot heat. It needs a new passenger front wheel bearing, accessory belt and pulleys, new headlights/fogs and an updated radio. A friend of mine is a Toyota Technician, does work at home and offered to do the wheel bearing for a significantly reduced price. The 10 put a smile on my face similar to the first time I drove my 94 Landcruiser.
    My plan for the 10 if I get it would be fix the known issues, fresh fluids all around, grease the u-joints, fill the gas tank and drive it.
    I'm not afraid of doing vehicle maintenance but would prefer spending time with my family going places and not sitting in the garage chasing yet another damn problem. For the record, I currently drive a 2017 BMW 328 diesel wagon that is a fantastic vehicle but very high maintenance and I am done with that crap.
    Thanks for reading my novel and I await your responses.
    TacoTuesday2165 likes this.
  2. Apr 15, 2024 at 7:05 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Sounds like you have a handle on it and know what to look for, I’d get the 10 replace what’s need and keep up with maintenance. Don’t let the miles worry you.
  3. Apr 15, 2024 at 7:11 AM
    Jasskillman
    Jasskillman Well-Known Member
    SoCal
    2013 DCSB
    I agree I would get the 10 based on your willingness and access to help if you do need to fix anything.
    Robe30[OP] and a400ryan like this.
  4. Apr 15, 2024 at 7:11 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    get a toyota or honda mini van . Its a no brainer
    WilliamJames, Ricardo13x and a400ryan like this.
  5. Apr 15, 2024 at 7:15 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    150k is high mileage?
    I haven't had to do any major maintenance on my 2010. Wheel bearings, alternator, starter, oil, and brakes. It just keeps going.
    Go for it!
    WilliamJames likes this.
  6. Apr 15, 2024 at 9:17 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    You found the 2010 traded in at a Toyota dealership? So they probably traded it in for another Toyota... because they had good luck with the Taco they traded in.
    I'd be more inclined to buy a used Taco than a new Beemer...
    Shotgun Clay likes this.
  7. Apr 15, 2024 at 9:18 AM
    TacoTuesday1
    SD CA
    Inspect the truck.
    I’ve never had a CEL. It’s DIYable. And not German. That’s the point.
    Some German cars are reliable. Most are not. They usually don’t have capability.
    lots to choose from.
    10k mi/yr is probably average statistic.
    having a warranty for 100k doesn’t mean anything if it means getting a newer worse vehicle that will break in and outside of that warranty rather than one that doesn’t.
    Most 2nd gen’s probably only ever been to a dealer once for free leaf recall before putting a pack on it. 100k isn’t a window where things break on a reliable vehicle.
    you’d have a tough time getting mine from me regardless of miles. Wheel bearings pulleys sounds normal on any vehicle.
    check out B8 A4 2.0t
    Award winning engine
    For worst motor ever made
    Lmk how you like any kind of warranty on that
    be advised. Opie engineered TOB on RA60F.
    661 likes this.
  8. Apr 15, 2024 at 9:24 AM
    661 Well-Known Member
    SoCal
    10k mi/yr is decent. Vehicles hate sitting.
  9. Apr 15, 2024 at 9:36 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    This is the only thing that caught my attention "started up with no issue after sitting a dealer lot for 2 months" -- these seem so hard to find. it seems odd it would be sitting at the dealer lot for 2 months (unless somewthing is wrong). Like others note, I would go for it if the price is reasonable. As part of your final check, I'd see if your toyota tech buddy could give it a once over.
  10. Apr 15, 2024 at 9:36 AM
    TacoTuesday2165
    TacoTuesday2165 Active Member
    David
    05 TRD Sport DCSB What, Me Worry?
    Go ahead & get the Tacoma! The key word here is 'rust', and if it passes this criteria, you're good to go. As for the BMW, I also own a ///M car, and in case you didn't know, FCPEuro is your friend! Everything you buy from them comes with a lifetime replacement guaranty, INCLUDING oil changes! Just ship the old oil and filter back to get full credit. However, they don't sell tires yet. So don't give up on the beamer.
  11. Apr 15, 2024 at 9:50 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    Go for the 2023 . Lots of parts on any 2010 vehicle just go downhill.
  12. Apr 15, 2024 at 10:09 AM
    TacoTuesday1
    SD CA
    so instead of a 2010 than has gone up and down many hills without a CEL
    Spend more on a turd gen where motor broke going on a hill and engine chokes itself on oil
    Yes.
    pre 2010 means it’s in the shop for an oil change can’t find anything wrong with it refuses to die.
    Pre 2010 means a whopping 3 computers without windshield camera forced down your throat
    Pre 2010 is when certain cars lasted and were bulletproof.
    B5 A4. B6 A4. B7 A4. MB W210, maybe W211. P71 Crown Vic. Old Toyotas/Lexus. Old 2500’s. pre 2010.
    But what do I know
    according to a Toyota tech on YouTube 1GRFE is one of if not most reliable Toyota motor ever made. There is only one Tacoma that comes in.
    But what does he know.
    pics or it didn’t happen
    if only FCP, autohausAZ, pelicanparts, europaparts, ECS tuning, etc added the Tacoma…
    maybe it doesn’t break enough for them to sell anything
  13. Apr 15, 2024 at 10:45 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Agreed w/ 2nd gens better than 3rd gens.
    Pre-2016 (2015 or earlier) checks most of the same boxes as pre-2010, innit? Trusty V6 1GR-FE, no onboard cameras, no anti-collision braking, no expensive radar sensors, etc. 2012+ do have the pesky SAIS pump but that can be worked around.
    Robe30[OP] likes this.
  14. Apr 15, 2024 at 10:54 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    How many more yrs are you looking to get out of a 14 yr old vehicle?
    23MGM and 4x4spiegel like this.
  15. Apr 15, 2024 at 10:58 AM
    Robe30
    Pennsylvania
    It's a small dealer and their price is too high.
    My Landcruiser is 30 and still rolling. If I could get 5-8 out of the Tacoma, which I think is reasonable with maintenance and rust proofing/remediation, I think I'd be happy.
    Travlr likes this.
  16. Apr 15, 2024 at 10:59 AM
    Robe30
    Pennsylvania
    Their price is too high.
  17. Apr 15, 2024 at 11:11 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    What would the cost out the door (not including repairs on the 2010 that you know of at this time) be for either vehicle? That's a huge factor.
    In general my 2010 at just under 140K is solid. I did drop about $4000 into it last year, 50-50 for regular stuff or not so much. Still runs strong, was reframed 3 yrs ago, and still checks off all the boxes for my needs. 4 cylinder, single cab, 2WD.
    I was in a 2022 double cab OffRoad for a week recently while mine was in the body shop. More truck than I'd have need of though it was a nice rig.
    Steves104x4 likes this.
  18. Apr 15, 2024 at 12:36 PM
    GilbertOz
    GilbertOz Driver
    CA
    C'mon, man. It's a 1st or 2nd gen Tacoma. Like an Egyptian pharaoh, you get buried with it if you can afford a big enough tomb.
    My 2014 Taco is now 10 years old, with 78K on the ODO.
    Expected service lifetime is at least another 20 years. Possibly 30.
  19. Apr 15, 2024 at 12:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Where did the frame break?
  20. Apr 15, 2024 at 12:54 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    In areas where rust is an issue it can easily be the years that take more toll than mileage. In those parts of the country actual mileage can be of secondary concern since simple mechanical issues are often made more complex by rusted/frozen fasteners and corrosion is more often than not pervasive. If I lived in the rust belt I’d be very much inclined to look elsewhere for a used ride or look for one of those garaged unicorns that were only driven in summer. If I had to buy local I’d factor in accelerating rust into any longevity estimate.
    Travlr likes this.
