Any reason to turn off BSM?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by One-up, Aug 12, 2020.
  1. Aug 12, 2020 at 2:33 PM
    One-up
    One-up [OP] Member
    2017 DC LB TRD SPORT 2WD
    PRO Grille, Clazzio Seat Covers, Cab Chrome Blackout, Too Much to List
    I'm getting ready to install an anytime camera feature, and I need to free up a spot in the lower switch panel to accommodate the switch.
    I'm thinking of making sure the Blind Spot Monitor switch is on and tucking it into the dash (making it inaccessible). Is there any reason it would need to be turned off?
    For example, I need to turn off the parking assist (rear alert) whenever I have a trailer attached to the truck or it beeps constantly. I just haven't found a case where I need to turn off the BSM.
    enforcertaco91 and drizzoh like this.
  2. Aug 12, 2020 at 2:41 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Well, try it out and see. You're just tucking it away, not cutting anything so if you change your mind, it's easily undone! :thumbsup:
    ORtoCOTaco and Junkhead like this.
  3. Aug 12, 2020 at 2:44 PM
    rtadams89
    rtadams89 Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    I did that 3 months ago. Have never thought about it or had a reason to dig the switch back out since then.
    ORtoCOTaco and One-up[OP] like this.
  4. Aug 12, 2020 at 3:01 PM
    NV_Spencer
    NV_Spencer Well-Known Member
    2020 CREWMAX / 2017 OR DCSB
    I've gotten warnings in my center dash screen before that said my BSM was inactive/not working. Turning it off & then on again would fix it. Weird, stupid thing that I used to see occasionally but probably not in the last year or so.
  5. Aug 12, 2020 at 4:23 PM
    ToyodaTruck
    ToyodaTruck Well-Known Member
    2019 TRD Sport
    Wow. Good to know.
  6. Aug 12, 2020 at 4:30 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Yeah, I'm having issues with the BSM going on/off on it's own......If you can move it to where you can operate it without moving too much, I would. I'm having to turn mine on/off..
    It goes into a beeping mode sometimes.....gotta turn it off.
    Good luck
    One-up[OP] likes this.
  7. Aug 12, 2020 at 4:34 PM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    I've turned mine off before. Got ice and mud stuck that set it off constantly until it got washed on both occasions
    I did the anytime camera mod that ran off double clicking the menu button then is controlled by the arrows on the wheel for the menu
  8. Aug 12, 2020 at 4:35 PM
    ToyodaTruck
    2019 TRD Sport
    Thanks for sharing that with the community. Good to know.
  9. Aug 12, 2020 at 6:01 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Yes, if you have a trailer you need to turn it off, or it’ll constantly beep at you in reverse and sometimes constantly think someone is in your blind spot while driving. (The latter will depend on size / location of trailer).
  10. Jun 23, 2022 at 1:09 PM
    NotAHugger
    NotAHugger New Member
    Western NC
    2022 Tacoma Double Cab TRD OR Barcelona Red
    Has anyone added BSM camera to the passenger side mirror? Did you use a kit? Brand?
  11. Jun 23, 2022 at 1:21 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I can't even spell BSM.
  12. Jun 23, 2022 at 1:40 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Was wanting to do this as well for the same reason and looking for an extension harness to move the BSM switch to the left of the steering wheel. Just makes sense to be closer to the side mirrors IMO. Sent a few messages out to custom guys but so far nothing has panned out. The anytime switch kit wiring really isn't long enough to run to the left of the steering wheel anyway. Was a total bitch to install over there.
    enforcertaco91 likes this.
  13. Jun 26, 2022 at 7:50 AM
    NotAHugger
    Western NC
    Are there any other yodas that have mirror mounted cameras, maybe a 4runner? I was thinking of using the input on the jbl unit for the front camera since i have no front camera, use the input for adding a bsm cam.
  14. Jun 26, 2022 at 8:20 AM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    On my 2017 Tacoma I kept BSM off after about 3 years because it stopped working and cost more to fix than I thought the feature was worth.
  15. Jun 26, 2022 at 8:44 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
