Any Recommendations for Remote Starter for TRD Off Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nellie326, May 5, 2023.
  1. May 5, 2023 at 6:16 AM
    Nellie326
    Nellie326 [OP] Active Member
    Keith
    2023 TRD
    Looking for Recommendation for an Aftermarket Remote Starter for a 2023 Tacoma OFF-Road. This has the push button start. Thanks in advance for any ideas.
  2. May 5, 2023 at 6:34 AM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    It should have remote start as well. I believe you have to press the lock button 2 times and hold down on the third. You will see the lights start blinking then it starts up. That’s how my ‘22 is.
    stftaco likes this.
  3. May 5, 2023 at 6:35 AM
    Nellie326
    Keith
    2023 TRD
    Tried it at dealer yesterday, lights blinked but did not start
  4. May 5, 2023 at 6:40 AM
    TacoTrigger16
    I know it can be sensitive. My likes to work when it wants to. I tried using it this past winter. One morning it would work the next it wouldn’t. I came to believe it is how it was locked the night before. I had to just hit the lock button once and not worry about the second time turning off the lights. I park outside. I will attach a link to the process below.
    https://getjerry.com/driving/how-to...tacoma#how-to-remote-start-your-toyota-tacoma
  5. May 5, 2023 at 9:14 AM
    wj3v
    wj3v Active Member
    2022 TRD Sport
    The doors have to be locked for it to function correctly. If the doors are unlocked, lock them with the remote FOB and wait for about 15 seconds. Then, push the lock button 3 times pausing slightly between presses. On the 3rd press hold the lock button down and wait for the lights to flash 5 times. Release lock button and truck will start.
    stftaco and Vjustinc like this.
  6. May 5, 2023 at 9:19 AM
    Claupp
    Claupp Member
    Christopher
    St. Louis MO
    2001 Pre-runner
    stock
    My 19 is hit the lock button 4 times and on the 4th hold it for a while.
  7. May 5, 2023 at 9:22 AM
    wj3v
    wj3v Active Member
    2022 TRD Sport
    The 19 didn't have a factory installed remote start.
  8. May 5, 2023 at 9:25 AM
    Claupp
    Claupp Member
    Christopher
    St. Louis MO
    2001 Pre-runner
    stock
    19 TRD Pro did apparently
  9. May 5, 2023 at 3:06 PM
    Nellie326
    Keith
    2023 TRD
    Thank you for all the idea
    TacoTrigger16 likes this.
  10. May 5, 2023 at 4:10 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    It's aftermarket. Remote start wasn't available on any model in 19.
    OP I have the N2 Designs and it's been great for the last 4 or so years. It's the most recommended here.
    MadKatt likes this.
  11. May 5, 2023 at 6:39 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Yep, and your range goes from 50’ to worldwide with the cell package.
  12. May 5, 2023 at 6:47 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    +1 for N2 4 years going strong
  13. May 5, 2023 at 10:09 PM
    raveseer
    raveseer Member
    2022 Army Green TRD Off Road
    I have a 2022. You have to activate the Toyota connected services app. Once you activate then the remote start will work. I resisted activation of the app, until I learned it locked this feature. I tested this with my dealer. From other threads I’ve seen, after the app trial expires, you can still use the triple tap to remote start on the key fob. Good luck.
    stftaco and Kolohe07 like this.
  14. May 6, 2023 at 6:24 AM
    Nellie326
    Keith
    2023 TRD
    Thank you
  15. May 6, 2023 at 8:01 AM
    Herennow
    Herennow Well-Known Member
    2023 Lunar Rock Tacoma TRD 4X4 Sport V6
    Les Schwab Open Range A/T- Peragon LimitedHD Tonneau Cover- Teton Workshop Shift Knob - Vtails Taillight Conversion kit - Cali Raised LED's Catalytic Converter Shields- Rough Country bed mat- 9 piece LED interior light kit - HIGH FLYING Led Side Mirrors Sequential Dynamic Turn Signal Lights Indicator. -Diode Dynamics Elite Series Fog Lamps.
    I hope you find something. I want to do something to fix mine. 23 Trd sport.
    Has remote start. But when you get in the
    Truck shuts off. Security feature that's annoying!
  16. May 6, 2023 at 2:57 PM
    Nellie326
    Keith
    2023 TRD
    My sister in laws Acura does the same thing. I just want get mine to work 2023 TRD off road
  17. May 6, 2023 at 3:55 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I think it will only run for about ten minutes as well
  18. May 6, 2023 at 5:46 PM
    Nellie326
    Keith
    2023 TRD
    That’s what I heard, and also shuts when the door is open
  19. May 6, 2023 at 6:05 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    FYI, no way around it shutting down when door opens. Factory or aftermarket. Been discussed many times.
  20. May 6, 2023 at 6:10 PM
    Vjustinc
    Vjustinc Talk Nerdy to Me
    City of Angels CA
    2021 Toyota Tacoma (it's white)
    I've found that this way makes mine start more successfully than just pressing it twice really fast then holding down on the third.
    I want to add that I didnt do any of the having to activate the Toyota services app.
