Any Recommendations on Slotted Rotors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shanekss415, Apr 8, 2017.
  1. Apr 8, 2017 at 2:53 PM
    shanekss415
    shanekss415 [OP] Well-Known Member
    Kevin
    San Francisco
    2018 TRD Off-Road DCLB
    Bestop supertop, RCI Transfer Case and Transmission Skids, SCS Ray10's
    I have a 2015 Prerunner (2wd) and looking into replacing the original rotors and was wondering if anyone has any opinion on some slotted rotors. I was looking at the EBC Ultimax Slotted rotors but just would like to possibly get any feed back and opinions. I don't really use the truck off road or anything mainly street, highway and some towing (usually not too heavy but sometimes on occasion).
    Thanks!
  2. Apr 8, 2017 at 3:03 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I don't think most people recommend them on a daily driver. I think your money would be better spent on a quality set of rotors and pads, maybe some stainless lines?
  3. Apr 8, 2017 at 3:35 PM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
  4. Apr 8, 2017 at 3:38 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
  5. Apr 8, 2017 at 3:40 PM
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
  6. Apr 8, 2017 at 3:51 PM
    schleygo
    Daniel
    Ft Worth TX
    Any dislikes? Gripes? Complaints?
    I am literally a click away from ordering this.
  7. Apr 8, 2017 at 3:53 PM
    Tacotruck422
    Tacotruck422 Well-Known Member
    Seattle, Wa
    2015 DCLB
    Pro wheels, bilstein 5100's, 265/70/17 ko2's
    13wh calipers, 338mm rotors, with steel lines:benchpress:
    Justinlhc likes this.
  8. Apr 8, 2017 at 4:05 PM
    Justinlhc
    That would be better than any slotted rotor you can find on eBay :drevil:
  9. Apr 8, 2017 at 4:33 PM
    CO Ryan
    Colorado
    13 TRD Offroad
    stuff
    Nope they've been great... only been on for a little over a month and have not done any off roading. No complaints so far.
  10. Apr 8, 2017 at 4:42 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I've had those for a year now. No problems at all. Made it on a cross country road trip fully loaded. Never overheated (although stock did very well also).
  11. Apr 9, 2017 at 10:17 AM
    shanekss415
    Kevin
    San Francisco
    Well I do have some new better pads but starting to get a little warp in the stock rotors. Planning to do the whole job at once or if I should just turn the rotors and put them back on (I have my own brake lathes).
  12. Apr 9, 2017 at 10:27 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    EBC and Hawk racing both have good rotors. You want just slotted, not slotted and drilled.
    Get some good ceramic pads, stainless lines, and then fully flush and bleed your system with good brake fluid. Should be good to go after that.
    boogie3478 likes this.
  13. Apr 9, 2017 at 3:54 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    DBA USA.
  14. Apr 9, 2017 at 3:55 PM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    Honestly if you've got under 80-100 k just keep the factory ones... if not stoptech makes a good set
  15. Apr 9, 2017 at 3:58 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    There is really no reason for your truck to have slotted rotors
  16. Apr 9, 2017 at 4:03 PM
    Justinlhc
    Gotta keep them pads fresh for stopping at the mall :burnrubber:
    jgantzler, BassAckwards and igno1tus like this.
  17. Apr 9, 2017 at 4:31 PM
    Texasarmor
    Texasarmor Member
    Lt. Dan
    2013 double cab long bed 4.0
    Stock
    Imagine the surface of the rotor being the same thickness when its cast.... now imagine it warping still the same thickness as when it was cast....you put it on the lathe and cut off the high spots which thin out the rotor in that area right?? So now you don't have the same thickness on the surface of the rotor....does it dissipate the heat the same as the rest of the rotor?? It can not, it is doomed to warp again! Now I'm talking noticeable warpage not slight . all rotors will have some run out on the lathe but if you can feel it when applying the brakes...don't waste your time or money just get new ones it took me 20 years to figure that out as a mechanic....:p
    BassAckwards likes this.
  18. Apr 9, 2017 at 5:01 PM
    CO Ryan
    Colorado
    13 TRD Offroad
    stuff
    My stock rotors were warped when I bought the truck @ 30k. I am glad to be rid of them and will never use stockers on this truck again.
  19. Apr 9, 2017 at 11:30 PM
    09BlueBeast
    Cody
    Denver
    I put 128k on mine with no issues and drive the piss out of my truck
  20. Apr 10, 2017 at 12:28 AM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Slots looks cool but they do not improve braking distance, There is a benefit to them but you won't ever see it unless your taking the truck out on the track to do some racing. Slots also increase pad wear and that's one of the reason I go against it considering I usually buy expensive brake pads; Hawks, EBC, ect.
    I suggest if your going slots; use the Powerslot slotted rotors; Good brand and great wear performance or StopTech slotted rotors. I don't like EBC rotors simply because most of them if not all of them come slotted and drilled. I highly suggest avoiding drilled rotors just because of stress cracks that can occur(although highly unlikely; I wouldn't want to deal with it)
    I recommend Stop Tech Cryo treated blank rotors with some Hawk LTS brake pads; I run this and tremendous increase in braking power; no more fading with heavy towing on downhills or stop and go traffic.
    zerotimeouts likes this.
