Any Recommendations on Slotted Rotors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shanekss415, Apr 8, 2017.
  1. Apr 10, 2019 at 5:29 PM
    #81
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    You need a set of brake line wrenches. They have 5 sides instead of 3. Other than that spray PB blaster if you have to and let them soak, but they're gonna be tight because they're brake lines. Keep that in mind when reassembling :thumbsup:
  2. Apr 10, 2019 at 5:53 PM
    #82
    lynyrd3
    Bill
    East Central Upstate NY
    I have a set of Power Stop drilled and slotted rotors with whatever the pads that came with them are . At least 5 years now . No problem. Just make sure you break them in per the instructions! I also have SS extended brake lines .
  3. Feb 28, 2020 at 3:02 AM
    #83
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Do a brake system flush/refill. Moisture (water) gets into the brake system when it's opened, can't be stopped. Speeds up rusting caliper pistons and journals. The master is see-through, so you can check the level without opening it, for this very reason.
  4. Feb 28, 2020 at 5:05 AM
    #84
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    New factory rotors are the best.
