Any risks with 3rd party tune?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by buckjay, Sep 27, 2022.
  1. Sep 27, 2022 at 12:44 PM
    buckjay
    buckjay [OP] Member
    I recently traded in my 2019 Honda Accord 2.0 MT for a 2022 Tacoma. Absolutely love the truck but the gear hunting and acceleration is rough. From everything I've read, these aftermarket tunes can really help with those issues.
    My question is, is there any risks or trade offs associated with getting a tune? This is going to be a daily driver but I also plan to take it offroad on the weekends. Right now I'm at about 300 miles on it, is there any reason to wait until I've broken in the motor? (Is that a thing still?).
    Any insight would be appreciated! Thanks!
  2. Sep 27, 2022 at 1:36 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I can't speak to the risks or tradeoffs.
    I bought my '21 TRD OR AC knowing that there were major differences between the 3.5V6 with AT vs my '06 TRD OR AC 4.0V6 with MT. As @oogielaflick explains, it's a "learning" transmission. Combined with the 3.5V6 and it's narrow power band (at higher revs), my new Taco is vastly different. That said, I've adjusted to it, and it's adjusted to my driving habits. Over time I've accepted the difference and am happy with the truck.
    Adjust your expectations and give it some time - you may find that it'll get less annoying.
    stftaco and Silentshredr like this.
  3. Sep 27, 2022 at 1:53 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Yes, break-in IS a thing, still. Check your manual on that subject but as mentioned above, get a couple-a-few thousand on her before tweaking on the ECM. It WILL get better over time but still may not be to your liking and if that's the case, the tune is always an option. The only drawback I have seen is the scary part of tune transaction where the tuner has you sign a document indemnifying themselves from "bricking" your entire ECM and rendering your brand new truck a 5000 lb shitbox! o_O
    I plan on a tune very soon even though I'm somewhat okay with the 11.5k miles I've put on the truck since new last year. I'm doing it because I've started towing and think it will be significant improvement of the truck. We'll see!
    Briavael likes this.
  4. Sep 27, 2022 at 2:18 PM
    CT Yankee
    CT
    I tow a trailer with my Kubota BX on it (about 3500 lbs total) and my Taco does just fine. ECT + S4 on the upgrades and S5 on the flats. But it's not a regular thing, i.e. to the Kubota dealer & back.
  5. Sep 27, 2022 at 2:57 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Just from an design engineering perspective, there is always a risk when you change something from how it was originally designed to operate to something else. Tune proponents will argue otherwise but they just can't say this is a 100% risk free proposition because it is not. Having said all that, maybe the risk is low but I really don't know.
    Tuners also claim that a tune will not affect your factory warranty coverage as they claim it is undetectable by the dealer but I am not so sure I believe that. You start mucking around with code and it leaves a digital trail, thats a fact! Maybe dealerships cannot see the code change marker right now but I bet they will be able to soon enough. I heard some states are even passing laws making these tunes an automatic emissions tests failure criteria so they must be able to see them, right?
    Don't get me wrong, not bashing the black market tune industry here. Just pointing out that it ain't a risk free thing.
    CGPickup, Borracho Loco and IrishRed like this.
  6. Sep 27, 2022 at 3:59 PM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    Your warranty will be gone if a big enough issue arises where you need it. If you pop a motor, trans, PCM, or basically anything prohibitively expensive Toyota will send a FTS out to the truck and they will 100% be able to sniff out a tune if they want to. Flash counters, flags (such as TD1 in VWs), hashes, etc. You might get lucky and they won’t catch it but why risk it? I’ve owned tons of other cars that were commonly tuned and there are very few people that get major components covered under warranty if they’re tuned.
  7. Sep 27, 2022 at 4:35 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    I'm pulling a travel trailer just under 5k lbs on a kinda-sorta regular basis so I'd like to see if it makes a worthwhile difference as I have been told it would.
  8. Sep 27, 2022 at 5:44 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    I've pulled twice before tuning and 3X since and it most certainly makes a difference. Pulling almost 5K lb on with a Blackhawk tune which I really like out of the 3 or so tunes I've used.
  9. Sep 27, 2022 at 6:01 PM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    Not saying you’re wrong, but very few major components get covered under warranty even without a tune. Dealerships will do anything they can to get out of footing the bill. This is especially true with extended warranties. The fine print leaves you much less covered than you’re led to believe when you purchase the warranty. There are plenty examples of that on this forum alone.
  10. Sep 27, 2022 at 6:03 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Welcome to TW.
    As someone who put 30k miles on the truck before tuning, then another 20k before tuning again, here is my advice.
    A new truck will change behavior at around 1500 miles. I don't know why it takes that long for the ECU to adapt to your habits, but it will.
    I highly recommend waiting until then at a minimum. Preferably, wait until the first 5000 miles. Then go talk to a local tuner or two.
    The tuning world has changed wildly within the last year. There are three (that I know of) popular files that are floating around. On top of that there are a few tuners that are writing and installing their own homebrew. Each flavor is slightly different. Everyone has their own solution to balancing a sporty ride against mileage, throttle response against transmission logic.
    Meet and talk to a couple tuners, let them describe what makes theirs unique. Decide for yourself if the cost is worth it.
    My honest review, I liked my truck before the tune, I liked it a little more after getting a tweaked version of the now obsolete m+w tune. Now I'm on a homebrew made by a local guy, and I love it. It was worth it for me, but not because I hated the truck before. It's just more fun now.
    usmc2msu, Junkhead, stftaco and 4 others like this.
  11. Sep 27, 2022 at 6:08 PM
    Tacospike
    Two Trucks
    Now that’s an honest review
    Junkhead, stftaco and Rock Lobster like this.
  12. Sep 27, 2022 at 6:17 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Great advice @Rock Lobster
    I had my truck over a year before I did the OTT 7.0 Tune in May 2022. Then another update the first week of June.
    Most recently was the OTT 8.0 Tune with Gear Lock on Sept 18 which I'm still testing out the functionality and getting familiar with it. (I went from Med/Mild to Lite/Mild)
    My Sport has better acceleration/torque and goes through the gears more efficiently than before.
    I've been very fortunate/successful with all my upgrades to my Sport as well as the OTT Tune.
    I can't thank Allan enough for explaining my Tune and helping me find the best option for my style of driving.
    Rock Lobster likes this.
  13. Sep 27, 2022 at 6:57 PM
    buckjay
    buckjay [OP] Member
    Appreciate all the responses guys.. I think waiting a couple thousand miles is a terrific idea and I will do that.
    Regarding break in - how hard of a science is it? I'm kinda worried because I had to floor it to merge into traffic a few times and RPMs did def get pretty high. Obviously not ideal but shouldn't be a problem right?
  14. Sep 27, 2022 at 7:04 PM
    Buck Henry
    Just drive the fucking thing like a normal human and you will be fine! You just don't want to go out right away to drag race with your buddy's minivan and / or take a lengthy long 80mph without ever changing speed road trips either.
    Carry on!
    Pibbles99 and stftaco like this.
  15. Sep 27, 2022 at 7:09 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Avoid towing for 500 miles. Technically you aren't supposed to redline it for the first 1000. Don't worry about it too much if you briefly violate either.
  16. Sep 27, 2022 at 9:00 PM
    kona61
    J
    RCI Skids
    If you keep on maintenance and have evidence of doing such, I’ve personally heard of no reasonable instances where motor work or transmission work were denied under a factory warranty. Extended warranties are basically useless if it’s through any third party provider.
  17. Sep 28, 2022 at 6:07 AM
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    You haven’t paid attention then. I’ve come across several stories, some of which the problems were actually caused by the dealer service dept. and they tried to get out of paying. And extended warranties are basically useless even from the dealer. Just search around on this forum and you’ll be convinced of that.
  18. Sep 28, 2022 at 10:30 AM
    PiñonTaco
    PiñonTaco Well-Known Member
    2020 TRD OR DCLB
    “Just search around on this forum and you’ll be convinced of that.”
    LOL. Search around on this forum and you could convince yourself of anything…
    Pibbles99, Tony21 and Jofenech like this.
  19. Sep 28, 2022 at 10:53 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Well said.
    Im in the same boat, I liked my truck on stock tune, but now running 94E0 SFOB tune and it’s sooo much more fun to drive. Really wakes up this awesome 2GR.
    Rock Lobster[QUOTED] likes this.
  20. Sep 28, 2022 at 11:37 AM
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    Haha! I will not argue that! This place has convinced me I’ve needed all sorts of things.
