Any Roofers on here? Chime in please
Discussion in 'Garage / Workshop' started by toyotatacomaTRD, Apr 14, 2016.
  1. Apr 14, 2016 at 8:52 AM
    toyotatacomaTRD
    toyotatacomaTRD [OP] Senior Member
    Roofing a shed we just built. Got lazy with the nailer and shot a nail right through the good roofing where it doesn't need nails. Whats the protocol? Leave the nail? Remove it and put silicone? Or tear off the layers and replace that shingle? I appreciate the help in advance.
  2. Apr 16, 2016 at 8:21 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Pull the nail and place a square of alum. flashing under the shingle's hole.
    .... Or just replace that one shingle..... you don't need to remove all the layers above it, use a flat bar to do it. How many are like that? Got pics?
    Don't put silicone,.... that's half-assed, it wont last long.
  3. Apr 16, 2016 at 8:29 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Weird. My house is getting roofed as we speak. I had to leave. Sounded like they were hitting it with a 5lb sledge.
  4. Apr 16, 2016 at 8:31 AM
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    Pull the shingle and nails and replace both.
  5. Apr 16, 2016 at 8:36 AM
    Matic
    Tricky Dick
    Easley, SC
    So not having much knowledge in this, what exactly happened..? you missed a stud or rafter whatever and went in on just the plywood?
  6. Apr 16, 2016 at 8:42 AM
    JoeySauce
    JoeySauce Well-Known Member
    Joe
    Eagle PA
    11 DCSB
    pretty much this.....you can easily replace just one shingle, just takes a little finesse with a bar
    File IFR[QUOTED] likes this.
  7. Apr 16, 2016 at 5:08 PM
    toyotatacomaTRD
    Roofing Nailers shoot full auto. So, if you set the nailer down and have your finger on the trigger a nail shoots. Not like a framing nailer that requires you to pull the trigger each time. Laid the nailer on the finished part of the roof and shot a nail into it. Eventually water will get onto the sheathing then rot. Just wondering the best way to repair before it becomes an issue.
    Matic[QUOTED] likes this.
  8. Apr 16, 2016 at 5:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  9. Apr 16, 2016 at 5:11 PM
    OZ-T
    Peter North
    British Columbia
    Most framing nailers are "full auto" too unless you switch out the trigger mechanism for the safety one
  10. Apr 17, 2016 at 1:04 PM
    Southerner
    Southerner Well-Known Member
    S
    The great state of TN
    2015 Grey Tacoma Access cab
    I am a roofing inspector contractor for the major insurance companies in the area. Personally I would replace the shingle. Even small things like a misplaced nail makes me question. The installation of the roof. Caulking dryrots and cracks and then leaks. I have seen peoples living room ceilings nearly cave in because of a leaking nail that was under a shingle so if its ontop...
    Here is how to do it: with a flat tool, a painters spatula will work, debond the tar strip at the bottom edge of the shingle and the 2 shingles directly above them and the 4 shingles directly above those 2. Remove the offending shingle by pulling the nails while holding up the other ones you debonded and carefully replace it. Then take a caulk gun and caulk the debonded shingles back down where the caulk will not be visible. And you are done!
