Any shops doing OvTune flashes in Norcal?
Discussion in 'Northern California' started by Hooper89, Nov 6, 2020.
  1. May 2, 2021 at 10:00 AM
    #121
    hotrodder636
    hotrodder636 Well-Known Member
    2020 Tacoma TRD Pro (MGM)
    Are you the creator of CVC tune (guessing based on your name here)?
    I am looking into a tune for my 2020 TRD Pro and was looking hard at the KDMAX but a local guy is trying to sell me on the CVC. Learn me please! Does the CVC take care of the gear hunting and improve throttle response like KD?
  2. May 2, 2021 at 11:06 AM
    #122
    PacRat4x
    PacRat4x New Member
    Sam
    Belmont, CA
    2016 TRD OR DCLB
    OME 887 with Bilstein 5100 Ridge Grapplers on Method 701's
    @chanvchau , looking for a tune PM sent. Are you able to bump up the alternator for an AGM battery also?
    chanvchau likes this.
  3. May 3, 2021 at 10:53 AM
    #123
    PipsTaco
    PipsTaco Well-Known Member
    Jarrod
    Central Valley, Ca
    2020 TRD Off Road
    Chan did the CVC Tune on my truck a little over a week ago. I have put about 100 miles on since then (2020 TRD Off road). I am very pleased with it and the gear hunting issue was my biggest complaint pre-tune. MUCH better now. Throttle response is also much better, the more I have driven it the more I like it. Even my wife commented on how much smoother it seems.
  4. May 3, 2021 at 7:34 PM
    #124
    chanvchau
    chanvchau CVC Tuning LLC
    Chan
    San Jose
    2020 Tacoma TRD OR
    CVC Tuned 315/70/17 Falken Wildpeaks AT3 KING 2.5 w/ Adjustable Deaver Stage II Leafpacks Summit Off Road Dakars Fenders Cut by @milogenfabrications Baja S2 Pro custom fitted into OEM TRD PRO Rigid bezels Baja S2 Sport Ditch Lights Rigid Hitch Swingout Prinsu Roof Rack w/ Uptop Overland AAP Uptop Overland Mid Size Bed Rack Thule Tepui Ruggedized RTT Tepui Matching Awning
    Shoot me a DM! You can also DM me on IG @chanvchau and on Facebook!
  5. May 3, 2021 at 7:35 PM
    #125
    chanvchau
    Chan
    San Jose
    2020 Tacoma TRD OR
    Replied! Yes, I can definitely tune alternator output for AGM Batteries!
    CAtacoWaves likes this.
  6. May 3, 2021 at 7:35 PM
    #126
    chanvchau
    Chan
    San Jose
    2020 Tacoma TRD OR
    Replied!
  7. May 3, 2021 at 7:45 PM
    #127
    chanvchau
    Chan
    San Jose
    2020 Tacoma TRD OR
    I got the honor of testing out the KD Max tune, along with some of our testers also testing out KD Max tune AND CVC Tunes. I will tell you this brother:
    IF YOURE IN NORCAL, GET THE CVC.
    Aside from the tune, I'm local and offer local support.
    Regarding the tunes, my CVC Tune is based on NORCAL terrain and my personal driving experience. It shifts the way I felt was appropriate, it puts down power where i want it to, you're not just getting local support, you're getting a local tune, tailored for the environment around you.
    I tested the KDMax tune and its a great tune. However neither tune will completely remove gear hunting. on the freeways, yes, but on the mountain, both still hunt a bit. My tune holds gears a bit longer (intended to do this) than the KDMax. KD Max will shift into 6th a bit earlier, which is more efficient on FLAT highways. As far as power, they are VERY similar in power, whats different is where the power is delivered. I Personally like my tune more, but I am biased. I created it based on my own driving in NorCal and for those around here. I also have guys who test out my tunes and share feedback to improve it. It not just me!
  8. May 4, 2021 at 3:51 AM
    #128
    hotrodder636
    Thank you for sharing. I am in East Tennessee and we have quite a few hills/mountains. I have heard that KDMAX has a “dead spot” on the throttle at the start whereas the CVC does not?
    I guess what I am looking for is smooth, consistent throttle response/delivery and improved (I understand likely nothing will be perfect) shift points. What I have found from reading reviews is that OVT is not the tune I desire, but rather KD or [now] CVC. Thank you!
  9. May 4, 2021 at 12:54 PM
    #129
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    hello- must have missed your reply :confused:
  10. May 5, 2021 at 7:21 AM
    #130
    CAtacoWaves
    CAtacoWaves Active Member
    2019 MT DCSB OR
    Rhino Rack Gutter Channels & Rack, Thule Bed Rack (old model mod), Bed Platform,[Switches: Stereo Brightness, NAV Bypass, White Noise Backup Alarm], Interior AC plugs w/400W anytime, Gate King, Bed & Underhood Lights, SPIKER Eng Hood Struts, MICTUNING Tailgate Light Bar, Blinker Genie 2 Mod for side mirrors and side markers. CBI 0deg Rock Rails, Riccochet Al Full Skids, Bed Divider Rear Window Block, Rostra Front Rock Crawl Camera, Rostra Front/Rear Dashcams, [Alarm Upgrades: Glass Break Sensor, and Tilt Sensor, Shock Sensor, Tailgate Sensor with off switches]. Snail Armor Tailgate Insert. Pop&Lock Tailgate Lock. SaBellCo Tailgate Security Lock. Wheeler's OR 1.5" Prog Add-a-leaf with stock Overload spring. TIMBREN Active OR Rear Bump Stops. FOB free key. HitchSafe. TUFFY Lock Boxes in Center Console & Rear Seat. Toyota Wheel and Spare Tire Locks. In progress: Bilstein 5100s & OME 886 coils, Durobumps Front Bumpstops, CBI hidden front hitch, Hitch mounted winch with front and rear wiring, Eco Gapshield, War Fab Inc Sheridan Hitch Skid, Battery Upgrade. Make me stop...
    DM sent, Chan. Looking for AGM battery > alternator output mod, and to see what you have for manual transmission tuning. Thanks
  11. May 5, 2021 at 12:35 PM
    #131
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2019 TRD-OR AC
    CVC tune is amazing, I have almost no complaints about it. I have tried OVtune 2.0 and it's leaps and bounds better. MPGs increased back to what I had before 33's, the power curve is silky smooth, everything is great.
    I only wish there was a "milder" throttle version. If you hit a bump, making your foot tap the throttle, you will launch the truck. It "feels" like you only use the first .5-1" of the accelerator pedal, so it's verrrrrrry touchy at low speeds.
    Otherwise, the best tune I've used to date, by a longshot. I was surprised that I can cruise at 80-85 in traffic again without feeling sluggish, while getting 20+mpg. My speedo is calibrated correctly as well!
    chanvchau and PacRat4x like this.
  12. May 5, 2021 at 12:41 PM
    #132
    CAtacoWaves
    2019 MT DCSB OR
    I didn't know a tune could do all that. Is this with stock gearing?
  13. May 5, 2021 at 12:45 PM
    #133
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    Yeah. I have stock gears, and 33's. Steel bumper/winch etc.
    While trying to get best MPG I was getting 15-18 MPG before, now I get 18-22+.
    Honestly, I was originally skeptical and just went with the base OVtune 2.0, modified for 33's. But it wasn't that big of a difference over stock (with the newest TSBs that honestly copied OVtune). So I talked with Chan and decided to try his CVC tune out.
    Big difference.
    Chan's a nice dude too.
    Still wish it wasn't as touchy, but that's just me being peculiar.
  14. May 5, 2021 at 5:07 PM
    #134
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    Aaaaand taken from my commute through Sacramento on the way home. Mix of 80mph, and a few slowdowns of traffic on the way home.
    AC was on the whole time!
    I could have gotten more MPGs if I had more freeway time.
    Thanks @chanvchau
    chanvchau and PipsTaco like this.
  15. May 6, 2021 at 5:02 AM
    #135
    hotrodder636
    Your described throttle response is why I was looking to the SLT version of KDMAX, to minimize this ‘launch’ effect.
  16. May 13, 2021 at 7:25 AM
    #136
    slvrtaco11
    slvrtaco11 Well-Known Member
    SF bay area
    2018 TRD OFF ROAD AC
    tint, oem bed mat, CVC tune
    Any 3rd Gen trucks that are on the fence teetering about getting your truck tuned by @chanvchau don't hesitate and DO IT. I had it done yesterday. I was going to wait a few days to comment but there was such a noticeable difference.
    My 18 off road was giving me so many issues with gear hunting, weird vibrations between 30 and 40 mph, crazy rpm surges, just about everything that makes these trucks run like crap.
    The tune has fixed/helped just about all of this. Once I stepped on the gas pedal to leave it was instant power from the top of the gas pedal. I am still in the "break in" process and will return to give an update in a few weeks. I cant thank Chan enough! Super knowledgeable guy and will listen to every question you have and address it.
    A couple shout outs to @tacomarin for helping me with my truck a few weeks back. Also to Tony @tonered for helping me choose to do a TSB update and then get the tune.
    chanvchau and tacomarin like this.
  17. May 13, 2021 at 7:27 AM
    #137
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    :cheers:
    chanvchau and slvrtaco11[QUOTED] like this.
  18. May 13, 2021 at 8:59 AM
    #138
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Glad you were able to get that resolved and sorry I wasn't able to get it done for you!
  19. May 13, 2021 at 10:32 AM
    #139
    chanvchau
    Chan
    San Jose
    2020 Tacoma TRD OR
    I can also tone down throttle curves, which I've done for a a handful of people! If anyone needs a toned down version, reach out to me! Free retunes, so wont charge you twice! I dont want anyone worrying about getting something and not knowing what to expect, then having to pay again if they need adjustments! Reach out, I got you.
  20. May 13, 2021 at 10:34 AM
    #140
    chanvchau
    Chan
    San Jose
    2020 Tacoma TRD OR
    Let's link up again, I have a version that will tone down that initial tip in. I had it dialed in when I had smaller tires, I've done it for a few guys and they all said it was perfect for them. As promised, I'll take care of ya!
