Any SockMonkey artists out there?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by floridaoccifer, May 17, 2014.
  1. May 17, 2014 at 5:20 AM
    floridaoccifer
    floridaoccifer [OP] Civil Servant
    So it still kills me that SockMonkey pulled the plug for whatever reason :(
    With that being said, has anyone run across or know anyone producing the same style of bedside decal out there? I am not interested in the multiple layer, vinyl that EVERYONE does but OEM quality, custom stuff.
    Thanks (I kinda miss this place).
  2. May 1, 2015 at 7:32 PM
    shorerider
    shorerider New Member
    I'm looking as well! I need stock TRD Sport replacements for my 2010 truck!
  3. May 1, 2015 at 7:39 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
  4. May 1, 2015 at 7:43 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Sock got out of it because he no longer had access to the equipment. There's a few others who have stepped up to the plate since his departure as a vendor. Cboy808 has done some great work for me.
  5. May 1, 2015 at 8:00 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I've held off because he got out. He did some epic work. Long live the Monkey.
