Any solution to not getting shocked after getting out of truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacrazy651, Feb 19, 2023.
  1. Feb 19, 2023 at 10:45 PM
    Tacrazy651
    Tacrazy651 [OP] Member
    2003 Tacoma double cab TRD prerunner
    So I'm fairly certain this happens with other vehicles, especially older models. It seems the only solution I've found so far is to touch the outer metal while stepping out to ground the static. Either that or I'm not looking hard enough for a certain answer to fixing this.
    Would it have anything to do with the wiring within the truck or something? Any fellow Tacoma owners have this same situation? Any input is appreciated!
    ztwatson, MGMDesertTaco and Burro like this.
  2. Feb 19, 2023 at 11:55 PM
    MGMDesertTaco
    Lol, static electricity. I notice it only during monsoon season in AZ with the cloth seats in my Tacoma and sliding across the seat to get out. Put your hand on the glass window and it will "ground" you and prevent a shock.
    Tacrazy651[OP] likes this.
  3. Feb 20, 2023 at 12:09 AM
    Tacrazy651
    Now that I think about it, that makes alot of sense. Moving around with the cloth material could create static charge, I wonder if putting something over the seat could fix this. Imagine the passengers shock when they find out :D
    MGMDesertTaco[QUOTED] likes this.
  4. Feb 20, 2023 at 7:07 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Buy some fabric anti-static spray and use it on your seats and carpet.
    Tacrazy651[OP] and jnossoff like this.
  5. Feb 20, 2023 at 9:26 PM
    Tacrazy651
    cool, I'll definitely try that out.
    So the general consensus on this issue is because the seats are cloth and the type of weather its in? I've always wondered what made old vehicles do that, thinking about it now does make alot of sense with the charge buildup.
  6. Feb 20, 2023 at 9:26 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    THIS! Definitely works.
