Any suggestions for padding a carport support?
Discussion in 'Garage / Workshop' started by JRFry, Dec 6, 2012.
  1. Dec 6, 2012 at 10:41 AM
    JRFry
    JRFry [OP] Well-Known Member
    Central PA
    '13 SR5 4X2 Long Bed
    ARE cap, ProMaxx stainless step bars
    My carport is a tight fit, and I don't always park far enough away from the posts that support the roof. I want to wrap some padding around the posts closest to my car doors so that I won't dent the doors if I open them too far. I was hoping to find something like the tubular insulation that's split lengthwise to fit around plumbing pipes--only bigger. The carport supports are about 3 inches, and they're square. Does anyone know if insulation material comes in bigger sizes? Or pieces/sheets? It doesn't have to be pretty, but I'm thinking along the lines of something better than a couple of rags held on with duct tape!!;)
  2. Dec 6, 2012 at 10:58 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    How about one of those pool noodles split open? Just wondering.
  3. Dec 6, 2012 at 11:01 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    My thoughts exactly^
  4. Dec 6, 2012 at 11:04 AM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Cost a bit more but? :notsure:
  5. Dec 6, 2012 at 11:05 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Insulation comes in sheets, the have it at home depot or lowes. If you want to look into that option it is called rigid insulation
  6. Dec 6, 2012 at 11:11 AM
    Miketech
    Miketech Member
    Seattle, WA & San Luis Obispo, CA
    08 Tacoma SR5 TRD Sport
    You can buy a huge variety of densities of foam from foam stores. Here in seattle we have one called Friendly Foam. Some of it cuts well on a table saw, some of it with a hot knife, yet more works well with an electric turkey knife, just depends on the type of foam. You can then cut out 4 sides and tape the joins. If you wanted to go further you could even get some tough outdoor type fabric (walmart sells it cheap) and cover it so it will be even longer before you have to replace the foam pieces. However because they are just strips of foam you could replace them pretty easily anytime.
    Or... if you used the split pipe insulation you could get some pretty thick stuff and split it over the corners of the post, wrap some tape to hold it there (or peel off the backing and stick that, just not sure how well that would hold to your post, being as its an adhesive meant to stick to itself) and it should keep both the post and your truck protected from each other. Benefit of this method is that you already know where to find the pipe insulation! =P
    Hope this helped!
  7. Dec 6, 2012 at 11:41 AM
    JRFry
    Central PA
    !!! What are these??
  8. Dec 6, 2012 at 11:41 AM
    JRFry
    Central PA
    "Friendly Foam," huh?? ;) Interesting....
    Seriously tho, lots of good ideas here. Thanks!
  9. Dec 6, 2012 at 11:42 AM
    JRFry
    Central PA
    Ah-hah!! Great idea. But I doubt I can find any this time of year (and I don't have a pool...)
    Thanks!
  10. Dec 6, 2012 at 11:43 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Pool 'Noodles' or pipe insulation. Both are cheap and readily available.
  11. Dec 6, 2012 at 11:49 AM
    BHP
    BHP Active Member
    Roswell, GA
    2002 Dbl Cab Prerunner
    You can get one of those cheap blue foam sleeping bag pads, cut it to size and zip tie the sections onto the posts.
  12. Dec 6, 2012 at 12:05 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    This is what i was talking about
    Rigid foam insulation.
  13. Dec 6, 2012 at 12:17 PM
    JRFry
    Central PA
    !! Good!
  14. Dec 6, 2012 at 12:32 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i used an old hand truck (dolly) tire on a post at my mom's apartment.. but i could just slip i over the top. not so sure how difficult it would be to cut one open. it lasted forever.
  15. Dec 6, 2012 at 12:32 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This ^^^ I've done this before when I had a garage with center support posts.
