Any suggestions on getting these JIS screws out?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ensemaine, Mar 31, 2021.
  1. Mar 31, 2021 at 4:22 PM
    ensemaine
    ensemaine [OP] Active Member
    Davis, CA
    I'm trying to take off the driver's side grab handle trim and the two JIS screws holding the handle in place is giving me trouble.
    I bought some JIS screwdriver from Amazon and tried it on the screws. It turned probably half a turn and it looks like it stripped the screw. Any suggestions on getting this off?
    I think I uploaded an image of what I'm dealing with. I have the pre 2001 model so the screw isn't a 10mm bolt.
  2. Mar 31, 2021 at 4:23 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Go get an ez out
  3. Mar 31, 2021 at 4:38 PM
    1997tacomav6
    Denver
    I used an impact punch with a hammer,
    These screws depending on the year have a glue type substance that locks them in place
    Dm93 likes this.
  4. Mar 31, 2021 at 4:40 PM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    flathead screwdriver, ez out, or the right screwdriver with a rubber band over the bit.. or if you have a dremel with a cutoff bit, you can cut a slot in it to use a flathead as well...
  5. Mar 31, 2021 at 4:46 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Manual impact driver: Put some valve grinding compound on the tip for extra traction: https://www.amazon.com/Permatex-80037-Valve-Grinding-Compound/dp/B000HBM80M/
    DrZ and JJ04TACO like this.
  6. Mar 31, 2021 at 4:59 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I'd drill the head off.
  7. Mar 31, 2021 at 5:18 PM
    ensemaine
    Davis, CA
    I'll try that after the flathead and the rubber band suggestion.
    Basically I drill out the head with a large enough bit and then twist the rest of the screw out?
  8. Mar 31, 2021 at 6:39 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Once the head is gone then the handle will come off and you can grab what is left of the screw with some vise grips. You will need a replacement screw so make it a last resort.
    If you have small needle nose vice grips you might even be able to grab the head of the screw and turn it enough to break it loose. Then a small flat head will be able to grab the bottom where it isn't stripped.
  9. Apr 1, 2021 at 4:53 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Those have loctite on them. Like others suggested, you really have to use a manual impact screwdriver with a JIS bit. I did the same as you and had to drill it out.
    jnossoff likes this.
  10. Apr 1, 2021 at 5:37 AM
    jmferg
    jmferg Well-Known Member
    They are factory loctited in heavily, vice grips didn't work for me. break the head off, remove the trim and use the double nut method to remove the remaining stud piece.
  11. Apr 1, 2021 at 7:08 AM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    Hard to explain.
    I'll use a 3/16" dull drill bit first. The idea is to create friction (heat) to break down the thread adhesive.
    Don't focus on trying to get the drill bit to cut metal. What you want to create is heat.
    Then use a 3/16" reverse drill bit (in it's intended cutting direction). With any luck, this method will back out the screw.
    If the above does not work, center punch what's left of the screw shank, and this time use a 1/8" or 3/32" reverse drill bit.
    There have been a lot of methods of removal mentioned. Use what makes sense for the situation.
    More is better.
  12. Apr 1, 2021 at 10:42 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If all you want is heat then just hold a soldering iron to it.
  13. Apr 1, 2021 at 10:48 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Impact gun with a Phillips head made short work of that. It’s loctited so yeah heat helps.
  14. Apr 1, 2021 at 10:50 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  15. Apr 1, 2021 at 4:13 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
  16. Apr 1, 2021 at 8:12 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Vessel Impacta crosshead (JIS) screwdriver. The turn-on-impact and optimized fit (to what’s left!) would likely make short work of those screws.
  17. Apr 1, 2021 at 8:14 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Dremel a deep cut across the head. Use a fat, stout flathead screwdriver to back it out.
  18. Apr 1, 2021 at 11:46 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    Helpful instructions [based on input from people who have actually done it] can be found at Pages 3 & 4 at https://spikerengineering.com/wp-content/uploads/2020/07/Manual-UG.pdf [copyright @SpikerEng While you are there take a look at his wonderful products at https://spikerengineering.com/ ! ] The PDF includes a link to a Timmy the Toolman video that will be helpful.
    Every Toyota "crosshead" screw is a JIS (Japanese Industrial Standard) and not a Phillips. A Phillips driver will destroy a JIS screw head. The word is getting out about JIS screw heads and JIS drivers are hard to find but do it anyway! I ordered mine last night. Try: https://www.mcmaster.com/jis-(japanese-industrial-standard)-screwdrivers/ I ordered: JIS/Jcis 8-Bit Set 1/4" Hex Shank for Power Tools [Item # 2661N2 ]
    I ended up drilling mine out.
    • Start small; progressively increase the diameter of sharp drill bits made for metal.
    • Drill each time until you hit bottom (difficult to tell, length is 25mm).
    • Then use the next size up drill bit to open up the hole. You are drilling to remove almost all screw material, in stages. Repeat.
    • Drill as straight into the center of the screw thread body as you can, and centered on the very center of the screw body.
    • Drilling off center, or too large, may damage the inside threads that the screw is threaded into.
    • If you damage those inside threads then you will have to either "chase" them (hopefully), or rethread (NO!) possibly to a larger diameter
    • At some point you can reverse the drill and it will likely pull the remaining metal screw pieces out.
    • What you want remaining is a thin spiral of metal remaining from the high part of the thread; you have hopefully removed only the metal at the low part (valley) of the screw thread.
    SpikerEng likes this.
