Any suggestions on quality aftermarket cv axle replacements?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishWolf, Oct 25, 2022.
  1. Oct 25, 2022 at 2:23 PM
    FishWolf
    FishWolf [OP] Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    I have a 2011 Tacoma, and plan on replacing CV axles, I would most likely go with OEM parts but its crazy what they want, $500 installed for each side, I had same situation with control arms/ball joint, they wanted $600 each side, I found some made in USA by Moog, they actually sell a premium "Problem Solver" line with many improvements over OEM units, including greaseable zerks on the ball joints, Im looking for something similar in my cv axles, nothing made in China but yet more affordable than the Toyota stealership, Thanks
    https://www.moogparts.com/technologies/articles/enhanced-premium-control-arms.html
  2. Oct 25, 2022 at 2:25 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Either OEM ($$), China ($), or USA (RCV $$$$)
    Why do you need to replace them? Torn boots?
  3. Oct 25, 2022 at 2:28 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Believe it or not I have been daily driving and wheeling hard on Napa HD cv axles which are around $120 ea IIRC & they have yet to fail me. I also have a very mild lift, only about 2” so my cv angles are awesome but my Napa axles have been fine. I can’t afford oem axles as replacements.
    muddog321, Bikinaz and Chuy like this.
  4. Oct 25, 2022 at 2:29 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    According to dealership, grease leaking out, I havnt really confirmed it, just getting ideas on replacements if thats actually the case
  5. Oct 25, 2022 at 2:31 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Im fine with non OEM as long as its not China, its not easy to find but there is other options, I was pretty impressed by the made in USA Moogs, they have their budget line but also a premium line with many improvements over OEM
  6. Oct 25, 2022 at 2:35 PM
    saint277
    saint277 Vigilo Confido
    You can replace torn boots with a rebuild kit, like 50 bucks plus some labor. there is a thread on how to DIY it somewhere on here.
    Hawapino and FishWolf[OP] like this.
  7. Oct 25, 2022 at 2:38 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Hmn, Im not opposed to some basic wrenching, otherwise Id just find someone
  8. Oct 25, 2022 at 2:42 PM
    saint277
  9. Oct 25, 2022 at 2:48 PM
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
  10. Oct 25, 2022 at 3:12 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The Car Care Nut YouTube channel actually just did a video on Toyota CV boot replacement.
    Reman'd CV axles utilizing OEM components are OK. New aftermarket axles often don't have the same range of articulation, so they blow up more easily off road.
    winkel and goforbroke123 like this.
  11. Oct 25, 2022 at 4:07 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    I see a couple people mentioning the boots, and maybe not have to automatically replace the whole unit
  12. Oct 25, 2022 at 4:27 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Canadian Joe[QUOTED] likes this.
  13. Oct 25, 2022 at 4:35 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    OEM remans are much cheaper than brand new ones and will outlast any standard aftermarket CV axle. Dealerships sell them, also CVJ sells reman OEM axles.
    FishWolf[OP] likes this.
  14. Oct 25, 2022 at 4:36 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Im liking this option for sure!
  15. Oct 25, 2022 at 4:37 PM
    eon_blue
    Azusa, CA
    They charge you a core charge but if you bring or ship in your old ones, you'll get that core charge back.
  16. Oct 25, 2022 at 4:38 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    CVJ-axles, reman OEM factory toyota axles
    SliMbo4.0 likes this.
  17. Oct 25, 2022 at 4:45 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Depending on axle condition, reboot is the way to go as far as quality and bang for the buck. A $50 oem boot kit services one axle. If the boot's been torn for awhile though and let grit in there then I wouldn't go through the effort of saving it.
    Aside from that, I agree with Ty about the Napa ones. I wheeled the piss outta mine for a few years. Finally the outer boot slipped off the joint from the constant extreme droop so I took them into napa and walked out with new ones. The axles carry a lifetime warranty.
    singletrack_ftw and 3JOH22A like this.
  18. Oct 25, 2022 at 4:52 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    sparkystaco[QUOTED] likes this.
  19. Oct 26, 2022 at 6:43 AM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
  20. Oct 26, 2022 at 6:54 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Ive had great luck with LCE cv axles, plus they dont bind up at steep angles.
