Any Tacomas with a pickup bed crane?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DG92071, May 28, 2020.
  1. Jun 2, 2020 at 10:15 AM
    #41
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Yeah for that much effort I'd just pitch it and buy one already set up for that.
    Amen. I considered the crane but ultimately decided if I'm going to be lugging that much hardware around for that much cost, I'd get one on a trailer instead -- benefit there too is after the truck goes/trades in, I keep the same trailer. And I'm not drilling through the bed/frame.
    Seems like a perfect use for a farm jack for a few seconds :p put those off-road show ponies to use!
    Yeah as quoted above, I started thinking about it when I wanted to start collecting free firewood which isn't super light, and would be on my own doing it. MAYBE if I go through the whole process of setting up a wood stove, etc etc etc and using wood as a main fuel source, I'll consider doing it more, but as it is I just use the fireplace for "funsies" during the winter. If I do anything I'll probably land it on a utility trailer so I can pull 5k lbs of wood at a time :p
  2. Jun 2, 2020 at 10:20 AM
    #42
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Exactly. I think that's a good example. Looks like it has pins to adjust the legs, once dropping 700 pounds in the bed it might be difficult to pull the pins. Maybe something adapted, like screw jacks for scaffolding.
    I don't know, that is how they sell trailer hitch cranes and I've never used them so I'll drop out now....:hattip:
    DG92071[OP] and Toyko Joe like this.
  3. Jun 2, 2020 at 7:45 PM
    #43
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    If you used this crane setup with airbags you could just dump all the air out of the bags and then when you get the load in the bed put air to the bags, raising the back,and now you have the legs off the ground and away you go.
    BKinzey, DG92071[OP] and Muddinfun like this.
  4. Jun 2, 2020 at 8:18 PM
    #44
    DG92071
    DG92071 [OP] Well-Known Member
    BEAUTIFUL, thank you!
  5. Jun 2, 2020 at 8:19 PM
    #45
    bhigbee
    Barney
    Hayden Id
    Wrecked 07 DCSB
    You bet, it's an old truck driver trick.
    DG92071[QUOTED][OP] likes this.
  6. Jun 2, 2020 at 8:20 PM
    #46
    DG92071
    Boat jack stands have long threaded bolts and big wing nuts like that. I have a few of those that I can adapt.
