any tacos with bushwackers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotyme08, Jul 16, 2009.
  1. Jul 16, 2009 at 2:45 AM
    tacotyme08
    tacotyme08 [OP] My truck dont bitch like my GF
    Maricopa, Arizona
    08 4x4 murdered out
    3" spacer lift with add-a-leaf, BHLM, smoked tailights, 7" in-dash dvd, 18" pro-comp xtreme alloys, 325/60/18 hankook dynapro mt's, 2 12" rockford fosgate p3's with 1800watt kenwood amp, K&N cold air intake, Borla muffler, grillcraft grill with hella 500's behind, and silverstar ultras all around
    I bought new tires about 2 weeks ago and they were rubbing my fender flares pretty bad, i had to take the fender flares completley off for them to stop rubbing. i know the tires i got were a little too big for the truck but they were a great deal. i was wondering if anyone has put bushwackers on their truck and if they would help the rubbing problem?
  2. Jul 16, 2009 at 4:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Where exactly are they rubbing?
    What size tires are they?
    Installing different flares isn't gonna help unless you actually cut away at part of the truck itself.
    Use the search button (top right in the blue bar) and search for a mild lift kit.
  3. Jul 16, 2009 at 6:35 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    :puke:
    Get Glassworks. You still won't clear the cab mount though.
  4. Jul 16, 2009 at 6:46 AM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    you have to cut on the cab mount to clear it if that is your problem is what i am understanding...correct me if im wrong. mine touches it a bit when in 3/4 to a full turn while navigating obstacles on the trail. I'm pretty sure after what toku said, that i can cut on that mount no problems.
  5. Jul 17, 2009 at 12:22 AM
    tacotyme08
    Maricopa, Arizona
    08 4x4 murdered out
    i already have a 3" spacer lift and it does rub the bolt that holds the fender next to the door, BADLY! im thinking to fix the problem permenantly i need to get glassworks fenders or a bigger lift, problem is that glassworks has only those 3" rise fender, and i cant afford a lift.too bad glassworks dont make a little more mild fender. and i will have to cut on the cab, but i dont want to do any crazy cutting. how did u solve the problem on your truck gjbonner?
  6. Jul 17, 2009 at 1:46 AM
    brian
    Elizabeth City, NC
    Do a search for it, theres one member on the forums who did a writeup on it. I'm a little too drunk to find it atm though, sorry.
  7. Jul 17, 2009 at 6:46 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Don't know tire size and wheel BS.
    Just trim it or lift it, no way around it.
    PS. smaller tires wil help thou...........
  8. Jul 17, 2009 at 6:50 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    your tire size is too big for a 3" lift. a 325/60/18 is 33.5" tall and nearly 13" wide. Thats your problem.....
  9. Jul 17, 2009 at 10:13 AM
    Mandy3206
    San Juan PR
    Sheesh, I just saw the profile and saw the tire size, probably a 6" will get you there or maybe an LT like Allpro may let you run those tires without chopping.
    Too big of a tire, search for body mount and you'll find lots of trimmed Tacos.
    If money is a problem and can't change the tires, then you're stuck nowhere until money can be thrown at the problem..........stash the tires and save some money............first decide which way you're going:
    1) Chop lots of metal, body mounts, fenders, maybe tub the wheel well
    2) Lift to 6" and maybe chop too
    3) LT and maybe chop too
    4) Sell tires and get smaller ones that fit
    Good luck
  10. Jul 17, 2009 at 12:06 PM
    tacotyme08
    Maricopa, Arizona
    08 4x4 murdered out
    ya i know those tires are huge, but they look so badass lol. i may just have to get a bigger lift.i may just sell the tires and get new ones like mandy 3206 said, but then ill b running stocks for a while. i would just go get that allpro longtravel kit that i always dreamed of having but i gotta pay my damn college tuition! lol thanks for the help guys.
