Any teeth grinders in here?
Discussion in 'Health' started by flatblack, Jun 26, 2013.
  1. Jun 26, 2013 at 4:29 AM
    flatblack
    flatblack [OP] Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I apparently grind my teeth pretty severly while I'm asleep
    My premolars and molars are ground nearly flat, which makes them extremely sensitive since there's little to no enamel covering the dentin/root
    Also, almost all of my teeth have small fractures in them due to the force I must be clinching while asleep
    Anyone have/had this problem?
    Have you had them restored/rebuilt somehow that didn't cost 1-3k a tooth?
    Have you had any success with nightguards?
    Etc.
    I'd appreciate any help with this - I'm sick of just googling info about it
    Some one-on-one convo with someone who's dealt with this would be nice
  2. Jun 26, 2013 at 4:35 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    I grind my teeth. Started in high school when i had my braces removed. I put a hole in my retainer over my right canine tooth.
    I have worn a night guard for about 6 years now with no issues. I went the cheaper route with the DenTex brand that is heated then molded to your teeth and bite. The I am on my 2nd one now since they to break down with the grinding. I do not feel the need to spend the $$$ on a custom ones when the drug store brands work just fine for me.
  3. Jun 26, 2013 at 4:36 AM
    flatblack
    CDA
    Thanks!
    I will check into those
  4. Aug 8, 2013 at 4:12 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I sometimes grind my teeth but have not had any really bad side affects from it yet. I wake up doing it more when Im stressed about things.. . .
    so, I have been able to control it a little bit by making sure im in a good mood by bedtime. this involves beers.
    I will look into guards though as sometimes I still wake up with intense pressure on my teeth. thanks for this thread!
  5. Aug 13, 2013 at 5:06 AM
    flatblack
    CDA
    Sure! Thanks for stopping in!
    I have tried the DenTex guard recommended (Thanks, Jester!) and it's good enough, for now, to keep me from spending $600 on a custom one
    Can anyone comment on options to have teeth rebuilt?
    Like I said, I've ground mine down pretty much flat
    I'd rather not have them ground the rest of the way and crowned; not to mention that would cost at least 1k a tooth
    Is there anything else that can be done?
  6. Aug 13, 2013 at 5:25 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Yeah I do it really bad. I need to try then dentex mouth guards. Every other one I've used has ended up on my floor or pillow in the middle of the night. My jaw hurts every day from the pressure too
  7. Aug 13, 2013 at 5:29 AM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    My sister grinds her teeth pretty bad. She wore a football mouthpiece at night lol. Pretty sure she still has issues with it.
  8. Aug 13, 2013 at 5:35 AM
    Deercantseeme
    Deercantseeme Well-Known Member
    Colorado
    afe intake, jvc kw-r5000, Bhlm, true btlm, Ipcw black third brake light, avs slim in channel window visors, wade floor mats, ome 884s, dakars, tinted windows, black wet okole seat covers, debadged, grillecraft insert, matte black SCS F5 wheels, 285 duratracs
    I seriously grind my teeth. I use a custom night guard. I've had to get two root canals to fix the damage. I have pits in my molars and at one point just had simple fillings to help ease the pain. This was before I started using a night guard so they didn't last. Dentists are expensive and I had super messed up teeth until I joined the army because I couldn't afford it. Not sure if fillings would work for you but might be worth it to look into it.
  9. Aug 13, 2013 at 5:42 AM
    flatblack
    CDA
    yeah, I had 3 molars root canaled for this reason and the guy who did them did a really horrible job;
    3 years later I found out, from a routine x-ray, that all 3 were infected because the canals weren't fully excavated, and one even had a drill tip broke off in it
    The options were to have them re-root canaled at 1k a piece, with a 20-50% chance of failure... or get them pulled
    So, instead of rolling the dice with 3k; I got them pulled :mad::(
    My remaining molars are all heavily pitted too
    The whole situation makes me so stressed I could grind my teeth!
  10. Aug 13, 2013 at 6:08 AM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    Damn dude. That sounds incredibly painful.
  11. Aug 13, 2013 at 6:14 AM
    robnolan
    robnolan Well-Known Member
    Rob
    Naples, FL
    09 PreRunner V6 SR5
    I've had a problem with teeth grinding, about a year ago the dentist said I must have been grinding my teeth because they're more worn down than should be for my age, but I didn't even realize I was doing it. It was either in my sleep or I was doing it subconsciously when I was stressed out..but they didn't suggest using a mouthguard and didn't say anything last time I went there. So I really don't know lol. I have an appointment in 3 days so if it's still a problem they'll probably let me know
  12. Aug 14, 2013 at 12:40 AM
    flatblack
    CDA
    I had no clue I did it either
    I've been told by several dentists in the past that I do it; just based on the wear
    But, I thought it had happened from my teeth shifting around during the time I had braces; so, I never paid mind to the grinding theory
    Eventually, after being told the same by a new dentist; I'm gathering they must be right
    And the more I pay attention now, I do notice that I subconciously clinch (not so much grind) my teeth pretty often
    Also, the second I wake up I notice that I've been doing the same and/or grinding
  13. Aug 14, 2013 at 1:11 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If only i had teeth to grind.......:pout::pout:
  14. Aug 14, 2013 at 1:19 AM
    flatblack
    CDA
    Sorry, dude!
    I'm getting in that same boat... just had 3 molars yanked cause of an incompentent dentist
    Aesthetically, the best ones, cause you can't easily tell; but, darnit! those are the main teeth I chew on!
    Now I've got to chew everything on my front teeth; and the roof of my mouth is always getting all torn up because of it
    I may end up getting partial dentures... and I'm only freaking 30
  15. Aug 26, 2013 at 4:05 PM
    joshua721
    joshua721 Well-Known Member
    05 dblcab 4x4
    6 inch fabtech stage 2, alcan springs
    Alcohol makes me grind and clack my jaw( opening than slamming it shut again) its only been the last few years that I noticed I did that.
  16. Aug 26, 2013 at 4:12 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    I picked up the habit of "bad teeth grinding" in last few years. Several docs said mine was due to PTSD from the military.
    You have to use a night guard to save your tooth enamel.
  17. Aug 26, 2013 at 4:16 PM
    HIYota
    HIYota Well-Known Member
    Angel
    O'Fallon, IL originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Fox 2.5 ext travel coilovers w/700# King Coils, Desert Products uniball UCAs, AllPro 3" leafs, Fox rear resi's, ext brake lines, Weathertech digifits front and back, B.A.M.F. sliders & LCA skids, full set of ATO skids, Aero Turbine 2525XL, LED dome, map and license plate lights, URD Short Throw Shifter, Brute Force Fab front plate bumper, Satoshi, BlueInstinct console and door handle covers, TRS D2S HID retrofit, aFe Pro dry-s air filter, TonnoPro Tonneau cover, Pop&Lock, Yellow wire mod, Wet Okole seat covers, 17" SCS SR8 rims, 50" radius LED lightbar mounted with RelentlessFab mounts, ComeUp Winch, more to come.
    I found out I had TMD from grinding and clenching my jaw while I sleep and when awake. It got really bad once my daughter was born. I guess the stress of working, dealing with a newborn and balancing bills got to me. Luckily I brought it up to the Doc before it got really bad. It's since gone away now that I've learned to realize when I'm doing it. Doc told me if it returns I'll have to use a night guard.
  18. Mar 10, 2014 at 11:36 AM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2011 Dbl Cab Prerunner
    ^^^ this
    My problem is I throw it across the room at some point during the night
  19. Sep 1, 2014 at 11:44 AM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Been grinding my teeth for about 13 yrs. First dentist didn't catch it, his dental tech did. The next dentist made me a "mouthguard", that literally lasted 2 days. And then I found a competent dentist, he referred me to one of the best Orthodontist in the Nation. For the 2 1/2 yrs of braces, I had little to no grinding issues. Then about 6 months after the braces were removed, I started grinding/clenching real bad. The Orthodontist suggested their "night guard" for a mere $700, it replaced my top retainer. Every so often i'll have jaw pain from clenching at night, but the grinding has been eliminated.
