Any thought on my proposed audio build for my 2020 tacoma?
Discussion in 'Audio & Video' started by kkjjjmccann, Apr 22, 2020.
  1. Apr 22, 2020 at 5:41 AM
    kkjjjmccann
    kkjjjmccann [OP] Active Member
    Kelly
    Swansboro, NC
    2016 Tacoma TRD DBCB 4X4 Nav Sunroof
    Helix g five amp
    Addison bit 10
    hertz MPK PRO 6.5 components up front ACTIVE
    hertz MPK PRO 6.5 coaxial for rears
    Mr. Marv 10" subwoofer with JL Audio in custom sub box
    stock head unit
  2. Apr 22, 2020 at 5:44 AM
    Taco1.1
    Taco1.1 Well-Known Member
    2018 TRD Off-Road
    Debadged, Kenwood 9905 Head Unit, Tinted Windows, Remote Start
    Any specific reason you want to stick with the stock head unit? It has no apple carplay or android auto (assuming you still have the 2016).
    Shellshock likes this.
  3. Apr 22, 2020 at 5:47 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    The title says for 2020 tacoma
  4. Apr 22, 2020 at 5:48 AM
    Taco1.1
    2018 TRD Off-Road
    Duh. I need coffee before responding.
  5. Apr 22, 2020 at 10:57 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Looks like your planning to use the amp to run just the front speakers and the sub right? If so, save your self the money and dont even bother getting new rear speakers.
    The factory headunit plays so low on the rear speakers that upgrading them will do nothing with a upgrade.
    If you were planning to amp the rear speakers, then I would say to upgrade them.
  6. Apr 22, 2020 at 6:31 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    I'd be ditchin' the rears too. You really need processing if you're going to use them - and do it right which means more amp channels. The Bit 10 might be capable of making up for the time difference you'd need to compensate for with factory power...dunno. Its latency isn't that bad, but it does exist...on the order of 10ms or sommat. But in a SQ setup, and I'd suspect that's the goal considering the gear, you'll usually want to bandwidth limit the rear channels at least. And maybe have another preset for rear passengers if the Bit 10 does that. And probably moar power. If you are going to limit bandwidth to the rear, probably no need for coax.
