Any Thoughts on PK Grills?
Discussion in 'Food Talk' started by HighCountryTacoma, Apr 14, 2018.
  1. Apr 14, 2018 at 1:54 AM
    HighCountryTacoma
    HighCountryTacoma [OP] Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    I'm in the market for a new grill. (Food grill, not car grille) Anybody had any experience with PK? I just recently found out about these, seems as though they are more popular in the south. looks like a good alternative to the old Weber that could potentially have a longer lifespan at a slightly higher cost but with good smoking capability. Any first hand experience here?
  2. Apr 14, 2018 at 7:09 AM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    I’ve had one for 15 years, love it. Very versatile and controllable.
  3. Apr 14, 2018 at 11:56 AM
    horstuff
    horstuff Re-member
    PNW
    Some pics when I rigged it up for smoking before I had a dedicated smoker, worked great but you don’t really need to do all this, just makes it more controllable as far as indirect heat...
  4. Apr 14, 2018 at 3:30 PM
    HighCountryTacoma
    Colorado
    Damn that looks good! Thanks for the info. Really just asking cause there aren’t any retailers around me and I don’t know anybody that has one. So I’m m either gonna have to commit and order one of these online or drive a couple hours to view one in person.
  5. Apr 14, 2018 at 3:39 PM
    horstuff
    horstuff Re-member
    PNW
    They’re worth it, will never rust, bulletproof. The 4 vents make it extremely controllable. Only reason I don’t use it all the time is because smoking full racks of ribs or a brisket can’t be done as well as in a Weber Smokey Mountain or whatever. Not enough room in the PK for big cuts like that AND indirect heat. That’s why you see in one of the pics a rack of ribs cut in half. But, unless you’re smoking for a few people, you could make it work. Full brisket is the only no. As far as a straight bbq setup, it’s top notch.
  6. Apr 14, 2018 at 5:19 PM
    HighCountryTacoma
    Colorado
    Yeah, it’d primarily be used for traditional grilling and the occasional smoke. They have made a new larger version, check it out if you haven’t seen it. I’ll probably get the traditional smaller one though. Thanks again!
  7. Apr 14, 2018 at 6:37 PM
    horstuff
    horstuff Re-member
    PNW
    I have seen the new one, 360 or whatever it’s called. Too much $ IMO. The classic is just that, classic, built like a tank, damn near flawless. Highly recommended as your primary grilling unit.
    HighCountryTacoma[OP] likes this.
