Any time fog light failure. Help.
Discussion in 'Technical Chat' started by clc, Feb 4, 2012.
  1. Feb 4, 2012 at 5:48 PM
    clc
    clc [OP] New Member
    NY
    SPORT
    Ok, I made a newbie mistake. I jumped the gun and did the "anytime fog light mod" on my new 2012. I thought everything was going great when I started it up and-Nothing.. Then I realized the mod I just did was wrong. I found a different mod for anytime fogs for the 2012's.
    My problem now is my check engine light and traction light are now on.....OMG, what did I do? Did I damage my truck? Is there any easy fix? Stupid newbie mistake! Please help.
  2. Feb 4, 2012 at 5:53 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Get a multimeter and check your fuses.
  3. Feb 4, 2012 at 6:00 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    take it to the dealership...I wouldn't be trying to reset the check engine light myself.
    ^ above sounds better if you have one
  4. Feb 4, 2012 at 6:04 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    dealership will say, whats all this shit you got goin on here. and charge you out the ass.
    my suggestion. unhook the battery, go watch some tv, then rehook the battery. gotta start somewhere, this is an easy place to start.
  5. Feb 4, 2012 at 6:05 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This^^
    Do not panick! You probably just blew a fuse. Figure out which one, and why, fix it, then pull the negative battery cable for a few minutes to reset the warning lights. If you can't get the light reset that way, then yeah, you need to take it in, but that usually works for me.
  6. Feb 4, 2012 at 6:16 PM
    clc
    clc [OP] New Member
    NY
    SPORT
    Thanks for the responses, what gets me is that I thought I was doing everything right. Everything matched up, I thought. The relay and wires where the same on my truck as the mod on the post.. I didn't know there was a separate mod for the 2102s. If thats the case what is so different on the 2012's.
  7. Feb 4, 2012 at 7:54 PM
    clc
    clc [OP] New Member
    NY
    SPORT
    Disconnected the neg battery terminal and it worked, Check engine light off. Do I dare try the 2012 anytime fog light mod. Can anyone tell me why the mods are so different.
  8. Feb 4, 2012 at 7:55 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    just yty unplug the battery after a few hpurs, plug it back in, i believe it will be all get reset, if not, just go to any auto shop out there, ask them help you to reset.
    don't panic
  9. Feb 4, 2012 at 7:58 PM
    acdronin
    acdronin Well-Known Member
    If none of this works, I would undo everything you did, including the mod, take anything you added out, take it to the dealer and play dumb
  10. Feb 10, 2012 at 8:56 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    ^ haaa thats what i was thinking reading alll these posts!
