Any tips for removing fender flares properly/safely?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorrinRadd, May 3, 2021.
  1. May 3, 2021 at 10:27 AM
    NorrinRadd
    NorrinRadd [OP] Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    The service manual, as usual, leaves out the "real world" details of things. It says to use a heat lamp but don't overheat (lol). I don't have one, but I DO have a shrink tubing hot air gun. I suspect it puts out a lot more focused heat and would be wary of bringing it close to my truck exterior.
    Anyone who has removed their fender flares have any hints for removal and reassembly? I want to get them vinyl wrapped black to break up the solid color down the side of my truck, but I hate the look of those flares with studs or visible bolts. TIA!
  2. May 3, 2021 at 10:29 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Take the bolt out inside the fender and pull them off. Don't be shy.
    Antboooy likes this.
  3. May 3, 2021 at 10:38 AM
    Antboooy
    Antboooy Well-Known Member
    Ant
    Southern Oregon
    2016 Silver Tacoma TRD 2WD
    Bilstein 5100 front and rear Eibach lift springs Freedom Off-road UCAs Torch Off-road 1.5in AAL
    Just give em a good yank once the bolts are off. But then you'll be left with the sticky residue on your paint from the double sided adhesive tape.
    May I ask why you're removing them?
  4. May 3, 2021 at 11:58 AM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    put your truck in the sun too. softens everything up.
  5. May 3, 2021 at 12:01 PM
    MTB Mamba
    MTB Mamba Well-Known Member
    2018 SR5, KDMax 6.0
  6. May 3, 2021 at 12:17 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Remove the bolts and start from the front. 100% you're going to break clips so buy some of these ahead of time:
    https://www.amazon.com/AUTOLA-75495...20068643&sprefix=tacoma+fender,aps,224&sr=8-6
    Slowly pull the fender off. There are a couple of tabs on the fronts in the bumper that can be difficult to get out so be careful with those. Work slowly but firmly.
    You can do this while heating up the 3M adhesive tape with a hair dryer (safer than a heat gun) or do it after you pull off the fenders.
    If you pull off the fenders first use this method for removing the adhesive residue:
    1. Use the hairdryer as in my video: https://youtu.be/ASWhbQCVhk8
    2. Use Goo Gone after to finish removing and additional residue
    3. Use Iso Alcohol to remove any additional contaminants prior to installing the fenders
    Vmax540, Skydvrr and NorrinRadd[OP] like this.
  7. May 3, 2021 at 2:28 PM
    chuam
    Marcus
    San Diego
    Remember that you will need to put automotive double-sided tape back onto your fenders so you will have to buy it and clean prep the fenders as well.
    NorrinRadd[OP] likes this.
  8. May 3, 2021 at 3:36 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Places that di wrapping can usually do the flares while on the truck from what I was told.
  9. May 3, 2021 at 5:04 PM
    NorrinRadd
    WA
    Got a quote for that which was six to seven hundred bucks so I figured it's either going to be done by me or live with monocolor...
  10. May 3, 2021 at 5:08 PM
    chuam
    Marcus
    San Diego
    Crap, for that price you can almost buy brand new matte black ones from the dealer.
    Not a bad idea to check offerup or craigslist. I bought an OEM set of the matte black OR flares that had some minor scratches from being shipped but couldn't be installed because they weren't pristine. I think I paid around $200-250 for them. I knew I was going to scratch them up so I didn't care. They came with the 3M adhesive tape and all the clips as well. I was also able to sell my old SSM painted ones for $150.
  11. May 9, 2021 at 7:33 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Good Video, short and to the point wish more were like it on YouTube.
  12. May 9, 2021 at 7:36 PM
    cementnotgray
    cementnotgray Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
  13. May 9, 2021 at 7:37 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    You will likely need some new clips.
  14. May 9, 2021 at 7:51 PM
    Hofmann’s Tacos
    Hofmann’s Tacos Professional Asian
    Nor Cal / South FL
    2020 off-road 6MT (SFOB 2.0)
    SFOB 2.0
    I’d just mask it off and plasti-dip them honestly
    But you could also wrap them yourself with some patience, you just have to be careful and patient while you cut the vinyl
