Any tips on adjusting 5100 height setting without removing struts from truck??
Discussion in 'Suspension' started by BenWA, Dec 13, 2010.
  1. Dec 13, 2010 at 9:47 PM
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I want to move from the 0" setting to the .85" setting, so it's not like the coils have to be compressed a huge amount. Is this a relatively straightforward task? Just by looking, seems like it would be a challenge to get two threaded rod style coil compressors on opposite sides of the coil, with the flanges of the shock tower in the way. Any tips??
    p.s., I'm sure there are a million threads about this but nothing relevant turned up in my search.
  2. Dec 13, 2010 at 9:55 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    not possible... safely
  3. Dec 13, 2010 at 10:00 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    i tried. i failed. its not worth the hassel, its only an extra 15 min per side to take the coils right out. you waste that dinkin around with the coil compressor easily.
  4. Dec 13, 2010 at 10:05 PM
    BenWA
    Boston burbs
    Okay, well...off they come AGAIN.
    :annoyed:
    I bet I could do it blindfolded this time. Gonna be like the 3rd time in a month.
    Thanx for the replies.
  5. Dec 13, 2010 at 10:07 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    sucks.. hope you have lifetime alignment
  6. Dec 13, 2010 at 10:11 PM
    BenWA
    Boston burbs
    Nope, unfortunately. :( Another $60 down the turlit.
  7. Dec 13, 2010 at 10:15 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    bummer dude. make sure you dont have the taco lean before you get it aligned. you might wanna get the spacer in first so you dont waste money getting another alignment again
  8. Dec 15, 2010 at 9:00 AM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    so my taco has the lean, since its a 1/4 inch it actually lifts it a 1/2 inch, is this true.
    if anyone can answer it would be much appericated.
    since its a spacer, i read its bad to stacks lifts, but does this one not count since its such a small lift?
    thanks, anyone, did want to start a new tread so i added to this one.
    might be the wrong thread since its about the 5100's but worth a try,
  9. Dec 15, 2010 at 9:58 AM
    Grande
    Victorville, CA
    bump for an answer
  10. Dec 15, 2010 at 10:01 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Why have you done this 3 times this month?
    I realize you are doing it a 2nd time to raise it but why did you do it the 3rd time?
  11. Dec 15, 2010 at 10:19 AM
    deadbolt
    deadbolt do w3rk!
    Socal
    many people use this small spacer to correct the lean. i doubt it would affect anything.
  12. Dec 15, 2010 at 10:20 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I've seen this done on a Scion, can't vouch for its effectiveness on the Taco.
    Source: http://dpcars.net/scion/sc2.htm
    1. While the truck is on the ground (springs compressed by truck's own weight), wrap a tow strap several times up and down the coils to hold its length.
    2. Jack up the truck. The spring is still in its compressed length, but the shock is extended, giving you [hopefully] enough room to move the spring perch.
  13. Dec 15, 2010 at 11:00 AM
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    That sounds logical but VERY dangerous! If your strap breaks or loosens, you could cause damage or loose a finger.
    It's really not too difficult to remove. I agree it's a pain but it's safer.
  14. Dec 15, 2010 at 11:08 AM
    merrit
    merrit Well-Known Member
    Las Vegas
    seriously depussified oc to
    buy another set then adjust them ?
  15. Dec 15, 2010 at 11:17 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Could someone explain to me why you need an alignment after pulling a coilover out.
  16. Dec 15, 2010 at 11:26 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You don't necessarily need an alignment after pulling a coilover out. You DO need an alignment after pulling a coilover out and adjusting the height of it.
  17. Dec 15, 2010 at 11:26 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The OP will be adjusting the height of the vehicle which will change the geometry hence the need for an alignment.
  18. Dec 15, 2010 at 11:29 AM
    Chachie
    Justin
    Nor Cal
    Ok well that was not stated. Adjusting the height i can see why...although i have gone up and down with mine and just not bothered with it...but i have had mine out like 10 times in the last couple months with no alignment.
  19. Dec 15, 2010 at 11:31 AM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Firestone lifetime alignment is only $140, and they always have coupons on their site for it. I bought it knowing I would be trying different settings on my 5100's and have used it a few times, and they have been able to align mine fine every time.
  20. Dec 15, 2010 at 11:32 AM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    In the OP: "I want to move from the 0" setting to the .85" setting"
