Any Tips On Handling Diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blm, Jun 2, 2025.
  1. Jun 2, 2025 at 5:08 PM
    blm
    blm [OP] Well-Known Member
    I'm changing the oil pan on my 2013 with the 2.7 and 4 x 4. I have everything disconnected except the 3 fastners that mount the front differential and the actuator harness plus there may be a vent tube. I even cracked the alan head fastner loose a bit to see if it was going to give me problems.
    So tomorrow first thing is drop the diff. Looks like it has to move forward as it is coming out. My plan is to support it with a transmission jack as the mounting bolts are removed.
    So anyone that has done this is there any tips? How far does it need dropped?
  2. Jun 2, 2025 at 8:42 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Couldn't tell you how much it needs dropped to get to the oil pan (or if it needs removed entirely or not)...
    When I took mine out to install a locker, I basically just pivoted it down & out from the frame. There was a protrusion (pry boss?) near the top of the diff housing that hit the front crossmember though that I had to grind down slightly for it to clear, but that took all of about 5 minutes to grab an angle grinder and whip about ¼" off of it.
    Just be aware the diff is VERY heavy and awkward to handle (like 100-120lbs or somewhere thereabouts).
  3. Jun 2, 2025 at 8:49 PM
    Bishop84
    Bishop84 Well-Known Member
    Make sure breathers are disconnected, there's 2, the 4x4 connector and the prop shaft.
    I remove the allen key mount first to give more room for rotation, once the 2 17mm and the key bolt are out, I pry up on the diff and remove the mount.
    Then rotate the diff forward and out with the pinion upward.
    It always pukes out oil, no matter how well you drain it lol.
    SR-71A and b_r_o like this.
  4. Jun 3, 2025 at 4:42 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Did mine over the winter for a re-gear. The hardest bit for me was lifting the diff back far enough up to reconnect the breather hose hardline to the top of the diff to the diff breather and thread the little bolt that holds it in place. You need to hold it just right, up far enough to reconnect the breather but not too far so that you've got room to work. Even with a tranny jack under the diff and an extension on the breather line, I was working by feel. I didn't see a work around (other than having the motor out) but I definitely didn't see a need to take a grinder to anything! Lol!
  5. Jun 3, 2025 at 2:31 PM
    blm
    Ok i got the front diff dropped maybe 3-4 inches on the passer side and a little less on drivers side which really doesnt matter.
    Anyway i am having trouble getting some of the oil pan bolts out. Especially about 5 or 6 at the front. There isnt much clearance there between the bolts and steering tube.
    Cant get a rachet with a socket in there. What tool did you use to get the bolts out in that area?
    DesertRatliff likes this.
  6. Jun 3, 2025 at 2:34 PM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    box end ratcheting wrench and a few knocks from a dead blow hammer?
  7. Jun 3, 2025 at 2:47 PM
    Bishop84
    It's brutal, there's a few options.
    Lower the transmission and tilt the engine back/upwards. This requires the cross member being dropped.
    Or the "right" way. Remove the steering rack. It suuuuuucks but the rack comes out easy with the diff out. You could also try just loosening the rack.
  8. Jun 3, 2025 at 3:26 PM
    blm
    couldnt get a ratcheting wrench on them. The ratcheting head is too big for clearance between the bolts heads and the oil pan. Plus the oil pan has a return on it that will only allow a socket on it.
  9. Jun 3, 2025 at 4:28 PM
    blm
    So does the diff need completely removed for this?
    Wondering if a 1/4 drive 10 mm universal socket would do any good.
  10. Jun 3, 2025 at 4:39 PM
    Bishop84
    It’s certainly worth trying.
