Any tips on how to pull the fog light relay?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DenverMojo, Jan 13, 2015.
  1. Jan 13, 2015 at 2:03 PM
    DenverMojo
    DenverMojo [OP] Well-Known Member
    Evergreen, CO
    13 DCSB OR 6-spd
    It's kind of hard to get a good grip on the relay. I haven't had much success in trying to pull it out so far. Don't want to try pliers because I'm sure I'll destroy the relay that way... Anyone have any tips on an easy method to get that relay to pop out?
    thanks!
  2. Jan 13, 2015 at 3:27 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    Um, you could use your fingers?:confused:
  3. Jan 13, 2015 at 5:07 PM
    DenverMojo
    Evergreen, CO
    13 DCSB OR 6-spd
    Yeah, I only spent 5-10 minutes trying to work it out, but wasn't making any progress. Had as good of a grip as I could on it and tried to wiggle/work it out without any luck. Just wanted to see if anyone had any tips. I was hoping there was a relay puller somewhere that I hadn't looked (like there is a fuse puller under the lid of the main fuse box). My main problem seems to be that I can't get a good grip on it because the adjacent relay is so close.
  4. Jan 13, 2015 at 5:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    a light grip with a pair of pliers should do the trick .
  5. Jan 13, 2015 at 6:29 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Wiggling and pliers should help. Once you get a little lip on the bottom you can gently pry it up using a flathead. Try grabbing it the long way (your fingers on the two short sides), it tends to flex less and allows you a more sturdy grip
  6. Jan 14, 2015 at 3:12 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Those relays can be in there good. I had to pull one for the fog light anytime mod linked in my signature and I luckily had some plastic panel tools and one had like a small 90deg end on it and I was able to sneak that guy under the bottom to get some more leverage while I wiggled it and pulled upwards. I wouldn't attempt this with anything metal so you don't short anything out but if you have something non-conductive like that it can help you to pry it out with some more leverage since it's tough to get very much traction on it where it is.
  7. Jan 14, 2015 at 5:06 PM
    Hair Missile
    Hair Missile Well-Known Member
    VT
    2014 DCSB TRD OR
    Lund Genesis Elite Tri-Fold tonneau, FJ Trail Team Wheels, Weathertech floor liners, Wet Okole seat covers, OEM bed mat, ND4's Fog Light Anytime Mod, LOTS of Poorboys EX-P paint sealant ;-)
    I found it helped to pull the other two relays first. They were stubborn for sure.
  8. Jan 14, 2015 at 7:13 PM
    DenverMojo
    Evergreen, CO
    13 DCSB OR 6-spd
    Thanks for the suggestions (and confirmation that I'm not being a total pansy). Friend at work has some plastic panel tools that I may borrow. I didn't think about pulling the other relays, either. Great thought. Will try that first.
