Any tips on reading the dipstick accurately?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by marcamos, Oct 10, 2022.
  1. Oct 10, 2022 at 6:17 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    I taped mine with 2 pieces of painters tape. One at the full dot and one at the low mark. Basically masking the dipstick so that the oil level normal operating range of the metal is exposed. Then I took some 2000 grit and sanded that part of the dipstick. In simple terms, I gave the area of the dipstick where the oil should be in a matte finish with the rest staying the factory sorta shiny metal. It’s a lot easier to see a reading on that matte finish than the shiny part now so as long as it’s in the higher part of that area I know I’m good.
    Barsoom likes this.
  2. Oct 10, 2022 at 6:57 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Can color the tip with a paint marker like the ones used for marking pistons and cylinder heads.
  3. Oct 11, 2022 at 3:34 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    Even with fresh oil, it's not that hard to read. The real trick is to pull the dipstick, wipe it down, then reinsert. When you pull it out again, you should fairly easily be able to see the difference in surface reflection between the dipstick and the oil. I just put in 6 qts. 6 oz. and call it a day and read it a few times a year. Way easier than checking the oil cooled 911 (14 qts.) where you have to drive it until it's at full operating temperature, park it on a level surface and then, without turning the engine off, open up the rear deck, pull out the dipstick, wipe it down, re-insert and then read it. And when you're changing the oil on that, you have to drain both the engine and the external oil reservoir, and all that oil comes gushing out all at once and if your oil drain pan isn't fast enough, it'll overflow and coat your entire garage floor. Then, you replace the drain plugs with new crush washers, screw on a new Mahle filter, add 9-10 quarts, then go out and drive it until it's hot and go through the aforementioned checking routine, adding just enough to bring you up to the top fill line. And even though there's 14 quarts in there, you can never get more than 11 out during an oil change. The Taco is so easy by comparison.
  4. Oct 11, 2022 at 3:48 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I scuffed and also twisted mine. It does not seem to drag on the tube anymore
  5. Oct 11, 2022 at 8:28 AM
    McGillz
    McGillz “It’s not accessorizing... It’s a BUILD!”
    New Jersey
    '19 TRD Sport Barcelona Red
    KMC Grenade wheels / BFG KO2 305/65/17 E rated, ECGS clamshell bushing, CMC, ARB Old Man Emu 2.5" lift- ARB 90000 OME Nitrocharger Sport Strut, ARB OME - 2886 Coil Springs (heavy), ARB OME Leaf Springs - EL111R (medium), SPC Specialty Products Upper Control Arms, Retrax One XR Tonneau Cover, Rhino Rack Vortex rails, Rago Fabrication Bed Stiffener, Tacomabeast- Spyder headlights /sequential LED DRL, Rigid driving/fog lightbar, RCI steel Skid Plate, Fab Fours Vengeance front bumper- High Pre Runner Guard, Fab Fours rear bumper, MillerCAT stainless Cat Shield, FEND-X wheel liners, Protec splash guards, Bushwhacker flares (Rhinoliner painted). For now…. Wife cut me off!!!
    Great idea!
    Rusty66 likes this.
  6. Oct 11, 2022 at 12:53 PM
    marcamos
    marcamos [OP] Well-Known Member
    Marc
    Beverly, Massachusetts
    2021 Off Road 6MT
    To me, it's less of a "I can't see the color" issue and way more of a "it looks like a mountain scene that starts halfway between the two dots and ends up near the yellow handle" issue.
  7. Oct 11, 2022 at 1:03 PM
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    Drive your truck. Pull the dipstick up a ways and let it sit for 5 minutes. Pull the dipstick and clean and then check the level. You will have one shot to get a great read lol
  8. Oct 11, 2022 at 1:30 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    Fine, I'll have this bald man over sometime to bless my truck.
    Why are people acting like it is impossible, or somehow beneath us, to work on our trucks? Grampa was a mechanic, Dad worked in his shop (as a child slave, most likely) and I grew up doing all the "easy" maintenance on my rides.
    I've replaced starters, water pumps, alternators, all fluids, patched tires, pulled dents, cleaned throttle bodies, replaced all filters, replaced headlights, bled brakes, fixed fuel tank leaks, torn dashes apart to replace heater cores, bled cooling systems, cleaned/gapped plugs, criticized my betters, fixed vacuum leaks, greased wheel bearings, replaced pinion seals, rotated tires, diagnosed shorts...
    Tons of people on this board have done WAY more than that.
    soundman98 likes this.
  9. Oct 11, 2022 at 1:52 PM
    LunarTeal
    LunarTeal Rarely interested....
    I did not act like it was beneath anyone - I've spent a ton of time doing my own maintenance, to include engine replacements in several OEMs, engine rebuilds, shocks, clutches, rear end rebuilds, LOF etc. I've also managed large shops with 20+ mechanics in it on 3 shifts. I've even overseen repairs for large fleets whose vehicle count is excess of 14,000 and budgets in excess of 8 figures a month.
    I'm well versed with all sides of the coin I assure you.
    My quote was that it had to be a joke because I do not see how anyone could do what the thread referenced claimed. I made a joke and pointed out some irony in the "dealers all suck, those techs don't know squat which is why I do my own maintenance" posts that are prevalent here and then we also see the "I drained my transmission, added oil to the radiator and now the truck makes weird noises" threads. I used a touch of hyperbole - I'm sorry.
    AxisCab[QUOTED] and Steves104x4 like this.
  10. Oct 11, 2022 at 2:01 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    This is your solution. You have to allow air into the top of the dipstick tube so that the oil drains down. It'll drain faster if it's warm. If it were me, I'd pull the dipstick out, wait the 5 minutes or more, clean off the dipstick, reinsert and check the level.
    Scuffing up the surface of the dipstick between the marks makes it a bit easier to get a good read.
  11. Oct 11, 2022 at 2:22 PM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    Dump 6 quarts in and be done.
    22Coma6MT likes this.
  12. Oct 11, 2022 at 2:43 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    check it first thing in the AM, all the oil in the tube will have run down. can use a flashlight to shine on it.
  13. Oct 11, 2022 at 2:49 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    its true quite a few have done it.
  14. Oct 11, 2022 at 3:09 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Drain the oil and put in 5 qts w/filter; (4.0L) let it sit overnight in a reasonably level spot. Pull the dipstick and take a reading before you go on your way in the morning. If you're paranoid, wipe it off and check it again. Adjust oil level as required from a new (quart) bottle, but limit it to a couple of ounces at a time. Repeat above. Once it's at the dot, you're done. If you're STILL worried, repeat in a couple of days. I know this method works because my truck doesn't burn oil and it stays at the same spot ("full dot") on the stick for the entire 5,000 miles to the next change every time I check it.
    Note: When I have been foolish enough to check it when I stop to get gas on a drive to the middle of nowhere in Maine to fish and hunt, it's almost always a wacky reading: overfilled, a qt low, no oil showing on the dipstick at all (WT!!!???.) Ya. My advice: Maybe don't check it when you're stopped to get gas, or especially during a lunch break on the side of some wilderness road, where the Canada BlueJays land on your shoulder or head begging for food, and it's obvious no one has passed this way for at least a week. (and the last place that sold oil for $8.99/qt in a brand you never heard of is at least 50 miles away: It will ruin your whole day. ;)
  15. Oct 11, 2022 at 3:56 PM
    #35
    avi8or_co
    Even though I’ve done the sand the dipstick mod to be able to see it, 99% of the time this is what I do on an oil change.
    When I drain the truck (it’s level in the air, because I jack the front and back to do the rotation) I pull the plug and let it drain while I swap out the filter and rotate the tires. Then I replace the plug and dump in 6 qts. Just about every time after I let it idle a min or two and I shut down, it’s about 3/4 up the range on the dipstick and I leave it at that. Every time I check it in between, it’s again at the 3/4 mark.
    6qts will do you just fine for an oil change, my IS350 with the same 2GR under the hood I follow the same procedure and get the same result. The book on both says 6.3 I think it is but that must be the absolute full mark which isn’t really necessary. It runs just fine on 6………plus conveniently, cases of Mobil 1 come in 6 packs and Costco has it $10 off about every other month:woot:
  16. Oct 11, 2022 at 7:06 PM
    #36
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    That's what I do too.
    I am more concerned that it does not leak than the reading on the dip stick.
  17. Oct 11, 2022 at 10:04 PM
    #37
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i park facing north and uphill at least 3% grade, while the moon is aligned with jupiter, and pull the dipstick with my left arm while covering the fill cap with my right hand so it can't see what i'm doing.
    works every time.
    Dfpftw, marcamos[OP] and Williston like this.
  18. Nov 18, 2022 at 4:40 PM
    #38
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    I have a new 2022 Tacoma, my first Toyota by the way. I been driving and taking care of my own cars/trucks for 50 years. It’s sad that I had to read about trying to read the @#$&*@#$ dipstick on a new $45,000 truck. Pull the stick, wait 5 minutes, scuff up the stick, check after it’s warm etc. How pathetic is this design. Every car or truck I’ve owned you would pull the stick, wipe it off, stick it back in and then read it and know exactly how much oil is in the engine but apparently that is too damn simple. I’m OCD about my cars and take excellent care of them and this is what is have to deal with on a brand new truck !!!! I hope this is not a sign of things to come with this Tacoma. Thanks for letting me vent.
  19. Nov 18, 2022 at 4:58 PM
    #39
    Williston
    New England
    Just pull the out the dip stick first thing in the morning after it has sat all night. Works every time with my truck as long as it is sitting on a fairly level spot. The oil should be approx. on the top dimple. I replace it and go on my way: I seldom wipe it clean and take another measurement. I change my own oil and approx 5.5 qts puts it right at that top dot. When I have occasionally checked it after stopping to put gas in the tank, it is within a millimeter or so of this mark. My 120k V6 uses no oil between changes.
    Welcome to the forum! :thumbsup:
  20. Nov 18, 2022 at 5:30 PM
    #40
    bmg88201
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Thanks for the advice, that is what I was going to try. Check it after setting all night and just pull it out and read it. I did scuff up the dipstick with machinist lion’s tongue. It has a V6 and the manual says it holds 6.2 qts. Going to change it at 5000, even though the dealer will change it at 10,000. I bought Toyota oil and filter for now since it is under warranty. I was going to put 6 qts in it and run it and then check after it sits for several hours like you said. But maybe I’ll try 5.5 qts in it first. I’m grateful for the input.
    My last new vehicle was a 2002 Yukon, geez this Tacoma is a computer on 4 wheels. I’ve turned a bunch of crap OFF !!!!! Lol
