Any tips on removing the bank 1 sensor 1 o2 sensor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KickAss, Aug 10, 2024.
  1. Aug 10, 2024 at 7:01 PM
    KickAss
    KickAss [OP] Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    Hey guys,
    I've fished around for awhile here but couldn't find anything specific,,,,
    so,
    Any tips on removing the bank 1 sensor 1 o2 sensor? some way to get to it or how you did it, and then find the connector after it's installed.
    Got the Denso part, just having a hell of a time trying to get to and break it free,, it's soaking in PB Blaster now
    Any help is appreciated.
    Thanks
  2. Aug 10, 2024 at 7:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Will removing the front wheel and going through the fender well help?
    KickAss[OP] likes this.
  3. Aug 10, 2024 at 7:32 PM
    KickAss
    Chuck
    Florida
    Hmmm,,, didn't think of that, I will check first thing in the morning. Thanks TnShooter
  4. Aug 10, 2024 at 7:33 PM
    Bishop84
    Bishop84 Well-Known Member
    Through the fender.
    If its really hard, cut the wire and use a deep 22mm socket as a fail safe removal.
    TnShooter and KickAss[OP] like this.
  5. Aug 10, 2024 at 9:44 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yeap this ^
  6. Aug 11, 2024 at 4:56 AM
    KickAss
    Chuck
    Florida
    I like it, thanks man!
    Thanks guys,,, gonna get on it this morning, I'll report back, again,, thanks so much!
    TnShooter likes this.
  7. Aug 11, 2024 at 10:45 AM
    KickAss
    Chuck
    Florida
    Got it!
    That worked,,, turned the wheel, jacked it up, removed wheel, was able to get to it with that special socket and a long extension bar connected to my impact driver and off she came! PB Blaster helped overnight I'm sure, but it worked, wasn't easy and the plug was a pita also.
    Thanks again! Here's a pic of the socket if it helps someone else. :cheers:
  8. Aug 11, 2024 at 11:00 AM
    TacoTuesday1
    FL
    I did mine from the top laying accross the engine bay
    soaked in AeroKroil which is hard to find for a good price
    And MAP gas
