Any tips to replacing the rear brake line?
Discussion in 'Technical Chat' started by dispatch55126, Jun 11, 2014.
  1. Jun 11, 2014 at 2:48 PM
    dispatch55126
    dispatch55126 [OP] Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    It seems like the rear brake line is pretty straight forward. There isn't much room at the upper connection but it is doable. However, the retainer clip is rusted and refuses to move, even when tapping it with a punch and hammer.
    This is for a 1st Gen.
  2. Jun 11, 2014 at 2:56 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You are trying to replace the flexible hose, right? If the existing hose can be sacrificed, just cut it with a dremel downstream of the mounting flange. :notsure:
  3. Jun 11, 2014 at 3:07 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Just stick a flathead screwdriver under the clip and work with it. I was able to rotate the clip until I was able to grab it with a Channel Lock. It is a very reduced area to work in. Just jack the truck up high so you will be comfortable doing it. And put your jack stands up, just in case.
  4. Jun 11, 2014 at 5:04 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    Thanks. Took bending my arms in unnatural ways but I got it off.
  5. Jun 11, 2014 at 7:24 PM
    KenLyns
    Belly of the Beast
    ^Did you lower the spare tire? Gives a bit more elbow room.
  6. Jun 11, 2014 at 7:44 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    Yep and reminded myself the painful way to always cover your bald head with a hat when under a vehicle.
