any tricks for keeping truck cooler? AC wise.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pahaf, Jul 2, 2023.
  1. Jul 2, 2023 at 12:10 PM
    pahaf
    pahaf [OP] Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Hey guys. Summer is here.
    My 2015 Tacoma takes about 7 min of ac full blast to finally cool down the truck. Where it will be comfortable.
    Does anyone have tips or tricks to help with cooling?
    I know ceramic window tint helps. Did anyone do the dynomat and notice a difference in interior temps?
  2. Jul 2, 2023 at 12:16 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Get a good insulating sunshade. Something like this.
    https://www.amazon.com/dp/B07MVPR6QF
    Then crack the rear windows an inch during the day, if it's safe to do so.
    That's really the cheapest and best method you can do. If your cabin starts at ambient hot and not at molten lava temperatures, then the AC doesn't have to work as hard to get to a comfortable range.
    After that, look into UV tint to reduce the greenhouse further.
  3. Jul 2, 2023 at 12:17 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Do you use the recirculation button when you run the AC?
    AusBerg, MarX, NmapFE and 2 others like this.
  4. Jul 2, 2023 at 12:17 PM
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    Weak ac? 7 minutes seems excessive. Only a couple of minutes in my '05.
    HondaGM likes this.
  5. Jul 2, 2023 at 12:19 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Edit, I also start the first 30 seconds of my drive with the windows down. Just enough to cycle hot-hot air for just hot air. Then I roll them up the second I feel cool air starting to emit from the partially melted dashboard.
    AusBerg, MarX, Travlr and 10 others like this.
  6. Jul 2, 2023 at 12:23 PM
    pahaf
    paul
    NorCal
    yes. we always have the full fan speed. recirculation on. and just blowing out of the forward facing vents.
    @Jonas it works just like it is supposed to....i am just spoiled by our other cars. 2015 accord has great ac. 2013 Infiniti g37 has freezing cold ac....the tacoma is the one that is ehhh. Takes a while.
    @Rock Lobster i do have the sunshade and it does help. But i didnt know about the rear window. That is clever. I am going to have to start opening it. Makes sense.
  7. Jul 2, 2023 at 12:25 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I use the sunshade and also have those rain guards that really help keep the hot air flowing out of the vehicle when parked. Since I installed them I have yet rolled my windows all the way up . Leave down about 1/2 inch and no one can see, no rain gets in.
  8. Jul 2, 2023 at 12:31 PM
    TacomaWorld2023
    TacomaWorld2023 Well-Known Member
    Ceramic Tint, sunshade, and get some in-channel vent visors so you can crack all four windows while car is parked. The vent visors obfuscates the cracked windows from the POS of the world that like to take what isn't theirs. I turn off the recirculate air button whenever I'm 10 mins out from the house. It dries up the A/C drain hose so I don't smell stale socks next time I turn on the car.
    Outside of that, park in the shade when you can and keep the car clean. As well, service your A/C as needed. Don't be cheap and get the freon in a can; dump/flush the entire system. That is really all you can do...
    I will note, it is a larger vehicle so it will take longer to cool down.
    LeakyAC and pahaf[OP] like this.
  9. Jul 2, 2023 at 12:43 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Drive with all windows down for the 1st mile or 2. That lets the hot air out. Temps here in GA can easily get 180-200 degrees inside a parked vehicle. If you use the recirculate button without letting that air out, it takes a while to cool it down. Even 100 degree outside air is cooler than what is inside. Then run AC on high with recirculate button on.
    ToyodaSun and NmapFE like this.
  10. Jul 2, 2023 at 1:41 PM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Better to not run in recirc mode when the cabin is stupid hot. Turn recirc off to pull the (relatively) cooler outside air, it's much easier to cool even 100-degree fresh air than 140+ degree cabin air. Way less load on the system and it'll start blowing colder sooner. Ride with the windows open for a couple minutes to dump as much of the excess heat as you can, then when the cabin is roughly equalized with outside air temp, close the windows and flip on recirc if you wish.
    Much easier to dump the tons of BTUs through wide open windows at 55mph, than trying to funnel every last one through your blower and already-undersized AC system. And the more overloaded it is, the less efficient it gets, and the quicker you're ordering a new compressor.
    pahaf[OP], VanDoom and Charlie Bravo like this.
  11. Jul 2, 2023 at 2:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you idling in the driveway? Get up to speed and cruise, more airflow across the condenser and the compressor is spinning faster which moves more refrigerant
  12. Jul 2, 2023 at 2:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    One thing I didn't see mentioned yet is replace/clean your cabin air filter, if it's dirty you will have reduced airflow which will inhibit cooling efficiency.
    TomTwo, YotaProject, 50Buck and 3 others like this.
  13. Jul 2, 2023 at 2:12 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Well, it's 114 here in Desert. I know my a/c is low on refrigerant when it takes more than 3-5 miles to cool the cabin. I just recharged mine & it's ice cold within a block. I add a can once a year for $39.00 plus the cabin filter. I took it in to try & get it fixed, they told me I needed a leak test, change all the orings, accumulator, compressor, recharge. Price was insane. I'll put a can in once a year until it dies.
    Clearwater Bill likes this.
  14. Jul 2, 2023 at 2:25 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Yeah I'm in New Orleans where its been 95+ lately, I crack the windows during the day and roll all the windows down when I leave work, when I start driving the fresh air flowing through the windows for two or three minutes really help.
    Our tacoma is a 08 but the dang 05 civic whoes ac is way better which is very annoying.
  15. Jul 2, 2023 at 4:37 PM
    TacoTuesday1
    FL
    Light paint
    Ceramic tint
    Insulation
    window visors to crack windows
    recharge service to make sure r134a quantity is correct
    clean the condenser
    if I worked in a shop with access to a machine I’d probably replace the condenser with new on my truck, as well as compressor, to try and have good working parts I can rely on. Rather than old ones which at this point (knock on wood) really can go out at any time.
    pahaf[OP] and b_r_o like this.
  16. Jul 2, 2023 at 5:05 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I think the AC should be good for about 30-40 degree temperature difference. If it’s less than that you probably need a recharge and do a leak test while you’re at it.
  17. Jul 2, 2023 at 6:05 PM
    Argann
    Argann Well-Known Member
    Rich
    4Runner, Tacoma, Defender 90
    I have a full weathered setup. My normal routine is try to keep the windows cracked just a bit. I will start my car. Keep the driver door open. Remove all the window shades. Plug in phone and such. Shut door. Hit recirc and go. By then it is cooling down.
    Window shades helped a lot. Plus all my windows are tinted.
  18. Jul 2, 2023 at 7:01 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    An auxiliary pusher electric radiator fan is another possible option.
    TomTwo likes this.
  19. Jul 2, 2023 at 7:35 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    Mine is icy cold - 2013 -
    Try recharging the AC system [R134A]
    I have an 2001 car whose AC gets weak about once a year - recharging the system fixes it 90%, good enough and I can do it at home.
    AusBerg and pahaf[OP] like this.
  20. Jul 2, 2023 at 7:53 PM
    Waasheem
    Waasheem
    2007 xrunner
    I used to do the leave the windows cracked open thing. Having a black widow dangle down in front of my face and drop while driving down the freeway with the nearest turnoff far away is not fun.
