any trouble with m udflaps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jang, Mar 2, 2012.
  1. Mar 2, 2012 at 4:43 PM
    jang
    jang [OP] Member
    cincinnasti
    06 tacoma
    has anyone else had trouble with the second generation tacoma front mudflaps breaking off? or am I in this alone? I've had both front mudflaps break off in the last two months, has anyone else had this problem?:confused:
  2. Mar 2, 2012 at 4:52 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2012 DCSB OR
    mine rub and hit everything!!
    Do some searching, most people either trim them or swap them with pre 2012 mudflaps.
  3. Mar 2, 2012 at 4:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Pretty normal. Had to trim mine on the 06 I had.....broke them first time I went offroad.
  4. Mar 2, 2012 at 4:57 PM
    bmc52
    bmc52 .
    Brett
    San Antonio,TX
    2007 4x4
    Stock
    Yes, after a day of 113 degree heat in the summer. I was driving on the highway and they both snapped off.
  5. Mar 2, 2012 at 4:57 PM
    rngrchad
    rngrchad Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    I broke one last weekend. I broke another the 2nd week i had the truck. they suck, but I really like keeping mud off my truck, so i will have to ziptie them back together and rebolt them on....er replastic pop rivet them i mean. These trucks bodies are like plastic/fiberglass nightmares.
  6. Mar 2, 2012 at 5:01 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    Anyone want to try the flaps from Huskyliner??
  7. Mar 2, 2012 at 5:02 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    wait....what,no way.
  8. Mar 2, 2012 at 5:02 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Unless you have laws about needed mud flaps or if you need them, just take them off.
  9. Mar 2, 2012 at 5:55 PM
    Mr Hyde
    Mr Hyde 3rd Taco's a charm
    Greg
    Winston-Salem, NC
    2012 TRD O/R 4x4
    TRD Catback, Rugged tri-fold Tonneau, Bed Extender, Tint, Ventshades, BFG ATKO's, and more to come.
    I had both the front flaps start to break off at the same time on my '06...took about 45,000 miles. The downside was they had chewed my flares up pretty bad. I took them off anyway, and then started seeing rock chips all over the lower sections of the truck. Its almost like a lose lose scenario in a way. You pick your poison and go with it.
  10. Mar 2, 2012 at 6:04 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you trim 4 - 4 1/2" from the bottom they are much better. First, being shorter reduces the chances of breakage, and cutting the rolled edge from the bottom takes the "rigidity" out of them and allows them to flex more without breaking. Tin snips work great, as does using the peice cut from the bottom to match the rounded corners.
  11. Mar 2, 2012 at 6:05 PM
    rngrchad
    08 Rugged Trail TRD
    Why would you take them off? They serve a GREAT purpose of keeping MUD OFF OF YOUR TRUCK. Which is really really nice for most normal people. Now, I do understand some people like to make their trucks look "dirty" so in such a case I guess they might like to take them off.
    Of course, lifted offroad trucks don't apply, the OP obviously isn't wheeling a modded rig. The stocker mudflaps are very nice, it just sucks they rip off easily.
    There are other reasons to leave the mudflaps on that have nothing to do with your local LAWS . DON'T TAKE THEM OFF, fix them, or cut them shorter.
  12. Mar 4, 2012 at 5:38 AM
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    My front right one cracked and on it's way to breaking off.I haven't even had it off road only a fairly rough driveway.
  13. Mar 4, 2012 at 5:50 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Normal People? :rolleyes:
  14. Mar 4, 2012 at 6:13 AM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    yep, my right front one split. i just took all of them off.
  15. Mar 4, 2012 at 6:22 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4
    My fronts broke off at about the 5 year mark. Just left them off after I got a price from the dealer on factory replacements. Right around 105 bucks each. I don't miss them. Still have the rears on.
  16. Mar 4, 2012 at 6:34 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I have lost mine a few times on the trails.
    They keys to keeping them on:
    *Cut about 3-4" off in height (from bottom)
    *Get HD mounting hardware (I used an assortment of GM/Ford pins I beat in with a hemmer)
    *Cut and trim flap (in fender-well) so tires don't rip it off at full lock and stuff in reverse
    *Before remounting slather contact surface area with structural silicone
    *Do the same to the rears less the fender-well trimming
    Before I modded mine they would rip off every time I was in reverse/lock/stuff.....that was about 4-5 times.
    After modding I have only lost one rear flap in about 2 years and that only because the tree I hit ripped it off...and that tree did more then just whack a flap off so overall I'm extremely happy
  17. Mar 4, 2012 at 6:56 AM
    Syncros
    Syncros Well-Known Member
    I trimmed mine. The stock ones scraped the paint off the bottom of my flares but, meh its a truck, it's not very noticeable anyway.
  18. Mar 4, 2012 at 7:34 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    My passenger front is hanging by a thread. So both will come off today. Rears look ok.
  19. Mar 4, 2012 at 8:00 AM
    TJ Asher
    TJ Asher Well-Known Member
    TJ
    Minneapolis
    '10 Virgin
    I've broken 3 fronts in two years. One just backing out of my driveway.
    I trimmed the one remaining stock front down and replaced the other with the Husky mud flaps. Both are working excellently. The Husky flaps are a great deal at $40 a pair compared to $125 EACH for the stock flaps.
  20. Mar 18, 2012 at 7:37 AM
    rjaco70
    rjaco70 New Member
    Ron
    RI
    Tacoma TRD Off-Road
    I've had my 2012 for 3 weeks and I'm already popping pins out. I think I may shorten them.
