Any truth to this article?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomairon, May 29, 2019.
  1. May 31, 2019 at 12:45 PM
    #541
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Should have leased it.
    My uncle had one of those in the 80s/90s it didnt look no where close to as nice as that one pictured. I can still remember ridding it, no seat belt, while he smoked a cigarette that he rolled himself. Back in those days you could go into a 7-11 and buy a bottle(glass bottle) of strawberry orange Tropicana.
    America needs the El Camino.
  2. May 31, 2019 at 12:47 PM
    #542
    KevinC
    KevinC Well-Known Member
    Kevin
    2017 SR5 Quicksand Tacoma
    Lmao, kid got a new engine for free, and still made his shit website? Type of guy to get his meal comped and still write a shitty review on tripadvisor
  3. May 31, 2019 at 1:48 PM
    #543
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    They are both great motors however, the 4L 1GR-FE is better suited to what I use my truck for.
    Running Board Man likes this.
  4. May 31, 2019 at 1:50 PM
    #544
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    It's a known fact that 2nd Gen is best gen
  5. May 31, 2019 at 1:50 PM
    #545
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    "May"???? Come on. You either know something or you're just making stuff up.
    The 1GR engine diagrams looks pretty similar to what I see when I change the oil on the 2GR-FKS.
    mynewtoy likes this.
  6. May 31, 2019 at 1:54 PM
    #546
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    you forgot the most famous 327! In fact, if the 4L is the 350... the 3.5L is the 327. Both great motors. Yesterday and today.:cheers:
    Also the 307
  7. May 31, 2019 at 2:08 PM
    #547
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    By 2012 they had most of the issues sorted out. I see you have a 2009.:D
    Paul631, boynoyce and Woodrow F Call like this.
  8. May 31, 2019 at 2:09 PM
    #548
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
  9. May 31, 2019 at 2:12 PM
    #549
    Woodrow F Call
    Colorful Colorado
    That's a pretty good comparison..... essentially the same bore/block with a different stroke.... At least if you're counting the large journal 327s. ;)
    mynewtoy and Steadfast[QUOTED] like this.
  10. May 31, 2019 at 2:21 PM
    #550
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    For sbc these are my favorites ... 406 , 408 ,410 and 454 sbc
    BBC ...... Won't go any smaller than a 565 and the 632 is the best
  11. May 31, 2019 at 2:31 PM
    #551
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Hydrolocks going through puddles. LOL. Maybe the Tacoma is a magical creature that assumes the characteristics of its owner, which would turn his into a whiny bitch.
    [​IMG]78453403-2G5A3082 by Lee, on Flickr
  12. May 31, 2019 at 2:40 PM
    #552
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Any Tacoma's successfully run the Back Door or Wrecking Ball trail at Johnson Valley OHV area ???
  13. May 31, 2019 at 3:09 PM
    #553
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    You forgot about the 302Boss found in the 60's mustangs or 302DZ found in the Z28's btw 5.7L is a 350ci.
    Not directed at you...
    a 3.6L would be about 220. Ci Hmm a 220ci motor making 278Hp and 260 torque. Lot more than a lot of the older TRUCK engines we all used for decades.
    ANY type of equipment that relies of gravity for liquid flow/location will have a maximum angle it can safely or be able to operate.
    Since all the mass produced vehicles under $100k have wet sump systems and gravity returns they ALL will have a maximum operating pitch and roll that they can safely operate at, depending on the oil return system it will also affect how long they can operate at that angle. i.e. 20mins at 30deg 5 mins at 60 deg. You'll also find different characteristics based on the design if you are pitch forwards or backwards right or left. Grade 2 physics applied to first year mechanical principals. "Common sense" to the mechanically inclined.
    G forces for the delta in speed and cornering forces are other considerations that that the engine designers take also into consideration.
    Only SLIGHT advantage the second gens have in the whole system is the torque values at 1500-about 2500 rpm (too lazy to go look it up),
    But now if you compare pretty much EVERYTHING ELSE, the second Gens ARE inferior. (Period)
    For the people saying that this is not a truck engine, I just wish you could see the look on people's faces when you blather that statement out.... Go to any mechanic or Automotive engineer, pop the hood and make that statement, Lol you'll see what I mean.
    If it is the same engine as in the Camry you should be able to unplug and unbolt one from there and drop it right in... LOL
    boynoyce, Boghog1 and JNG like this.
  14. May 31, 2019 at 3:16 PM
    #554
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Has the smallest bore and poorest flowing cyl heads of any BBC . As of today any BBC smaller than a 454 has no market value besides giving it to someone for #'s matching restoration
  15. May 31, 2019 at 3:57 PM
    #555
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    We just had our CIR/Paving train mobilized on a new project today. Our mechanic came out to get everything ready.
    I was feeling a tad playful, so I asked him to rank the top truck motors from the last 20 years. He though about it listed some of what he thought were the best and then started talking about the new Vogele path pavers we had been looking at. He's not a fan and let me know why.
    Anyway, I let him go on for awhile and said, "Billy, do you think the 4.0L Toyota 1GRE-FE is one of the better truck motors? I'm on a forum where people think it's in the pantheon of great truck motors."
    He laughed and said "Sounds like a stupid fucking forum."
    In the land of the blind, the one eyed man is king.
  16. May 31, 2019 at 4:01 PM
    #556
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    My guess is these same people are accustomed to that look and it no longer registers as derisive.
    daks[QUOTED] and boynoyce like this.
  17. May 31, 2019 at 4:02 PM
    #557
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Any chance Billy would want to be a moderator on TW.
    Probably could use someone of his caliber here...
    Jk mods
  18. May 31, 2019 at 4:20 PM
    #558
    TrailRayted
    TrailRayted Well-Known Member
    Ray
    2008 Rugged Trail Tacoma
    Well said
  19. May 31, 2019 at 4:23 PM
    #559
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    It looks like the side profile of a Stanley boxcutter, with a hump on top.
  20. May 31, 2019 at 4:47 PM
    #560
    81shark
    81shark Well-Known Member
