Any truth to this article?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomairon, May 29, 2019.
  1. May 29, 2019 at 4:19 PM
    #161
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    That’s Joan Chen ya kook
  2. May 29, 2019 at 4:20 PM
    #162
    stun gun
    Aaronski
    Tacomas.
    Dust storms av amirite
  3. May 29, 2019 at 4:21 PM
    #163
    My Name is Rahl
    So? We still have to check under the hood to see if it has a crankshaft or not...
  4. May 29, 2019 at 4:27 PM
    #164
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  5. May 29, 2019 at 4:37 PM
    #165
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Yeah I’m a kook, has to google
    I always like to check, see there was this one time when..........:anonymous:
  6. May 29, 2019 at 5:01 PM
    #166
    stun gun
    Aaronski
    Tacomas.
    Not if you like to party.
    I’m all about making memories.
  7. May 29, 2019 at 5:04 PM
    #167
    Al Hoff
    Al Hoff Well-Known Member
    Grand Rapids, MI
    2018 Tacoma Off-Road QUICKSAND
    I recently went through some... trails.. my engine bay is layered in dry mud and I have leaves stuck and stuffed in every possible nook and cranny under the truck. Sand and dirt chilling on the frame.. Guess I should clean it up before I take it to the dealer for my 15k. :mudding: Have not experienced and honestly have not heard about the incline/smoke oil pressure problem. I also have not gone up an incline for longer than 2 minutes. Thanks for bringing this up lol time to get back under my rock.
    Junkhead and JNG like this.
  8. May 29, 2019 at 5:07 PM
    #168
    My Name is Rahl
    I like making good memories. I don't think spending an intimate evening with a tranny is going to make me good memories.
  9. May 29, 2019 at 5:10 PM
    #169
    Stocklocker
    17TRDORDCSBAT
  10. May 29, 2019 at 5:10 PM
    #170
    Itchyfeet
    Itchyfeet Well-Known Member
    Drinks craft beer that no one has ever heard of - Beard smells like a day old Tuna sandwich - Knowledge base is strictly from Reddit - Wife doesn't want her face shown because she knows he fucked up and drove through a 20 inch deep stream- Doesn't understand that Jeep doesn't give a fording depth - Uses gender neutral language - Uses soft language - Quit is job because dad croaked and left him a pile of money - Thinks Enron Husk is a god - Sits down when he pees - Once wore a maxi-pad during a woman's march just so he could feel the oppression - Wants to be a YouTube Instaham social media influencer when he grows up- The type of guy to accuse you of being negative just because you said the weather sucks- Has mom issues - Didn't have enough common sense to file a claim with his insurance company - Hates to admit he's wrong
  11. May 29, 2019 at 5:15 PM
    #171
    TD90S
    GA
    ‘18 TRDOR 6MT
    Maybe not a good memory...
    But a hilarious story
  12. May 29, 2019 at 5:23 PM
    #172
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Mods, this man needs a custom title.....I’m partial to “The Tolstoy of Tacoma World”.
  13. May 29, 2019 at 5:25 PM
    #173
    stun gun
    Aaronski
    Tacomas.
    Nailed it.
  14. May 29, 2019 at 5:26 PM
    #174
    stun gun
    Aaronski
    Tacomas.
    Aka good memory.
    All of my best memories are of things that terrified me in the moment. Just sayin.
  15. May 29, 2019 at 5:28 PM
    #175
    GillyLink
    GillyLink Well-Known Member
    2018 Cement TRD Off-road DCSB AT
    Still stock completely capable!
    Honestly couldn’t of wrote that better myself if I had a week to think of what to say! That was amazing!
  16. May 29, 2019 at 5:29 PM
    #176
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    He has two valid points though,
    1) What is the Official safe fording depth? / Water level?
    2) What is that Max Incline?
    If Toyota won't say what it is but will deny warranty based on those parameters, then HIS POINTS ARE VALID.
    Dealer screwed up with the Hydrolocking diagnosis from water, maybe. My gut says it was from oil in the cylinder , but without looking at the Engine myself or talking to the tech, it's just a best guess.
    You guys knew that the lowest computers in these trucks are located inside the frame rails by the front of the front doors right? One is for the HP fuel pump I believe.... Yes they are supposed to be sealed, and yes the have waterproof connectors with O-ring seals (O-rings aging and shrinking/cracking etc) in them but... then all the other electronic gadgetry hanging off transmissions and transfer cases etc. Lol look at where the ABS sensors are...
    Official response (if there ever is one) will probably recommend water depth no more than the bottom of the frame rails.
    Age of the truck, manufacturing variation, dwell time in the water will create a probability matrix that would make it impossible to give you and accurate "guess" what the safe #'s are past that point. Until you get to the Obvious failure levels (air intake, internal passenger area computers).
    So with that logic
    Fine upto the bottom of the frame, This is were your warranty is safe.
    Might have a problem past there depending on how long you are in the water, this is where your warranty is in jeopardy.
    Once you get water into the passenger compartment upto the pedals or into the air intake, your warranty is null and void. Like trying to claim warranty on flood damage, not gonna happen.
    But I'm not an Engineer from Toyota, so my opinion is just on the pile of other opinions.
    Incline angle is a lot harder to say or even get a feel of with all the anecdotal testimony here closest I can figure out is it's somewhere past 30-35 degrees pitch,
    what was the Roll when this was happening? Does it happen only when you're Rolled towards the passenger side, been like that for how many minutes?
    Bad/weak valve guide or valve stem seal(s) might contribute to this also, oil return placement and size as well as a host of other things can contribute to this issue.
    Here is a shot in the dark giving the benefit of the doubt to they person with the issue.
    While on a 35 degree Pitch and a 20 degree passenger side roll, the oil started pooling in the rocker cover. Pressing on the gas then letting it off suddenly increases the vacuum in the cylinder and pulls oil past a marginal valve stem seal, unburnt oil and carbon accumulated in that passenger rear cylinder until internal pressures exceeded design parameters and the connecting rod bent.
    During the drive home and pulling a heavy load the connecting rod finally failed.
    Engineers at Toyota can say almost exactly what angles and times it will take before you go outside a safe zone for the truck, problem is getting the sales guys to let them release that information.
    ** Trying to get even a seat of your pants idea of facts on this site sometimes can be soooo hard, it's like trying to pick the pepper from the flyshit with trolls screaming in your ears while turning fans on. **
    Smoking on an incline happens in most vehicles unless they were specifically designed to run that way, only different parameters are how much and how long.
    We just gotta get the trolls distracted somewhere else and maybe we can get a better idea of roughly where the safe spots are for climbing in a Tacoma.
    We might be able to go 35 deg Pitch with 20 degrees roll on passenger for 10 mins, but could go 50deg Pitch with a 20 deg roll on driver side for 20 mins, not real numbers but we have to disperse the trolls so we can gather the facts.
  17. May 29, 2019 at 5:31 PM
    #177
    stun gun
    Aaronski
    Tacomas.
    Like that one time someone dared me to walk up the back steps of the Whaley house and stare into a 2nd story window. Which I did. And when I saw the ghost of a woman staring back at me with a scowl, I was so horrified my heart palpitated and I fell backwards. The ghost stormed forwards to the window to look down at me and she started screaming at me in Spanish. And it was at that point I realized she was the night time cleaning lady, because ghosts don’t speak Spanish. A wave of relief washed over my body. Ghosts are like the only thing I’m afraid of.
    GillyLink, jmneill, TD90S and 3 others like this.
  18. May 29, 2019 at 5:32 PM
    #178
    stun gun
    Aaronski
    Tacomas.
    His profiles of Kyle and the Applebee’s waitress are also excellent. Nails it EVERY single time.
  19. May 29, 2019 at 5:38 PM
    #179
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    WOW!! before reading I guessed a California type person= a fucking web link about 1st world problems type, first paragraph, yup California.... What happens to you folks in CA?
    Okay, more to the rant. CA = ~25 to 29y.o. = IG account = buy a 3rd gen = roof rack = weird tent thing on bed = bro it out - bro, put it on IG. Blame anyone and I mean anyone, but the fucker looking at you in the mirror. Fuck, no one is listening to me blaming others, back to IG or any social media that I can find like minded fuckers, share said blame story.
    Sorry, but I see same thing way to often and makes me laugh at CA = IG fuckers... :anonymous:. I have a very difficult time believing folks like this, which unfortunately we see all to often on TW :frusty:
    Ok, rant done :fenforcer:
    Boghog1 and stun gun like this.
  20. May 29, 2019 at 5:41 PM
    #180
    stun gun
    Aaronski
    Tacomas.
    I don’t know if you know this, but you need California more than California needs you. We could isolate that state, and it could exist indefinitely, and maintain control of the globe based on ports, military power, resources, and agriculture. Sell your Tacoma
    :D
    GillyLink and tcjacado like this.
