Any Typical Problems After 200K Miles?
Discussion in '1st Gen. Tacomas (1995-2004)' started by GradGirl, Jun 13, 2013.
  1. Jun 13, 2013 at 12:25 PM
    GradGirl
    GradGirl [OP] New Member
    02 PreRunner
    First-time post! I've always lurked on Tacoma World to find out more about my truck, and it's always been a super useful resource, so thanks, guys!
    I have a 2002 Tacoma PreRunner with about 210K miles on it. I'm also about to move away to graduate school approximately 2000 miles away. I would love to take my truck with me considering that I will need a vehicle for where I'm going, but I'm not sure if I can rely on my truck to get me there with so many miles on it.
    I have had no problems with performance, and recently had it checked out for basics (like brakes, fluids, belts, stuff like that) with everything checking out. My question for you guys is, is there anything "notorious" that happens to the first generation Tacomas after 200K miles? A friend mentioned to me that the 4Runners and Tacomas have a tendency to blow the head gasket around 200K, which would be super lame if that happened while I was driving in the middle of nowhere.
    I understand that every truck is going to be different depending on how hard it's handled or whether it's had regular maintenance, but if there is anything that seems to happen a lot around that mileage, any advice would be great! It would help me make a decision as to whether I can drive my truck or just buy a car once I get there (but we all know Tacomas are better) :)
  2. Jun 13, 2013 at 12:44 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    96 Tacoma Xtra Cab 2.7L
    Toytec Bilstein 5100's, Chevy Leafs.
    Should be good, just now broken in :D but I can't speak for a V6
  3. Jun 13, 2013 at 1:53 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    possible tendancy that the V6 headgasket does go but thats usually do to neglect on the owner. Should do the headgasket when doing the timing belt...i sure as hell do.
  4. Jun 13, 2013 at 5:18 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    ^could put in some head gasket sealer beforehand just to help prevent the off chance it would blow. Can't think of any predictable thing failing, but there probably will be some random little things that fail like a tps sensor or whatever
  5. Jun 13, 2013 at 5:23 PM
    scocar
    scocar Purity of essence
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Back to square one after the 2001. So...
    The old 3.0 before the Tacoma (95) head gaskets were flawed and known to blow, but I've never heard this of the 3.4, which is pretty bombproof.
    Just keep up with timing belt (and h2o pump) replacement every 90k miles (you should be on number 3 by now), and keep up with fluid and spark plug changes.
  6. Jun 13, 2013 at 10:03 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    +1, my '02 is currently at 246.5K miles and it's still running like a champ. don't forget to service the transmission too.
  7. Jun 13, 2013 at 10:08 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    Oh yeah! Sometimes the factory transmission cooler in the radiate has been known to leak coolant into it, put an aftermarket tranny cooler on it! And have it flushed
