Any value in "fluid-filming" (or similar anti-corrosion treatment)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tirediron, Sep 10, 2019.
  1. Sep 11, 2019 at 1:25 PM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    I'd still FF cause you can spray everything minus exhaust and brakes. Lots of other parts will rust too if you dont lube her up
  2. Sep 11, 2019 at 1:33 PM
    SIDELINER4
    SIDELINER4 SO MOTE IT BE.
    Sgt. G
    Hanover, NH & Jacksonville, Fl.
    ***UPDATE*** Purchased the 2019 TRD PRO VOODOO. 2016 Tacoma TRD Sport 4x4
    *Moto Fab Lifts* Level Kit (3x2)(Comming soon)! Bed Mat. Hondo AR-15 Radio knobs. Weather Tech Rain guards. Diode Dynamics interior LED's.(Wish List), Center console divider. Keeper Gun Magnet. 2" hose clamp Tailgate mod (along with about half of the "Cheep/Free Mods").Oh, my favorite "mod" is the AJT DESIGN Key fobs! (will need two more Voodoo Blue).
    True that. Thanks.
  3. Sep 11, 2019 at 1:39 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    On the can it says not to spray any rubber bushings or anything cuz it can cause swelling. Anyone have this issue? Just FFed mine about a month ago here in Spokane.
  4. Sep 11, 2019 at 1:47 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Is the fluid film sticky? If so what happens in sandy environments? Does sand get stuck in the cracks?
  5. Sep 11, 2019 at 1:54 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    $30,000. and up in a vehicle cost. Spending a few hundred bucks in rust protection, no brainer.
  6. Sep 11, 2019 at 1:57 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    I had a new bumper on the truck with only base paint on it. Undersides Fluid Filmed. Had to take the truck out in a snow storm. 1 trip in the brine. Went to use the truck 1 week later & the bumper had flash rusted completely. 1 trip. Under truck - no rust.
    If there is water in your atmosphere, If they brine even 1x/year. Fluid Film, or Wool Wax, or spray hot oil on the underside of your Toyotii. Nice thing about the fluidness of Fluid Film is it will flow into the bottom of your doors & along the leading edge of your hood when you spray it in there. Definitely do something. I had a Tundra (not sprayed) rear diff rust until pinholes started to leak the diff. fluid. Toyota metal is … well not specified to last your lifetime. :)
  7. Sep 11, 2019 at 8:06 PM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    I love Fluid Film and use it all the time.
    I'll be trying out WoolWax.
    FYI, I bought the Harbor Freight pneumatic engine degreasing tool for $5 and will be using it to apply my next application.
    Additionally, on all of my vehicles I spray fluid film in all of the duration holes in each door. Stinky but goes away after a week it so.
  8. Sep 12, 2019 at 4:49 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I'm trying out 3M Cavity Wax this time around. It's a replacement for the now discontinued 3M Rust Fighter 1. It has a lower odor (still some, though) than the FF... so much nicer for spraying in to areas like rockers, doors, and floor spaces that have some access to the passenger compartment.
  9. Sep 12, 2019 at 5:22 AM
    KVTaco
    KVTaco Well-Known Member
    +1 for Fluid Film - I also did all the interior parts by pulling off those black rubber "stoppers" all over the place and spraying inside. It does collect dirt but it's protecting. In fact, if you power spray the dirt off you are also taking off the Fluid Film so just leave it.
  10. Sep 12, 2019 at 5:29 AM
    Dryvah
    Dryvah Well-Known Member
    MA
    2019 Tacoma TRD
    I pay a place to fluid film mine. They use a spray gun and can get in every nook and cranny. It make a mess of your driveway while spraying it. If you're doing it at some put a tarp down first!
    Only downside is the smell. It lingers for a week or two. You can smell it in the cab.
  11. Sep 12, 2019 at 5:36 AM
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    What sort of place does this? I've done my own three years running, but would be curious where to find someone to do it professionally and how much it might cost..
  12. Sep 12, 2019 at 5:40 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    How did you only use 4 cans? I go though about 6 cans doing just the front half of the truck.
    Breakfast Taco likes this.
  13. Sep 12, 2019 at 5:42 AM
    Dryvah
    MA
    2019 Tacoma TRD
    Check this out
    https://www.fluid-film.com/undercoating-locator/
  14. Sep 12, 2019 at 6:20 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I did mine with Woolwax mid-summer, and I plan to check it in late fall. I'll touch up, or do a complete reapplication as needed.
    I bought a kit with the "professional" gun. It was my first time spraying any kind of lanolin undercoating, but it was a piece of cake.
    Woolwax has almost zero odor, which is nice.
    I would recommend applying it outdoors if possible. I did mine in our garage, and while it didn't appear to be over-spraying at all, there
    was a very fine mist/coating on most surfaces of the garage when I was done. I noticed it on the windshield and mirrors of the Tacoma.
    It wasn't anything terrible, but be aware that it's moving through the air, even though you're spraying under the truck.
    https://www.ebay.com/itm/Fluid-Film...-Kit-Bundle-w-PRO-GUN-extensions/183682387288
    senecataco and Breakfast Taco like this.
  15. Sep 12, 2019 at 7:12 AM
    #35
    tirediron
    tirediron [OP] Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Well, FF was on sale for $60-something a "gallon" at Princess Auto (Canadian Harbour Freight) so I grabbed one; pick up a gun when they go on sale next. Guess we're gettin' stinky!
  16. Sep 12, 2019 at 7:12 AM
    #36
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Hell fucking yes
  17. Sep 12, 2019 at 7:19 AM
    #37
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    It will more than pay for itself down the road when you don't have to replace the truck, or you have work done on the truck & they finish it up in less time, or you sell the truck for highest book value.... & you can use it on your lawn mower, snow thrower if you have one, ….
  18. Sep 12, 2019 at 7:19 AM
    #38
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Whoa. Who's charging you that much for fluid film. Bit high there
  19. Sep 12, 2019 at 7:21 AM
    #39
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Yeah I used about 4 cans on my entire truck too. That includes the engine bay and doors and tailgate
  20. Sep 12, 2019 at 7:22 AM
    #40
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Been in the Salt Belt since 2014 looks good to me.
    TRDProOne, ancient11, BRFab and 3 others like this.
