Any watch experts out there?
Discussion in 'Off-Topic Discussion' started by chris4x4, Aug 18, 2013.
  1. Aug 18, 2013 at 3:50 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Im wanting to get my Dad a new watch as a gift, and I have some questions.
    First, The brand Im getting him is a Movado. They are the only ones that have a style he would like. Second, I have the choice between a Sub-sea series 800 automatic, and a new Datron chronograph quartz. My biggest questions are, I have heard and read, that Movado uses a pretty high end automatic movement (ETA-2686, IIRC), but its still has an accuracy of +/- about 10 seconds a day. How much more accurate is the quartz movement? Also, the auto only has enough reserve for 40 hours or so?? Thoughts?
  2. Aug 18, 2013 at 4:07 PM
    M202Flash
    M202Flash Well-Known Member
    California
    '11 TRD DCSB
    Diff breather mod/JP Metal Fab Tie Downs/Plasti-dip front valance/Famous Fabrication Sliders/Illumination Supply LED Spotlights w/ Relentless Hood Hinge Light Mounts/Bora 1" Spacers/Westin Brush Guard/BajaRack/Goodyear Duratracs 265-75-16
    My everyday wearer is a Boschett Cave Dweller with an automatic movement. My second watch is a quartz Marathon JSAR. I found if I take the auto watch off for couple of days, it wound down and required me to manually wind it. I eventually had to buy a watch winder for weekends, etc. when its not being worn. The quartz, however, is self sufficient and requires nothing but a new battery after about three years. Bottom line...I prefer the quartz movement.
  3. Aug 18, 2013 at 4:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That is typical of most automatics. They are a nice hands-off if worn daily, but not if they are an evening/church watch.
    Quartz movements simply lack the "mojo" that watch snobs want, even if they are more accurate. It's like honing a straight razor on a stone, vs synthetic stones, vs lapping film, or simply shaving with a Mach-3.
  4. Aug 18, 2013 at 4:14 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I thought you said..............SPIDER! [​IMG]
  5. Aug 18, 2013 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks!
    So quartz is more accurate?
    Youre an asshole.
  6. Aug 18, 2013 at 5:03 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I've never seen a quartz movement with anywhere near +/- 10sec/day.
    Normally more like +/- 10sec per year.
    Surprisingly, the least accurate quartz movement I've ever seen is my wife's new Citizen Eco-Drive "Happy Flight" Solar Atomic.
    It syncs with Ft. Collins every night, but by midnight (it starts trying to sync at 2am) it's about 1/2 second fast.
  7. Aug 18, 2013 at 7:32 PM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    My quartz fossil watch was always spot on when I would put it on once a month or so. I don't wear watches. Finally I quit wearing it all together, the battery died, and the quartz lost charge. It's a paperweight now.
  8. Aug 18, 2013 at 8:30 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    New battery will bring it back unless there's something wrong.
    The circuit just applies a voltage to the quartz which makes it oscillate. That oscillation is divided (by 100's of thousands) to tell the watch when to tick off one second.
    The quartz has no "charge" to lose.. it's all in the battery.
  9. Aug 18, 2013 at 9:11 PM
    RAT PRODUCTS
    Farmington, MN
    False. I sent it to fossil and they said that the quartz lost all charge and can no longer vibrate properly. It wasn't covered under warranty because I allowed the quartz to die. They would charge the quartz if I wanted to pay whatever it cost, but I never wear it so I said no.
  10. Aug 18, 2013 at 9:16 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    They fed you a line of bullshit.
    The quartz is a simple flake of a stone that has been on this planet for a few million years. It has no charge, but it vibrates when a voltage is applied to it.
    It becomes a part of a tank circuit that sets up a resonant frequency that the watch measures and uses as it's time standard.
