Any water or Wastewater guys here?
Discussion in 'Jobs & Careers' started by jerretxx, Nov 17, 2013.
  1. Nov 17, 2013 at 5:53 PM
    jerretxx
    jerretxx [OP] Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    Yeah, its a program that allows you to control a PLC or VFD remotely, also it allows you to have sensors basically anywhere you want them to control temps, and pressure. Its great for pump stations because it allows you to control a place without physically needing someone there.
    It is basically for monitoring but it also allows you to remotely control the instrument as well.
  2. Nov 17, 2013 at 5:55 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    That's awesome I will have to talk to my instructor about it tomorrow..
  3. Nov 17, 2013 at 5:55 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I'm mostly on the pure side. Actually I'm the one who gets to talk to the FDA when the show up. We are in a GMP environment, so things have to be up tight. Its a PITA, but its always interesting.
  4. Nov 17, 2013 at 5:56 PM
    jerretxx
    Jerret
    North Carolina
    A lot of records and paper involved im sure.
  5. Nov 17, 2013 at 5:56 PM
    jerretxx
    Jerret
    North Carolina
    it is interesting stuff. ill see if I can grab a screen shot of our system to give you a basic idea
  6. Nov 17, 2013 at 5:59 PM
    tacomakid96
    Phil
    Out n' about
    Right on brotha
  7. Nov 17, 2013 at 6:00 PM
    skisailbike
    skisailbike Well-Known Member
    Colorado/Alaska
    '14 4x4 DCSB OffRoad
    Icon 2.5 ET coilovers, LR UCAs, Dakars, Icon 2.0 RR ET Rear Shocks
    Yeah, between pathogen reduction methods, soil science and dewatering with polymers and centrifuges, there is a lot to get your head around.
  8. Nov 17, 2013 at 6:00 PM
    Rupp1
    NC
    Indeed. For a 15. Min. Temp. Calibration, its about 30 min of paper and computer work.
  9. Nov 17, 2013 at 6:01 PM
    jerretxx
    Jerret
    North Carolina
    This is our sludge receiving from our dewatered bunker to our furnace. It allows you to check pipe pressure, lube pumps, bunker and hoper levels, and which leveling screws that are operating. also, you could click the words (running or stopped) and switch them on or off depending on what was going on within the plant. tracks everything you need to know.
  10. Nov 17, 2013 at 6:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You will work with the state, so yes, be prepared for lots of paperwork.
  11. Nov 17, 2013 at 6:02 PM
    jerretxx
    Jerret
    North Carolina
    I can believe that, we have to take samples every 2 hours and record all the data, 24/7 365
  12. Nov 17, 2013 at 6:03 PM
    jerretxx
    Jerret
    North Carolina
    yes, you also need to learn very fast that polymer is extremely slick if its wet. Did your plant have good luck with their centrifuges?
  13. Nov 17, 2013 at 6:39 PM
    skisailbike
    Colorado/Alaska
    Yeah, we worked with centrifuges at several facilities as both permanent and temporary installations. For the most part, once the polymer was dialed in we had good success. The up front capitol spend was pretty significant, but high trucking and landfill tipping costs often made it pay off pretty quickly. As for polymer, I've seen a few nightmare polymer spills in plants that just about broke me. There isn't enough water in the world to clean it up...
  14. Nov 17, 2013 at 7:26 PM
    jerretxx
    Jerret
    North Carolina
    Were one of the few plants that runs a centrifuge. Several people we have met at WW conferences swear against them and said plate press is the best way to dewater sludge. However, I disagree. We have had good luck with our centrifuges and they require very little maintenance for how much they run.
  15. Mar 5, 2014 at 12:17 AM
    #35
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I've worked with chemical treatment and operational optimization of CWT, boilers, and waste water at refineries.
    Water is a niche industry but an extraordinarily important one. You'll always have a job, that's for sure.
  16. Mar 5, 2014 at 12:26 AM
    #36
    Hawkeye888
    Hawkeye888 Well-Known Member
    The facility I work at has its own waste water treatment facility that I have to monitor and sample. Also deal with large air compressors, boiler, cooling water systems, and everything else in the facility lol. We run DeltaV
  17. Mar 5, 2014 at 1:07 AM
    #37
    Biscuits
    I won't bore y'all with the chemistries of polymers/coagulants, but many are flocculants: coiled molecular chains that uncoil & expand when exposed to water and attract solids and other muck that's in the water. The good news, like skisaibike said, once you have the correct ppm dosage for your application, they work like a freaking champ. (Obviously if you have too much or too little, you won't get the clarification that you need among other potential problems.)
    Unfortunately, because water causes floc to uncoil, it seems you need about 100lbs of kitty litter, another 100lbs of pig mats, a shovel, and a whole lot of curse words to clean up a gallon of even semi-wet polymer.
  18. Mar 5, 2014 at 2:31 AM
    #38
    DavidR
    DavidR Well-Known Member
    David
    Northern NY
    2011 Tacoma TRD Sport DCSB
    :anonymous:
  19. Mar 5, 2014 at 6:14 AM
    #39
    bluedust
    bluedust Well-Known Member
    Patrick
    Pittsburgh
    '12, Access, TRD, Off Road, ,
    Wet Okole Seat Covers, Charcoal & Black "TRD" stiching Stuby Ant., Husky Mud Guards WeatherTech Floor liners
    I am appointed to sit on a Board for a municipal authority, not too big,
    30-40,000 "customers".
    Starting a substantial upgrade at the plant, dollars and millions of gallons treated.
    Under a few consent orders, DEP, EPA
    Never a dull moment
  20. Mar 5, 2014 at 6:23 PM
    #40
    jerretxx
    Jerret
    North Carolina
    Our waste water company is made up of board members as well.
